Question about Bose Audio Players & Recorders
I have a Bose w/cd player. Have had no problem until recently. I was listening to cds and I inserted a cd that I had burned and it played. Then I inserted a store bought cd I have and the message on display was 'reading cd' and then it displayed 'cd not readable.' What is the problem?
  • Julie Barrera May 21, 2011
    Thank you so much. How do I open the unit? Would it be in the Bose manual?.
  • 11,800 Answers
The optical head inside your player has a plastic lens on it. To adjust to the different types of disks that lens is put on a suspension that is dinamically adjustable.
If you get a Not Readable message then the signal the laser sensor from the optical head receives a reflected signal that is too low. This happens either because the lens is covered in dust and you must clean it or the suspension of the lens is not working anymore and the reflected signal is no longer focused so it's too weak. This is almost always caused by a failure of the controller of the optical unit.
To do a proper diagnostic and attempt of fixing it you must open the unit, access the lens and clean it thoroughly with a can of compressed air and a q-tip. Use this occasion to check its suspension - sometimes dirt seeps in and partially blocks the movement.
If after that you don't see a marked improvement then the optical unit has failed and it will have to be replaced. If this is the case i think that it will be cheaper in the end just to replace the entire player.
Posted on May 21, 2011
  • Azrael SRL May 21, 2011
    You just take out the securing screws and the top lid will slide out giving you direct access to the optical unit. But you should do it yourself only if the player is out of warranty - opening it yourself would void it.
Bose sound
You could try to clean the laser, with a special cleaning disk. Don't try to clean a laser by opening the player, you will damage the system.
If it is a CD burned in a PC, it also can be the laser is now a bit less, not capable reading CD-R or CD-RW, and still can read normal CD's
Read my other post over CD players
Jul 26, 2014 | Bose & Wave& Music System
Why won't bose play some cds
Could it be the CDs you can't play, are burned in a PC?
Not all CD players can or will play CD's burned in a PC. Sometimes the CD player is to old, so not compatible with these CDs. Sometimes the player just does not play these CD's, because of rights protection.
A CD burned in a PC is less reflective than an normal music CD. Normal CD's do have a metal coating and are highly reflective. Burned CD's have a dye, and where the laser burned the dye, it only changed colour. Making it less reflective.
All modern CD playes should be capable of playing CD r's. But the player that is really compatible, is labelled CDr and CDrw compatible.
May 13, 2014 | Bose Wave music system Multi-CD Changer...
Not playable bose
your car stereo and computer are more than likely able to play the files but the bose cannot because the music files are burned in MP4 format I believe. I'm not sure if iTunes can be converted to MP3 so it will play in your bose.
Nov 09, 2013 | Audio Players & Recorders
The CD player does hardly read self- burnt audio CDs although every one of my other cheap Players i have at home or in the car can read them.
The answer depends upon the age and precise version of your Bose system. Not all CD players can reliably read CD-R and CD-RW discs, and even those which do are sometimes picky about the brand of recordable disc in use.
In my experience, all of the Bose Wave systems I've worked on have contained surprisingly cheap/average parts inside considering the luxury price-tag. Either stick to using other cheaper (and often far better) CD players for CDs you've burned yourself, or look into getting the CD laser pick up inside your Bose replaced with one which is known to have no issues with CDs of different reflectivity to standard pre-recorded CDs.
Jul 06, 2011 | Bose & Wave& Music System
Burning CDs from MP3 downloads
Try Nero Buring Rom. Select audio cd and burn the music.
If you need further assistance please post.
Mar 15, 2010 | Computers & Internet
Can't play burned cds through bose
get a 3.5mm male to 3.5mm male cable(one end to the laptop headphone jack and the other end to the AUX jack of the Bose wave music system), you are good to go...
Jan 01, 2010 | Bose Wave Music System CD Shelf System
Bose lifestyle 48 says format unsupported for audio cds
Hi Johnxxlt,
According to Bose, the message that you have is due to dust in the system ....
They have offered 3 ways :-
Try cleaning the CD or DVD, as follows:
  • Use a soft, dry, lint-free cloth to remove stains or fingerprints from the disc surface
  • Wipe in straight movements from the center of the disc to the outside
  • Do not use any chemical cleaning products. They can damage the disc.
If the above will not fix the problem, you need to call them to repair the system.
I know its frustrating, However, we cannot play more with Bose as it might void the warranty if any.
Thanks for using Fixya.
Do rate the solution as "Fixya" if 100% satisfied.
Apr 17, 2009 | Bose Lifestyle 48 System
Bose 3-2-1 Home Entertainment System
it must be the lens....
try cleaning it with one of those "cleaning cds" that have small brushes on their surface...
Mar 17, 2009 | Bose 3 2 1 Series I DVD Home Entertainment...
I have used Musicmatch Jukebox for years to download and burn mp3s to a CD. I have always used CD-R CDs. All of a sudden when I go to play the CDs, they aren't compatible with the same players I've...
MUSICMATCH PROBABLY CONVERTED YOUR FILES TO A NEWER FORMAT LIKEACC OR MP4 , THE PLAYERS SOFTWARE IS NOT UPDATED ENOUGH TO PLAY THESE NEW FORMATS , CHECK YOUR MUSIC FORMATS IN AN EXPLORER WINDOW AND IT WILL TELL U WHAT FORMAT THE SONG IS. WE KNOW YOUR PLAYER WILL PLAY A WAV FORMAT, BURN A STANDARD WAV. FORMAT DISC ON THE SAME TYPE OF DISK AND IF IT PLAYS ITS THE ADVANCE FORMATS THATS YOUR PROBLEM.
Aug 11, 2008 | Computers & Internet
CD player won't play CDs burned on new computer
hi penguinxy.
try get a original cds if it works fine.the next time you burn cd try burn at 8x or low may be your cd lens is not detecting cds burnt at high speed.hope this helps..
May 10, 2008 | Jensen CD-2010X CD Player
240 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
