Question about Refrigerators
Hi just wondering if you new how to fix my CTD 78 desk refrigerator it constatly runs it does cut out at all it just wont turn off any ideas or solutions many thanks
3 Suggested Answers
  • 3422 Answers
SOURCE: Refrigerator Problem
HI,
I suggest you to repeat the same process again.If the problem comes back again after 48 hours then start checking your defrost heater and defrost thermostat, you will need a volt/ohm meter.This process will require to remove the back panel to troubleshoot.The best solution is to get this repaired.
Posted on Oct 13, 2008
heatman101
  • 43501 Answers
SOURCE: The frezzer and refrigerator stop staying cool.
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Apr 27, 2010
I have a honeywell focus pro 6000 temp in house doesnt change unit runs constatly. thermostat says 78 thermomiter on other end of house says 72. changed batteries
It's possible you have a lot of dust build up inside the stat. If it has batteries remove face from wall and blow out. Take outside to see if temp will change. Plug the hole in the wall where the wire comes through. If all fails, replace. Turn power off, take wiring picture, replace, turn power on. Good Luck!!
Apr 30, 2017 | Honeywell Heating & Cooling
I have a 1995 gsxr750ws the oil and neutral lights work but no indicators,lights,horn & wont start.I have a new battery.I used a screwdriver across starter solenoid and turnsover.Anyone got any ideas?
Hi, Stuart and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Tip over sensor needs a reset.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://www.cycleforums.com/forums/78-help-me-fix/231092-94-gsx-r-750-wont-start.html
What to do When Your Motorcycle Won Start
Suzuki 1996 GSX R750 Service Manual
OEM parts for Suzuki
http://mybikemanuals.com/suzuki/suzuki-gsx-owners-manuals
Mar 15, 2017 | 1995 Suzuki GSX 750 F (Katana)
I have a Samsung rs21!!! it wont cool in either compartment. when I plug it in the compressor fan does a quarter turn then stops. the compressor runs for about 30 seconds then cuts out? any ideas plea
most likely the start relay on the compressor that changes from start windings to run windings. the compressor will run for about 30 seconds on start windings then click out on internal thermal overload.
this can be confirmed by turning it on and letting it do the 30 second run then when it stops just wait and see if it cuts in and tries to run again (usually takes about 5 min) the second time it cuts in it wil most likely not run for as long (usually about 10 seconds). if this is what it does get a new compressor start/run relay.
as for the fan flick it with your finger and see if it spins freely.
Jun 05, 2014 | Samsung RSA1SHPN American Platinum Inox...
Punctured inside bottom of chest freezer, now it wont work. how can it be fixed?
Sorry, but you punctures a refrigerant line and the system lost the freon...
To fix this the bottom would need to be cut out of the freezer and then the lines fixed and the system recharged...
Considering the cost of a new freezer... you will be better off to replace the freezer rather then doing that much work to it..
heatman101
Mar 12, 2011 | Refrigerators
Compressor on my Rs2577sl can't kick in but in a constat try to do that with a little clicing noise every 10 or so minites. I've changed the overload with no results. Do I need to by a new compressor at...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 05, 2011 | Samsung RS2578BB Side by Side Refrigerator
We have a Goldstar portable AC. It runs fine but
Refrigerant leak.....not worth fixing.. will cost more then a new one...
Here is a tip for other things you can check first....
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 27, 2010 | Heating & Cooling
WONT TURN ON
Most laptop batteries die from being left plugged in to power all the time. It's a good idea to run it from battery as much as possible.
Try removing the battery and running it on the power supply only. If this works you need a new battery.
Apr 07, 2010 | Apple MacBook PC Notebook
I have a Hewlet Parkard desk top that bleeps
dv2000/dv6000/dv9000 recall I have an out of warranty dv9000 and haven't had wireless for months. I just discovered HP issued a recall for the wireless and other problems with several different Pavilion and Presario models. For the wireless problem with the dv9000 they are replacing the motherboard on all notebooks in or out of warranty. I was wondering if anyone has had the repair done under the recall and how it turned out? I'm also wondering if HP is still cosmetically trashing notebooks when they are sent in for repair?
Here is the link for the recall:
http://h10025.www1.hp.com/ewfrf/wc/d...842189&lang=en
Nov 01, 2009 | HP Pavilion dv9000z Notebook
Refrigerators Logo
94 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
