Washer fil with water then nothing happen after that
  • 487 Answers
Means your motor is broken normally. If you provide me with model and serial number please?
Posted on Aug 15, 2008
Wont fil with water
The screen on the water inlet to the machine may be plugged. Take the water hoses off at the machine end to see if there is a blockage. If that isn't it the solenoids that open the water valves may be stuck or not working. The timer operates the solenoids.
Jan 13, 2014 | Maytag Bravos MTW6600T Top Load Washer
My Roper top load washer stops in mid cycle and will not drain or do anything else
Most of the time that is lid switch failure. The lid switch must be engaged before the tub can spin. You can bypass the lidswitch to see if that is the problem. The lidswitch has 3 wires. 2 live wires and one ground wire which is green and bolted to the frame. Tie the 2 live wires together and see if the washer will work. You can use it that way but is could cause harm if anyone was to try and grab clothes out the tub while it is spinning full blast.
Sep 23, 2012 | Roper RAS6233KQ Top Load Washer
Dishwaher hobart amx 900-16 has fil displayed what does this mean?
fil massage mean the water not came in the booster tank , maybe the water pressure is low or the solenoid valve is defective, always this massage come to me i change solenoid valve then it will work, check and tell me
May 12, 2012 | Dishwashers
BHWD12 water leaking Washer-drier While not in use it slowly fils with water.
(pre-typed to cover hot and/or cold!)
This is symptomatic of a malfunctioning (not closing completely) water control valve
With power off, if it is hot AND cold fill, turn one or the other off and see which one is causing the problem. Sorry but it needs replacing and a service call ;-0(
If it's cold fill only it's clear which one!!
If is only happens when there is power on it could be the PCB malfunctioning and will require checking by the service call.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Oct 05, 2011 | Washing Machines
I'll find water in the tank when the washer is off. I will put it on the drain cycle to drain the water. Come back about 6 plus hours later to find water in the tank. Possessed washer?! Took apart the...
u prop need a new fil valve,, it the part that the hoses connect to on the back of the washer, u can remove the top three screws on back for top and acess the valve. if that valve is defective and not shuttting off then water will continue to enter.. hope this helps
Apr 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Stopped spinning from heavy rug
what is error, most likely plugged the pump
Apr 18, 2010 | Frigidaire Affinity ATF7000E Front Load...
Water fills the tub then nothing happens.
it does not aggitate? Thats the cycle that allows the water to wash the clothes. It may be broken, I have had that happen a couple times. I would take the aggitator off and see if the teeth in the groves are worn out, It happen's when used alot. Commen problem and easy to replace.
Apr 05, 2009 | Maytag Ensignia MAV2757AWW Top Load Washer
My washer wont run in the hot water cycle
Sounds to me like your water valves in the back are going bad, just had it happen on mine the other day, I bought one online for like 15.00 that was new solinoid valves for both hot and cold water. took about an hour to install with no instructions (take the old one out, new one hooks up the same way) or call the washer repair people.
Mar 18, 2009 | Whirlpool Washing Machines
Waher dont work
Check the top lid interlock switch. If the switch is bad or out of adjustment, the washer will not agitate or spin. This is a safety feature so no one can reach inside while the machine is running. To check if the switch is working, open the lid and SLOWLY close it,going as slow as possible when the lid is almost closed. Just before the lid "hits bottom", you should hear a CLICK sound. This is the lid switch actuating. If you do not hear the click, the lid interlock switch needs replacement or adjustment.
Aug 09, 2008 | Washing Machines
Smeg washer/dryer not filling
Check the pressure switch, aka water level switch. If this isn't the problem, it may be the water valve.
Mar 26, 2008 | Washing Machines
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
