Question about Linksys Wireless-G WRT54G Router
Whenever I connect the router it says no internet access....
  • Linksys Master
  • 32,281 Answers
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards in all the laptops/computers needs to be configured withthese router's wireless settings. Then the laptops/desktop computers can communicatewith your wireless router and access the Internet via the DSL or cable modem.
Posted on May 21, 2011
My laptop wont stay connected to the internet
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
Jan 27, 2012 | HP Compaq nc4200 Notebook
I want to locate my wi fi password for my iphone.
I am assuming that you are trying to connect to the internet using the built in wifi instead of the 3G. To clarify, iphones don't have passwords for wifi. Wireless access points and wireless routers are the ones that have passwords. If you want to connect to the internet using an access point or router you must get the SSID of the router or access point and also the encryption and password to join said access point or router.
Once you have this information go to your iphone and select the settings icon. Then select the Wi-Fi, then turn on the wi-fi (if it is off), then under choose a network select "Other" and then type in the name (which is the SSID), tap on "Security", select the encryption that matches your access point or router (wep, wpa, wpa2, etc) tap on "Other network" (on the top left hand corner) to go back to the configuration page, and then type in the correct password.
Once you have done this your iphone will automatically connect to the access point or router whenever it is in range and connect to the 3G when it is out of range of the access point or router.
Hope this helps.
Aug 03, 2011 | Computers & Internet
Are the lights suppose to be flashing
The WAN lamp should blink whenever you are accessing the Internet.
The WIRELESS lamp should blink at a fixed rate.
Each of the LAN lamps should blink whenever that computer is accessing the Internet.
Sep 17, 2010 | NetGear WGR614 Wireless Router
Hi I am using ASUS router rt-g32 . whenever I connect my inernet via ausu it is not working but through ADSL modem internet is working fine. please help.I have reinstall and instaleed software of ASUS...
My asus rtg32 wifi wireless router is not getting connected to net. It shows connected (router with laptop) but its not connecting to net. I am not able to openany site. I m using BSNL connection. It shows no internet access.\r\n
Please suggest me what to do, what procedure to follow. Mine is windows 7 , 32bit OS
thx
shubham
shubhamformeATgmail.com
Aug 14, 2010 | ASUS RTG32 Router
Whenever i am using wireless, my internet will shot down. How can i fix this problem? thanks.
With the wired connection is it working fine ?
If yes and if you have only problem with the wireless connection then try to upgrade the firmware of the router.
Firmware is the software of the router.
Download the latest firmware of the router. Go to the manufacturer's web site and download the firmware of the router.
Open the set up page of the router and upgrade the firmware of the router. Once you upgrade the firmware of the router, reset the router.
On the router you will find a small reset button, hold it down for 30 seconds. release it. wait for 1 minute. Now unplug the power to the router and plug it back in.
Now you will need to reconfigure the router according to the Internet service provider.
Apr 17, 2010 | Linksys Wireless-G WRT54G Router
Don't have internet connection
This particular 8-port Ethernet switch/hub has auto-negotiation on both speed as well as MDI, MDI-X.  Therefore, the problem is not with your switch/hub, it's probably with the particular port that you're connecting it to on your Router.  Make sure that it's the LAN side, not the WAN side.
Mar 14, 2009 | Cnet CSH-800 8-Port Ethernet Switch
No connection to internet
First thing you need is to run the set up disk that you should have received when you purchased modem. It should run you through the steps. This should also allow you to set up your wireless connection also. It should also provide you the access code for your wireless security. Basically what this does is prevent unauthorized access to your network. Whenever you add additional computers you will need to set up each individually and enter access codes. If you don't have a disk you might need to contact manufacturer to get a replacement disk. Good luck.
Oct 18, 2008 | Encore 802.11G WIRELESS LAN ROUTER...
Dynex Router problem
You should first verify you have a internet connection to your computer directly from modem. If you do then turn your computer off unplug modem from power supply and remove ethernet connection. Then with cable only attached to modem plug in power supply. Allow enough time for modem to boot completely up. Then plug ethernet back into modem and the other end into router. Then power up router. Allow adequate time to router to sync up. If you never set up your router initially with all security features and access codes for wireless you may need to run set up disk. If this was all previously done then power up computer go to CONNECT TO option on START menu. Your wireless network should be listed with the name you gave it. Select your network. If it is a secured network it will ask for access codes. Enter the codes and you should be able to access internet. If not you may need to run set up disk again or contact manufacturer of router.Good luck
Oct 13, 2008 | Computers & Internet
Internet sharing problem
its actually a WEP key, this wep key is saved in the route setup page. if you cant remember what the WEP key or the password for your wireless network, then you can access the setup page of the router and check if from there. go to this link to know how to do that in your router. click here.
George,
With regards to your concern there is big possibility that your rotuer is not yet configured properly for internet connection. Can you tell me who is your internet service provider and the model no. and brand of you modem? So that I can give the steps on how you can get the router online.
Jun 05, 2008 | Computers & Internet
Linksys Wireless-G WRT54G Router Logo
85 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
