Question about Samsung Galaxy S GTI9000 Smartphone
My samsung Galaxy 1900 keeps poering down and I have to remove the battery to start it up again
  • 243 Answers
I think the problem is on your operation system, the wrong application or bad application cause it happens, to fix your problem you need to do reset to factory setting. To do a reset to factory setting you must save all your data which located in your phone memory because this way will erase all information on your phone memory then turn off your phone. After you turn off your phone press a volume down key and press and release a power button, then your screen will displayed some options such as: Fast Boot, Recovery, Clear storage and Sim Lock. Select clear storage option by using the volume up/down button to scroll to the option then click and release the power button again, then confirming your selection by press volume up for yes and volume down for no.
Posted on May 21, 2011
My tablet started shutting down and restarting while I was using it. It eventually would do nothing but shut down and restart but only partial start up. It freezes at the Samsung screen and then re
got same problem on my alcatel android phone. it has somethiing to do with heat sensor. I install toogle notification and put battery temperature as notification bar icon. whenever I used the phone for heavy app or charge it with hi-amp charger until it get above 38 degree, it will keep restarting. if it happend, no choice except remove battery until it cool back down.
Nov 05, 2014 | Samsung Galaxy Tab 2
Samsung galaxy ace 2 gt 18160
this sounds like you may have a short from the battery to the board.
check the contacts on the phone at the battery to make sure they are not clogged or have any mark that may be causing them to not get a good contact from the battery.
Aug 14, 2014 | Sony UNLOCKED Samsung Galaxy Ace 2 II X...
Why cant i open settings on my samsung galaxy s3
There are three ways to get to your settings.
1. Press the menu key. Select settings.
2. Swipe down from the top and press the gear icon in the top right.
3. Go to your apps and look towards the beginning .You will see a settings icon there.
If none of these allow you to access it then do a soft reset.
1. Shut down your phone.
2. Remove the battery for 10 seconds.
3. Replace the battery and turn on.
If after that you don't get any satisfaction you may have to do a factory reset. Keep in mind that you will lose everything on your phone so you should take steps to back up what you can before attempting it.
To do a factory reset I believe you turn the phone off then press the power button and the volume up buttons simultaneously to turn it back on. You be brought to a menu where you can choose an option to reset. Sorry if the key combination is wrong. I'm working from second hand memory. :p
Aug 07, 2014 | Samsung Galaxy S Iii S3 Gt-i9300 16gb...
Does the samsung galaxy S3 battery life run out after a couple of years?
All rechargeable batteries lose efficiency as they are charged and discharged over the course of their use. Depending on how much you use your device and how often you charge will ultimately determine how long your battery lasts. Current technology(lithium ion) has come a long way since it was first put on the market but it still has its limitations. Word of advice; Keep you eyes open for deals on replacement batteries and get you a spare.
Samsung turns off
It's faulty, buy an iPhone. You are not alone
How to fix Samsung Galaxy S4 that keeps turning off on its own ...
https://thedroidguy.com > Mailbag
Aug 24, 2015 - We received several emails from Samsung Galaxy S4 (#Samsung #GalaxyS4) owners whose phones are randomly rebooting. It may be ...
Fixing The Samsung Galaxy S4 Turns Off Does Not Turn Back On Issue
https://thedroidguy.com > Mailbag Jan 24, 2016 - The #Samsung Galaxy #S4 has established itself as one of the most dependable smartphones available in the market today. This device which ...
Samsung Galaxy S4 Randomly Shuts Down Issue & Other Related ...
https://thedroidguy.com > Mailbag Jan 10, 2016 - My Samsung s4 mini was switched off during an update and will not switch on now. ... Reinsert just the battery then check if the phone turns on.
samsung galaxy s4 turns off but still has 30% battery life ...
https://forums.androidcentral.com/samsung-galaxy-s4/303065-samsung-galaxy-s4-tur... Oct 12, 2016 - 25 posts - ‎22 authors
My s4 turns off at 30% battery life! ... note that, yesterday after the phone turned off by itself by showing battery critically low (in reality it had over ... Galaxy S4 shuts down randomly
8 Jan 2017
Galaxy S4: HELP with Hands Free
17 Dec 2016
Galaxy S4 Turns Off by itself sometimes
14 Apr 2016
S4 won't turn on unless replacing battery, then turns off ...
17 Jul 2014
More results from forums.androidcentral.com
Fix Randomly Shut Off Samsung Galaxy S4 Active Issue ' Technobezz
https://www.technobezz.com > Tech -How To's > Android Fix Randomly Shut Off Samsung Galaxy S4 Active Issue ... the battery. Now turn on the device to see if the sudden shut-off or reboot issue is resolved then. Samsung s4 mini turns itself off Google Search
Oct 28, 2017 | Samsung Galaxy S4 Mini Duos GT-I9192...
I did a hard reset by this what keeps showing on my screen 'forced upload by key pressing'
try to resset it again by hard reset
and make sure you have backed up your private data
nothing to worry just remove your battery for 5 min and try to restart
Jan 26, 2014 | Samsung I9000 GT-I9000 Galaxy S 8GB...
NO POWER MY PHONE
press home, volum - and power if you can see sometihing on the display can restore but if not your galaxy s3 must be hard bricked an possible can use and special micro usb with boot for revive problem with mmc chip set (factory problem)
Dec 16, 2013 | Samsung Galaxy S Iii S3 Gt-i9300 16gb...
My samsung galaxy s3 will not turn on
try take the battery and simcard out replace the battery but not the sim card connect to charger and then hold power button
Nov 27, 2013 | Samsung Galaxy Siii Gt-i9300 16gb Marble...
Wifi keeps turning on after i turn it off
Hello Dear::::::::
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Jan 12, 2013 | Samsung Galaxy S Iii S3 Gt-i9300 16gb...
Samsung Galaxy S GTI9000 Smartphone Logo
182 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
