I dont know if I have everything hooked up right or not, I thought I did, but when I turn on the car to power the amp to the subs the subs just start giving off a loud constant bass that is to no music or anything. So I was wondering what could be the problem
    Sergeant:
    Champion:
  • 319 Answers
You might check the grounding connections where inputs of amp are connected. Sounds like you have an open (unconnected ground) circuit
Posted on Aug 15, 2008
Can I hook two 12in. Subs up with a 1100w amp. Sony explode, pioneer subs
Yes....hook one up to the left channel and one up to the right.....once everything is wired up.....keep gain down on amp and turn stereo on.....turn up stereo with amp gain down to right before high end speakers start to distort......then while its playing, turn amp gain up about 1/2 way. close your trunk and hop in drivers seat....sound gd????? You might have to adjust level on amp and bass on head unit to taste.....Be careful though....pioneer subs are only rated around 300 watts continuous.....dont want to blow them...gd luck....
Mar 20, 2012 | Pioneer Car Audio & Video
My amp won't play bass everything is hooked up
I have a similar problem with my 2012 civic, I hooked up my 1800w kenwood mp to my 2 12" w6s and 1 song plays and sounds great, the rest of my songs have no bass from the subs, just the car speakers sound normal so I dont know what the hell thats all about. I thought it was a wiring issue but I can play the one song all day and it sounds perfect so any suggestions? thanks in advance
Jan 29, 2012 | Sony Car Audio & Video
No sound
ok if u have a radio with sub controll make sure its on an make sure that you have the gain bassboost turned up an if it has a crossover switch make that its on
Jul 24, 2010 | Jl Audio 1000/1 Car Audio Amplifier
The main problem I have having is I am getting power to my AMP but no power to the subs. I tested my AMP and subs in another car and everything worked so I know my hardware all works fine. I had someome...
okay , well you need to make sure all your conections are in the right spots, and that your IN LINE FUSE, between your amp and battery, the big glass one is not burnt, just take a look at the metal piece inside , if its a sold metal piece its good, if its burnt in half like a broken bridge it needs to be replaced. the next thing is the fuse on your amp, you need to make sure it is not burnt also. Check your remote that it is hooked up to the right wire. then check that your sub/speaker wires are connected properly and secure. YOUR GROUND WIRE IS HUGE HERE also. MAKE SURE IT IS GROUNDED TO A GOOD SPOT, YOU MAY HAVE TO MOVE IT AROUND A FEW TIMES TO FIND A GOOD GROUND!!!! if you check all of these things, it should work fine.. you can fiddle with your amp and bass settings levels. turn em up so when it works you know it, but not too much you dont wanna blow nothing :)
Mar 12, 2010 | Car Audio & Video
Amp burned out but fuses still good?
this is caused by inproper wiring from the speakers/subs to the amplifier.. an amp will still put out power to subs and speakers when it's wired improperly but it won't last for very long doing it... 6 months is longer than usual....
Dec 05, 2009 | MA Audio M1900XE Car Amp
The light comes on but little sound comes out
theres a chance you may have blown up the amp. never put a sub that is to strong for the amp because its pushing all of the energy out of the amp to power up the sub, causing the amp to blow a fuse or the channels, on the back there is control of frequency turn everything all the way up to see if you can even get it to thump hard but dont blow your sub if it pops turn down some stuff and check the head unit to where its fading to the front or rear and balance to left or right
Jul 27, 2009 | Legacy LA1478 Car Amp
Help asap
hook blue wire to ur radio to amp remote
Feb 12, 2009 | Sony Car Audio & Video
One speaker is working more than the other
I would replace the wire your sub is hooked up to and try hooking up the sub that was sparked to the opposite channel on the amp to make sure the amp is not the culprit. Also switch RCA cables L to R, R to L
Feb 02, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
I bought a 500/1 jl audio amp and also a w7 10 sub
if its cutting off and right back on then check your ground and your power wire makes sure both are connected good and none of your fuse's are blown, either that or you got a wire hooked up backwards in the sub.. but my guess is that the sub is hooked up wrong... that sub should be hooked up in a series or in parallel,
ok if your running just one speaker, it should be hooked up like this and 2 speakers are a different way...
this is parallel :pos to pos , neg to neg, then one wire coming from pos on sub to pos on amp then neg on sub to neg on amp but bridge the amp on your amp should be 2 pos and 2 neg in two different channels take the pos off the sub into the pos on 1 channel and then the neg from sub to the neg on the other channel,
this is series : on the sub it will go pos to neg then the other neg and pos will go to the amp, but make sure the pos and neg r on different sides of the sub, dont hook them both to the same coil
if your need more help give me your email and ill send you a pic of how to do it...
Aug 12, 2008 | Jl Audio 500/1 Car Audio Amplifier
Subwoofer Output Not Working...
first check that the subwoofer function on the actual head unit is turned up,second check that the gain on the amp is at bout half way then check that it is on a lp (low pass setting)
then check that the boost on the amp is turned up.
please leave feedback.
cheers
Jul 02, 2008 | Eclipse CD5405
 Grubhead
Grubhead
