We re-filled the toner cartridge and re-installed it, but the red light indicating toner low keeps blinking, also the computor is telling us toner is low
  • 3,940 Answers
Just refilling the cartridge may not resolve the low toner message. Many cartridges have a sensor chip that must be reset to clear the message. Due to this, many people opt to buy replacements or refurbished cartridges that have had the sensor chip reset.
Posted on Aug 15, 2008
When printer is turn on that time printer reddy and cartridge light on so what is the problem
You can see four LED's on control panel, from top to bottom,1st is toner indication 2nd Attention 3rd is Ready light, 4th go light.. Observe led's are 'blinking' or 'On' condition.. # If toner light is blinking ="toner cartridge missing or contact problem or memory faulty.
# If toner light & ready lights are on= "toner low indication or refilled cartridge loaded".
Jul 12, 2012 | HP LaserJet P2015dn Printer
RED LIGHT KEEP BLINKING ON MY ML-2510 PRINTER IT STILL WORKS , WHY?
A red blinking light on a samsung printer will often indicate that your toner level is low. It will still continue to work until the toner fully runs out. This is Samsung's warning saying that you should think about changing your cartridge soon. I hope this helps.
Sep 08, 2011 | Samsung ML-2510 Laser Printer
Red light
Error Red On
• The cover is open. Close the cover.
• There is no paper in the tray. Load paper in the tray.
• The printer has stopped printing due to a major error.
• The toner cartridge is not installed. Install the toner cartridge.
• Your system has some problems. If this problem occurs, contact your service representative.
• The toner is totally exhausted. Remove the old toner cartridge and install a new one.
Error Red Blinking
• A minor error is occurring and the printer is waiting for the error to be cleared. When the problem is cleared, the printer resumes printing.
• The toner cartridge is low. Order a new toner cartridge. You can temporarily improve print quality by redistributing the toner.
Aug 03, 2011 | Samsung ML-2851ND Laser Printer
When the red light blinks on the printer what does it indicate-model-xerox phaser printer 6110
The blinking toner cartridge is low. Order a new toner cartridge. You can temporarily improve print quality by redistributing the toner. See "Redistributing Toner" on page 5.2
from the manual online as pdf: http://download.support.xerox.com/pub/docs/6110/userdocs/any-os/en/Guide_XP.pdf
Apr 06, 2011 | Xerox Phaser 6110 Laser Printer
The top light of the two is flashing green/red back and forth very fast and the light on the bottom is a solid red. how do I fix this so that way it will work normally
The steady lower light indicates the unit needs a new toner cartridge, MLT-D108S. Did you previously see this light blinking or blinking rapidly? (Those indicate the toner being low.) Replace the cartridge and check for any other error lights. Turn off the machine and let it cool. Then open the front cover and pull the old toner cartridge. Open the package with the new cartridge, remove the packing tape and paper that protects the cartridge and gently shake it (avoid touching the blue or green parts of the OPC drum). Press the cartridge into the slot until it is fully seated. Close the front cover.
The green/red blinking power light is not one I'm seen before. The printer indicates a non-toner failure (open cover, no paper, LSU failure, etc.) with a steady red light.
Aug 02, 2010 | Samsung ML-2240 Laser Printer
Toner light keeps blinking
The inkjet uses ink, not toner. When the light is blinking it indicates something is wrong with one of the cartridges, such as can't find it, not installed, out of ink, improperly installed, printer has died. First thing to try is to disconnect the power (not just power off) for 5 - 10 minutes and reconnect. If that does not resolve it, inspect the cartridges and reinstall them. If you have another printer that uses the same cartridges, try the cartridge in it. if not, get another set of cartridges and install them. If none of these steps resolve the problem, chances are that the printer is the problem and is probably not worth spending additional time on it.
May 03, 2010 | HP DeskJet 810c InkJet Printer
AFTER RELOADING TONER INTO CARTRIDGES, THEN RED LIGHT BLINKING AND IT WILL NOT PRINT. WHAT CAN I DO TO FIX THE PROBLEM?
Did you change the chips in the cartridges after you filled them with toner? Inside the cartridges are chips that the printer keep track of the number of images that are printed. After so many pages, the printer marks the cartridge as empty, even if you fill it with toner. When the cartridge is changed the printer reads the serial number on the cartridge and keeps a log it its memory. If the chip is replaced, then the printer does not recognize it and thinks it is a new cartridge.
Hope this helps.
Apr 30, 2010 | Samsung CLP 300 Laser Printer
Samsung printer ML 2510 series
Maybe the toner is low... According to the manual, a blinking red light:
printing.
page 8.3.
and install a new one. See page
8.4.
• The toner cartridge reached the
end of its life.
Feb 24, 2009 | Samsung ML-2510 Laser Printer
Flashing Lights
From the User Guide:
Black, Cyan, Magenta, and Yellow Supplies Status lights
These lights indicate when a print cartridge is low (the light is on), or empty or missing (the
light blinks). The lights also indicate when a non-HP print cartridge is installed (the light
blinks and the Attention light is on).
If you don't have a User Guide click on the link below and save it for future reference.
2550n User Guide
If this solution has been helpful, please rate it. Thanks!
Jul 16, 2008 | HP Color LaserJet 2550n printer + HP Color...
Toner end life
it is printing with this blinking or not?
Jan 04, 2008 | Samsung ML-2510 Laser Printer
Computers & Internet Logo
113 people viewed this question
David Payne
David Payne
