Need the modem driver cant connect without it can download on other pc to boot the one i need driver if u could send me a way to download right one.........thanks
    Genius:
  • 1,127 Answers
Hi
Give me the Modem model no then its possible to help you.
Posted on May 21, 2011
Where can i get a network adapter device driver?
Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ?
you will need to update or install the driver or it could be firewalled.
Make sure your antivirus program is not blocking the internet connection.
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers.
The driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
You only need to check the BIOS if you cant install the driver
Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its
"Enabled"ima
Click start type cmd press enter you will be in DOS mode
type in ipconfig press enter you will see all of your internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138
or you could download one
http://download.cnet.com/driver-complete-rar/3000-2112_4-210081.html
http://download.cnet.com/802-11b-g-Atheros-Wireless-Lan-Driver-7-1-0-90-zip/3000-2112_4-162108.html
if these drivers are not right
http://download.cnet.com/2000-20_4.html
on the homepage you will see a search bar type in you want/need HP network driver
Aug 21, 2013 | HP Pavilion a1610n PC Desktop
I need the sim unlock pin code so i can switch over to Tmobile without getting a new phone.
Hi, You can get the unlock code for a Huawei U8652 Fusion from www.unlocking4u.com/huawei-fusion-u8652/rs6wp9/ at affordable cost.
Here are the steps for unlocking a Huawei U8652 Fusion,
Method 1:
This method requires your PC to have a software called Hyperterminal which can be found on the Start Menu in Windows XP, 2003 and other older versions of Windows:
Start - > Programs -> Accessories - > Communications - > Hyperterminal
1.Remove all other modems, printers and other devices connected to your PC other than your monitor, keypad and mouse.
2.Start your pc, connect your USB modem and open Hyperterminal.
3.Enter any name and select any icon and click OK to continue.
4.Set Connect using to your modem port, Huawei Mobile Connect - 3G Modem or the right COM port.
5.In the properties window that opens, without changing any values, click OK to continue.
6.Type the following command(replace the word UnlockCode with the unlock code we sent you):
AT^CARDLOCK=UnlockCode
and press enter.
7.Your modem should now be unlocked. Close Hyperterminal, disconnect your modem and connect it again.
Method 2:
Use this method if Method 1 does not work or if you are not able to follow method 1.
If your PC does not have Hyperterminal or if your using Windows Vista or Windows 7 you can use the following method.
1.Download our Modem Communicator Application. This application has been scanned by Mcafee and contains no virus. For your safety, please scan the application again after you download it.
2.Switch off your PC, remove all other modems, printers and other devices connected to your PC except your monitor, keypad and mouse.
3.Start your pc, connect your USB modem and open the application you downloaded(mc.exe).
4.Click on the Check for Ports button and wait for the response.
5.Click on the Check for Modems button and wait for a response.
6.Click on the Send AT Command button and make sure you get the response "OK".
7.In the text-box next to the Send User Command button, type the following command(replace the word UnlockCode with the unlock code we sent you):
8.Click on the Send User Command button.
9.Your modem should now be unlocked. Close the application(Modem Communicator), disconnect your modem and connect it again.
Sep 22, 2012 | Huawei U8652 Fusion Blue/blackandroid In...
I want 7339 modem drivers
contact me prajwal_yes@yahoo.com
Jan 23, 2010 | LG KP200 Cellular Phone
I need to download the ethernet drivers for the computer to detect the modem i cant connect to internet and i would like to know how to install the ethernet drivers without using the internet
If you dont have a manufacturer disk driver cd its difficult
you will need to download it in a cybercafe and load it on the machine
Use driverguide.com to download the driver.
Nov 13, 2009 | Compaq Computers & Internet
Dell Inspiron 2200 cant connect to internet
go to support.dell.com and download the modem driver to an external media (cd, thumb drive, etc.).
then right click 'my computer' and go to properties then device manager. you should be able to go to the modem and update the driver from a specific location and then point it to the external media you have downloaded the driver to.
Jul 11, 2009 | Dell Inspiron 2200 Notebook
Cant access internet without network adapter operating
You can download drivers at
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_P4_8400&os=WW1&osl=en&catid=&impid=
If internet is not working , then u might have received a CD with when u first got ur system, it has all the drivers that ur looking for.
If u cant find the CD, then contact Dell Technical support, they will send u one free of cost.
May 24, 2009 | Dell Dimension 8400 PC Desktop
Hi how did you solve the problem pls? i ve
it looks like u have to install Drivers on ur PC
if its a microsoft driver go to microsoft.com softwaredownload
and download the driver you need for ur pc
you can find this
MY computer icon | right click | properties
then hardware | devicemaneger | network adapters | see witch ones ur using that should take care of it
ps. you can download in to a CD for a later date it dose happen sometimes good luck
,July
rate me please
Apr 11, 2009 | Computers & Internet
Do I need drivers for my Modem
install the chipset driver from the dell drivers and utility cd if you cant find it there go to support.dell.com and enter the service tag number and go to the drivers download page and download the drivers..it should fix..hope this helps.
Regards,
Khushroo
Mar 11, 2009 | Dell Dimension 3100 PC Desktop
Hp dx 2300 microtower
when you had the internet installed, did you install the modem software for the modem? without the modem software, the modem cannot find the pc. if the modem connects directly to the pc, or even through a wired/wireless router, the modem software is a requirement. (i just went through all this myself w/ att dsl). if you have, or add, a router, that software will also need to be installed for those on the network to connect to the internet as well.
Nov 29, 2008 | Computers & Internet
Dial up modem cannot connect..
you need to download the right modem driver for your system. i have been trying to locate it for you but sadly, i cant read japanese
Apr 08, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
