Question about Samsung CLX-3160 All-In-One Laser Printer
How do i clean printer head for 3180 printer - Samsung CLX-3160 All-In-One Laser Printer
I want to check out my Wertheim 3180 my daughter borrowed @ it has lost a lot of suction filters are clean
If the filters are clean, try removing the hose from unit whilst switched on, if the sound changes then you may well have a blocked hose or tube
Jan 12, 2015 | Vacuums
The colours arent comming out the same as i wanted despite the cartridges are new
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts.
Jul 26, 2011 | HP Photosmart 3180 All-In-One Printer
C3180 will not print every thing elase is fine
This issues looking printer head problem. check the following Steps for cleaning printer head :
Click on the Start button if you have Windows XP. If you have Windows Vista, click the Windows icon that resides in the lower left corner of your computer screen.
Click on "Control Panel," then "Printers and Other Hardware." Finally click on "View Installed Printers or Fax Printers."
Right-click on the name of your printer and choose "Printing Preferences." This should open a new window; next look for a tab or button marked Maintenance, or something similar.
Find the button that says "Print heads" or "Clean the Print heads" and click on it. You may be asked to choose which print heads; choose them all if you are. Make sure there is paper and ink in your printer, and that it is turned on ahead of time.
Take out the page your printer has printed and see if there are any grids or boxes missing. If there aren't, then you can just exit the program--your print heads are not clogged. If there are grids missing, then click on the "Cleaning" or similarly worded button.
Once the cleaning process has completed, print another page to be sure that your print heads are no longer clogged. If they are still clogged, repeat Steps 1-5 until your printer is printing clearly.
Oct 26, 2010 | HP Photosmart 3180 All-In-One Printer
I Need Owners Manual for Photosmart model 3180 can I download 3180 owners manual ?
Yes, here you have the Basics Guide and the Setup Guide
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=1146331&lang=en&
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
Thank you
TechSaver
Feb 08, 2010 | HP Photosmart 3180 All-In-One Printer
Black cartridge not detected on my hp 3180 printer
i think you need to clean you black cartridge and your printer is olso need a clean
i hope i can solve your problem
Aug 31, 2009 | HP Photosmart C3180 All-In-One InkJet...
HP 3180 BLACK IS PRINTING LIGHT
Call HP.
There is an un-acknowledged issue with these printers having problems like that ....
They end up replacing some big parts inside it.
Jun 16, 2009 | HP Photosmart C3180 All-In-One InkJet...
My HP 3180 printer/scanner will not scan. It will print. What can I do?
Go to HP.com and download the latest drivers for your scanner. When asked where to save the drivers, chose DESKTOP. Then you must go to CONTROL PANEL uninstall the old HP files. then go to your desktop and install the new drivers. This should take care of your problem as long as there insn't amechanical problem with your scanner.
May 21, 2009 | HP Photosmart 3180 All-In-One Printer
Reinstalled printer
Download software for your printer from HP website
Apr 30, 2009 | HP Photosmart 3180 All-In-One Printer
Samsung CLX-3160 All-In-One Laser Printer Logo
414 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
