Question about HP Officejet 4355 All-In-One InkJet Printer
Catridge error : not printing - HP Officejet 4355 All-In-One InkJet Printer
    Genius:
  • 1,127 Answers
Hi
If your cartridge error is coming then please replace your cartridge and or buy the new cartridge in Hp Service Center.
Posted on May 21, 2011
I receive the hp catridge print error message when I refilled both the catridges. Thank you.
So now you need to download the utilities from www.hp.com......the one you will need is the printer printing utilities ...this helps clear printing errors.....(Drivers and support should be what you looking for...)
Apr 06, 2011 | HP Deskjet F335 All-In-One InkJet Printer
I cant print and get error message 1203 on my lexmark p315 model:any idea wat that error message is?
t's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge. I have the same problem which I think lexmark have a proble and overlook.
Solution:
I use the klennex with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of klennex on those holder contact panel.
Too bad that I also cound not find out how to reset the ink indicator. It's annoying to hit the OK button every time you want to print.
Try and see if it's work for you. Good luck......
Dec 22, 2010 | Office Equipment & Supplies
I was printing on my printer with no problem when in the window of the printer it shows cartridge error,error 1203.I checked the cartridges and they look fine.I took them out and put them back in I...
It's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge.
Solution:
The refill ink works very well if you let it sit 24 hrs. Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Try and see if it works for you. Good luck......
Oct 30, 2009 | Dell Photo 964 All-In-One InkJet Printer
Cartridge error
Error 1203 is a very interesting error which normally means that your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges.
Solution:
To reset the error code, disconnect the power cord from the wall. Also remove the power brick from the back of the printer for 60 seconds. Then connect everything again.
Please let me if this information helped.
Please rate me if you are haapy with the solution.
Sep 15, 2009 | Dell 946 All-In-One InkJet Printer
Error 1203 is a very interesting error code. Here is what I found out about error 1203
Error 1203 is a very interesting cartridge error. It means your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the cartridge
Solution:
Hope this helps and please feel free to rate me
Sep 12, 2009 | Dell 942 All-In-One InkJet Printer
Error 1203 printer not working
Here is what I found about the 1203 error in the dell community site.
It's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge. I have the same problem which I think lexmark have a proble and overlook.
Solution:
Jun 16, 2009 | Dell 946 All-In-One InkJet Printer
No print catridge error showing on display
plz remove the catridge and reinstall the catridge properly then uninstall the printer driver and restart the system then after restarting the system then reinstall the printer driver and restart the system again then after restarting the system check
Jun 01, 2009 | HP LaserJet 3050 All-In-One Printer
Hi, is the cartridge NON genuine. If so, it may be damaged in such a way that the printer is not recognising the cartridge. Try putting your old cartridge back in and if the problem goes away then the problem is the cartridge and not the printer
Jun 21, 2008 | HP LaserJet 3055 All-In-One Printer
Error 1203
  It's mean your catridges overflow even from brand new catridges. After  several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge is located.
Solution:
 use  kleenex with a few drops of water to dampen and clean off those contact on the holder.
The refill ink works very well if you let it sit 24 hrs. Then before you print anything, you should run align  catridges a couple times then run clean catridges a couple times.
Print the test page to see how it  looks and away you go.
Oct 29, 2007 | Lexmark P4350 All-In-One InkJet Printer
HP Officejet 4355 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
