Question about Lexmark X646e Laser Printer
My printer show in display paper jam in back door but there are not paper here. I took out the fuser unit and there not paper jam. thanks
  • Lexmark Master
  • 1,915 Answers
There are two flags on the back of the fuser, make sure the are moving properly and that the sensor itself has not been knocked off.
Posted on May 21, 2011
Testimonial: "Excellent my friends, the sensor in fuser unit was dirty with black toner.You is the best guru!!! Thanks so much.."
How do you remove fuser
->Turn off the printer and remove the power cord. Allow the printer to cool off for 30 minutes to an hour before attempting to work with the fuser. The fuser gets very hot while the printer is in use, and you can be burned if you touch it before it cools.
->Press the release lever on the side door to open it. Pull down the fuser lever so you have room to grab any jammed paper.
->Pull the jammed paper out of the fuser unit. Hold the paper at its lowest point and pull downward. Flip the fuser lever back up and close the side door.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Nov 16, 2012 | Office Equipment & Supplies
What is "fuser door open"
Fuser Door Open is the message on the display when it's powered on. I took the back apart, removed the fuser, looked all over. I couldn't see any kind of sensor, optical or mechanical that makes when the door is closed. There's an access plate with a blue latch below the fuser that makes an optical sensor and a mechanical sensor, but that seemed to be OK. It didn't seem like something that would be called a fuser door. So, I pushed on it where it made the mechanical switch and the printer hummed to life and the message went away. I took the fuser out and examined it. The metal brackets where the pivot parts were, seemed a little bent. I straightened them out, stuck it back in and that fixed it.
By moe who hasDell MFP 1850DN this might also help...
or Fuser Door Open
1. Make Sure the Paper Tray is Loaded Correctly With no Obstructions
2. Clear the Paper Jam in Tray 1 or 2
3. Clear the Paper Jam in the Multi-purpose Tray
Jul 05, 2011 | Dell 1815dn All-In-One Laser Printer
I have a paper jam in the back of the machine how do you get the paper out?
open the back door,see where paper jam,could be wrapped around fuser.if no jam,fuser or output sensor faulty.
Jul 07, 2009 | Samsung SCX-4828FN All-In-One Laser...
Paper Jam
Good day, Check the table below about the problem of paper jams.
Display and Meaning
[Paper Jam 0] - Paper has Jammed in the feeding area of the paper input tray.
[Paper Jam 1] - Paper has jammed in the fuser area or in the manual feeder.
[Paper Jam 2] - Paper has jammed in the paper exit area.
hope it will help you.
Jun 04, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Printer now not printing, as it says there is a paper jam
it sounds as though your pick up rollers are worn. when the oprinter can not pick the paper from the selected tray (tray 2 in your case) then it shows up as a jam. to sort this you will need:
One of these: RM1-0036-020: PAPER PICK-UP ROLLER ***'Y
Two of these: RM1-0037-020: PAPER FEED ROLLER ***'Y
Hope This Helps
Pete
Oct 30, 2008 | HP LaserJet 4250n Printer
Error 13-jam paper HP Laser 4+
HP LaserJet 4, 4m, 4 Plus and 4m Plus Series Printers - False Error Message 13 PAPER JAM ISSUE: After clearing all jammed paper from the HP LaserJet 4, 4m, 4 Plus, or 4m Plus series printer, the display still reads 13 Paper Jam . Even after cycling the power off and then back on, the error remains. SOLUTION: Open the rear door of the printer. There is a paper sensor near the upper right hand corner of the fusing assembly (just below the right edge of the long yellow warning sticker on the fuser) that can cause paper jam error messages even when there is no jammed paper in the printer. Toggle the thin black plastic lever up and down to make sure it is not stuck or sticky. The lever should be in the down position before closing the back of the printer. If the lever is stuck or missing, the printer will generate a false paper jam message. Hope it will help you !
Apr 02, 2008 | HP LaserJet 4 plus Printer
PRINTER SAYS PAPER JAM 23 ..
Hi there have you tried the door at the back of the machine as there maybe a piece stuck in the fuser unit. If not open the back door and check that there is a small black lever in the middle of the two rollers sticking up as this is the sensor arm that determines that there is a paper jam or not. If this is still there then the paper will be stuck just after the paper cassette within the paper path.
Hope this helps you.
thanks J
Jan 11, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Paper jam 202 with no paper in printer
This jam is refering to back door, jam in fuser (hot bit) Double check no paper is wraped around fuser rollers.
These machines have a fuser at rear if you look at he fuser from the back, on it you will see, two thick fuser rollers (ones rubber), paper runs threw these then it hits a little black switch (your machine thinks this switch is activated) and then a series(3,4) of small rubber exit rollers, this switch (between middle and left) can get damaged it also likely that a piece of paper is concertinaed in fuser.
Also remove print cartridge and look behind it, if this machine has duplex unit installed you will need to lift it off that first to axcess all areas.
Check all doors are shut.
Nov 13, 2007 | Lexmark T642 Laser Printer
Media Jam- Fuser
thx m8. Media jam: Fuser i had...
new there was no paper jam so looked about for the sensor and found that the little arm thing that gets liffted up as the paper pass was not falling back down so it thought the paper had jamed. i just took the back panal off and put a small bit of soft foam under it so it always got pushed back up.
works a treat now.
thx again
Oct 02, 2007 | Konica Minolta magicolor 2430 DL Laser...
Paper Jam
The fuser unit has a pape sensor. If, for some reason, the sensor is stuck, the printer will read a paper jam. Open the rear door and inspect the paper sensor located in the fuser assembly. See if it came out of it's original position or if there is something blocking it from moving freely. Good luck.
Aug 23, 2007 | Lexmark Optra T610 Laser Printer
Lexmark X646e Laser Printer Logo
50 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
