Question about Cell Phones
I can't set the phone's gprs - Cell Phones
I'd like to know what is the correct gprs for nokia n8 cell phone
The GPRS settings are not specific to your phone, they depend on your network. A good place to start is the attachment on this thread, which has all the settings for all the networks known globally.
Feb 15, 2013 | Cell Phones
Tip
GPRS Settings for Cell Phones
<span><span><span><span><span><span><b>Hello and Welcome to FixYa!<br /><br />General Packet Radio Service (GPRS)</b> is a packet-based wireless service used for sending and receiving data through the internet protocol. With GPRS, the transmitted data is divided into various 'packets' before it is received by the user.<br /><b><br /></b><br /><b>To use GPRS, users require:</b><br /> <ul> <li>A mobile phone that supports GPRS</li> <li>A subscription or upgrade, as relevant, to the mobile network that supports GPRS</li> <li>Some users would specifically require asking their mobile network provider to activate the GPRS while other network operators allow automatic access</li> <li>Knowledge of how to do data transfers on their specific model of the mobile handset as it varies depending on the models and brands.</li></ul><br /><b>Setting up GPRS for your phones:</b><br />Usually activating GPRS on your phones are done by the service providers, and different service providers have different configurations. Additionally, the settings for GPRS vary based on the different phones and phone models. As activation is required before setting up you should know that activation process vary from one provider to other. It could be as simple as sending an SMS to a particular number or calling customer care of that particular service provider. Once the activation is taken care of, the setting of the GPRS is done based on the model of the phone.<br />It is important to note here that the setting for GPRS is different for different phones companies and may be different even for the different models produced by these companies.Therefore, it is recommended that you rely on the information given directly from the service provider. Again activation process may be different for postpaid and prepaid customers. <b>So just call and demand GPRS settings for </b></span></span></span></span></span>your mobile<span><span><span><span><span> <b> </b></span><span><b>by the Service Providers, <span>They will send it free.<br /><br />Thank You For Using FixYa!<br /></span></b></span></span></span></span></span></span>
on Apr 28, 2011 | Cell Phones
Nokia x369 internet setting via mtn in uganda
Well it's simple first of all you need GPRS settings on your phone to get these settings you need to call costumer care of your service provider they will send you a message containing GPRS settings, all you need to do is just save these settings by followings option menu of that message. Once you save these settings then open internet browser on your phone and select the correct GPRS setting which is 'internet'. Post comments for further information..
Good Luck
Nov 08, 2011 | Cell Phones
How to connect gprs in nokia 5800d-1
Gprs on ''gprs compaitable handsets'' works only through specific gprs settings, the settings are different on every network. To activate gprs on your phone you should first get the gprs settings, then install and activate the settings as default. You should contact your service provider, they will send you the gprs settings, then do as i mentioned above. Rate my answer...
Oct 04, 2011 | Nokia 5800 XpressMusic Smartphone
It's on my Smart No. 09199634778. It received messages from Smart that I have MMS pictures. Can they be shown here?
Yes sir,to retrieve MMS data,you should activate you MMS/GPRS by configuring the settings of your network provider or Smart provider.
Here's how to Activate the your MMS/GPRS
Key in SET MMS and send to 211.
To download SMART GPRS phone settings:
Key in SET GPRS and send to 211.
Example: If you have a Nokia 6230, that's "SET MMS N6230"
To activate SMART GPRS:
Key in "GPRS ON" and send to "333′
To activate SMART MMS:
Key in "MMS ON" and send to "333′
Note :
The configuration settings will be sent to your phone. You will need to select "Save All" to save the settings in the phone. Some MMS and GPRS handsets already have pre-loaded phone settings.
Activation of MMS and GPRS will require a confirmation message from SMART. A message will be sent to the sub once the feature has been activated.
Hope this solution helps you. Thank you for visiting FixYa..
