Question about Panasonic Lumix DMC-FZ30 Digital Camera
I have a Panasonic Lumix FZ 30. The power light does not go off even 1-2 minutes after switching the camera off. This drains the battery very fast. Is this just a setting problem?
    Sergeant:
    Champion:
  • 214 Answers
I could give some simple and possible answer. Your camera Panasonic Lumix DMC-FZ30 is quite simple but good camera. Unfortunately it could be the lens unit doesn't work properly or the main PCB(printed circuit board). First the lens unit problem is right then you can bring it to any skillful local camera repair shop. But second problem you just have to use as a paper weight because most of panasonic part are very expensive. Most of case it exceed camera value. Now you camera is about 5 or 6 years old. The decision is yours. Oh! maybe the last possible chance is internal of camera circuitry connector( FPC--flexible printed circuitry) off position. I do once in a while see them. Thanks and good luck with you..
Posted on May 21, 2011
My lumix DMCfz-50 turns off and on several times when started.
Charge up the battery and remove and replace.
Jan 04, 2014 | Cameras
Battery life
There could be some internal short which is drianing the battery or your battery cell itself may be bad. Contact vendor if warrantee present.
Nov 19, 2013 | Panasonic Lumix DMC-FZ7 Digital Camera
FZ-100 shows number +/- 1-1/3 next to the flash icon in circle, what does that mean, flash is working ok but seams not enough flash power
This probably means the flash power is set to 1/3 of the full flash power.
Go into the camera's Menu and change the flash setting.
OR
If you cannot find how to change this setting, then remove the battery for 15 mins, replace the battery then go to the camera's Menu to set the Date & Time. the camera will be restored to the default settings.
Feb 28, 2013 | Panasonic Lumix DMC-FZ100 Digital Camera
On Lumix DMC FZ 20 camera, can I use SanDisk Extreme SDHC 4 GB card that has 30 mbps speed? I would like to confirm befor I buy the card. Thx.
No. According to the camera specifications, the DMC-FZ20 works with SD cards. While SDHC cards will fit into the slot, they will only work if the device has been designed to work with them.
You'll need to use SD cards, 2GB and smaller. You also don't need to worry about speed. Any SD card you can buy now will be fast enough to keep up with the camera.
Feb 19, 2012 | Panasonic Cameras
No power
They only have three connectors in the camera, unfortunately, you may be looking at a repair bill or replacement, as the minimum cost to repair may be more than replacement cost. i have an FZ 15 and love it, but the newer ones do much better especially in darker settings, I also have an FZ 18, seems cheaper, but good photos, the FZ 28 I think is the current one, but a step up would be better if your wallet allows, you are used to a heck of a good camera and the replacement needs to be a good one!
Apr 24, 2010 | Panasonic Lumix DMC-FZ20 Digital Camera
The on off button does not function on panasonic dmc fz 18 digi camera
Do you mean there is no power, even with a fully charged battery?
If so then it will need to go in for service.
Cheers.
Sep 20, 2009 | Panasonic Lumix DMC-FZ18K Digital Camera
DMC FZ 20 powers on but the controls do not work.
Make sure the camera is not in play mode. look for a reset procedure or a firmware flash procedure.
Aug 16, 2009 | Panasonic Lumix DMC-FZ20 Digital Camera
Update to 8 gig card
try to use lesser memory cards like 4 GB or 2 GB
Dec 17, 2008 | Panasonic Lumix DMC-FZ30 Digital Camera
No power
Hi, I have the same problem with my FZ30. The camera just doesnt turn on. Even the battery when put in the charger, the light of the charger goes of in few minutes or few seconds without properly charging it. Can it be a fault of the battery or the camera itself?
Nov 07, 2007 | Panasonic Lumix DMC-FZ30 Digital Camera
Panasonic Lumix DMC-FZ30 Digital Camera Logo
101 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