Jul 24, 2011 | Nokia N70 Smartphone
Cannot connect to pocket data and i cannot open my gprs in 5200 nokia!! tnx
hi! nothing to worry ! these are the simple steps to solve ur issue! there are two kinds of possibilities first from ur side and other from operator side! u need to activate gprs facility for ur num from the operator! activate gprs in ur num with ur phone with ur operator! ask the details to activate gprs in ur operator side! it will take maximum 48 hours to clear problem in operator side! that enables from the operator side to access gprs ! then coming to ur side problem! first clear all ur internet settings that u already received! then ask ur operator for gprs settings ( each operator has some msg code's to get gprs settings) then after received the settings set as default setting's by change in phone's browser setting's. then activate gprs plan based on ur requirement ! after the confirmation msg that after the activation of gprs! then switch off and ON ur phone! that's it! open ur phone's browser and start browsing! still hav problem try to call customer car number for ur operator! that's it! Rate me if u like!
Jul 17, 2011 | Nokia 5200 Cellular Phone
I like to open the GPRS in my mobile the brand is myphone i dont know how to do or what i need to do to access the gprs so i cant use internet in myhone,
It's very simple.
First, call your phone's service provider.
Ask them if your phone can support gprs (if you don't know that already)
If it's supported, ask them to activate gprs for your phone.
The activation will be done within 2 or 3 hours,.
Finally, you will receive a service message containing the gprs settings required to browse the internet on phone.
Thats it.
You're ready to surf.
But do confirm data transfer charges. They can be costly.
To start surfing, just open the phone browser, and enter the website you want to go.
Regards
Jul 05, 2011 | Cell Phones
Panu ako makakapag internet sa fone??? nagtry aq kea lang may kailangan pa atang configuration... manual daw??
Ano po bang model ang gamit ninyo? maaari po kayo mag internet sa phone sa papapagitan ng wi-fi o GPRS. Kung may wi-fi po ang phone ninyo,i-on lang po ito at pwede na kayo dumiretso sa browser. kung wala namang wi-fi ang phone ninyo eh kailangang ma-activate ang GPRS ninyo upang makapag internet po kayo.
sa pag activate ng GPRS, kung GLOBE po ang gamit ninyo eh automatic na pong matatanggap ang configuration settings ng nasabing GPRS,i-save lang po ito at ang may code pong hinihingi,ipasok lang po ang 1234 at pagkatapos i-save eh pwede napo kayong mag internet,basta may load po ang sim ninyo ok na po ito.
In SMART :
Here's a quick tip on how to activate your phone's Smart MMS and Smart GPRS settings if you're with the Smart network:
Download MMS and GPRS settings from Smart:
To download SMART MMS phone settings:
Key in "GPRS ON" and send to "333?
Key in "MMS ON" and send to "333?
Note :
In SUN CELLULAR
Activate your GPRS
Two ways to activate your GPRS:
1. Text ACTIVATE to 2300
2. Call 200 using your Sun phone or 395-8000 via landline, and a customer service representative
will assist you
Configure your Handset
Two ways to configure your phone:
1. Text SUN GPRS to 1200.
2. Manually configure your handset : CLICK MO AKO
Sana po makatungong...
Jun 23, 2011 | Cell Phones
Bsnl gprs setting nokia 5800
Hello and Welcome to Fixya
General Packet Radio Service (GPRS) is a packet-based wireless service used for sending and receiving data through the internet protocol. With GPRS, the transmitted data is divided into various 'packets' before it is received by the user.
Setting up bsnl GPRS for your phone:
It is important to note here that the setting for GPRS is different for different phones companies and may be different even for the different models produced by these companies.Therefore, it is recommended that you rely on the information given directly from the service provider. Again activation process may be different for postpaid and prepaid customers. So just call and demand GPRS settings for
nokia 5800 by the service provider, They will send it free.
I hope this solution helps you
Don't hesitate to let me know if you want any further assistance.
Thank you for using FixYa!
Apr 28, 2011 | Nokia 5800 XpressMusic Smartphone
Cell Phones Logo
124 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
