Question about HP DeskJet 810c InkJet Printer
Ink cartridge My ink cartridge was stuck and the three lights keeps on flashing,what will I do
  • 876 Answers
Is the ink cartridge now unstuck? Are the cartridge ports free of any dried ink, etc. are new cartridges in place? Try turning your printer off for several minutes and then turning it back on. Let us know if this does not work.
Posted on Aug 15, 2008
6ya staff
SOURCE:
Canon ip100 portable printer ink cradle stuck on right hand side
I had this same problem. Count the number of blinks in sequence of the error light. it will flash green and yellow, and then just straight yellow for a number of flashes, then it will flash green again and the same number of yellow flashes again. Here is the diagnostic guide.
Two flashes: Printer is out of paper. Paper does not feed
Three flashes: Paper jam
Four Flashes: The Print Head Lock Lever is not locked properly / Ink tank is not installed properly. / Ink may have run out
Five flashes: Print Head is not installed./ Print Head is defective
Eight flashes: Ink absorber is almost full
Nine flashes:No response from connected digital camera or video camcorder/Connected digital camera or video camcorder is not compatible with this printer./PictBridge compliant devices are attached to both Direct Print Port and Bluetooth Unit Connector
Eleven flashes: Automatic Print Head Alignment failed
Twelve Flashes: Low battery level
Fifteen Flashes: Ink tank cannot be recognized
Seventeen Flashes: Ink has run out
Eighteen Flashes: Printer detected ink out condition
Nineteen Flashes: A USB hub is connected
Mine had 10 Flashes and the Print Carriage, was bad. Cost almost as much as another printer so thats what I did. I did take it apart and got it unstuck, but still didn't work.
Mar 10, 2014 | Canon iP100 Portable Printer
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Please tell me how do I change the ink cartridge in my Epson TX650?
1) Looking at the front of the printer/scanner there is an indent on the left hand.
2) Lifting up on this portion should reveal the inside of the printer.
DO NOT touch the flat cable inside the printer, DO NOT force the lid, it should open easily.
3) The ink cartridge is underneath the plastic cover in the back right-hand side of the printer. Gently pull up on the cover until it swings open.
4) pinch the clips holding the ink cartridge in the printer and pull up.
5) Unpack the new ink cartridge.
6) Remove the tape that is on the ink cartridge.
(If you forget this step the printer won't print. If that happens, remove the new cartridge, remove the tape and then reinsert the cartridge)
7) Insert the ink cartridge and push gently until it clicks into place.
8) Close the cover over the ink cartridges, and then close the printer cover.
9) Follow any direction on the front display (hit OK)
May 07, 2011 | Computers & Internet
How do i install my ink cartridges into my epson stylus nx125
Starts on page 23. http://files.support.epson.com/pdf/nx125_/nx125_qr.pdf
Replacing Ink Cartridges Make sure you have a new ink cartridge before you begin. You must install new cartridges immediately after removing the old ones. Caution: Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability. Note: Leave the expended cartridge installed until you have obtained a replacement, or the ink remaining in the print head nozzles may dry out. 1. Turn on your printer. 2. If an ink cartridge is expended, the error and ink lights on the control panel stay on. 3. Open the document cover, then open the ink cover. Caution: Do not remove the ink cartridge guard or you may damage the printer.24 Maintaining Your Printer 4. Press the y Stop button. If a cartridge is low or expended, the print head moves that cartridge to the replacement position to indicate that it should be replaced. The P Power light starts flashing. If two or more ink cartridges are expended, the expended cartridge at the far left moves to the replacement position. The P Power light starts flashing. If no cartridges are low or expended, the print head does not move. Note: Do not hold the y Stop button for more than three seconds, or the printer may start cleaning the print head. 5. Squeeze the tab on the cartridge and lift it up. Dispose of it carefully. Do not take the used cartridge apart or try to refill it. Warning: If ink gets on your hands, wash them thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. Keep ink cartridges out of the reach of children.Replacing Ink Cartridges 25 6. Before you open the new cartridge package, shake it gently four or five times. Then remove the cartridge from the package. Caution: Do not touch the green chip on the front of the cartridge. This can damage the ink cartridge. 7. Remove the yellow tape from the bottom of the ink cartridge. Caution: Do not remove any other labels or seals, or ink may leak. 8. Insert the new ink cartridge into the holder and push it down until it clicks into place. 9. Press the y Stop button. If another cartridge is low or expended, it moves to the replacement position. Repeat steps 5 through 8 to replace any other cartridges that need to be replaced. When you press the y Stop button and no other cartridges need to be replaced, the print head moves to its home position and the printer starts priming the ink. This takes about 1 1/2 minutes.26 Maintaining Your Printer When the P Power light stops flashing and the error and ink lights go out, ink charging is finished. 10. Close the ink cover, then close the document cover. Caution: Never turn off the your Epson printer while ink is charging or you'll waste ink. If the error and ink lights remain on after the print head moves into its home position, an ink cartridge may not be installed properly. Press the y Stop button again, and then press the ink cartridge down securely. Note: If you replaced a cartridge while copying a document or photo, cancel printing and make sure your original is still placed correctly on the document table. Then copy your original again. If you remove a low or expended ink cartridge, you cannot reinstall and use the cartridge.
Mar 09, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Need to change ink catrege help
Using the printer's control panel In some circumstances, you may need to replace an ink cartridge before it is empty.
If the fonth.gif ink out light is flashing or is on, replace the empty ink cartridge as described in Replacing an Empty Ink Cartridge.
To replace an ink cartridge before the fonth.gif ink out light flashes or the Status Monitor notifies you that the cartridge is empty, follow the instructions in this section.
r_caut.gif Caution: r_space.gif Do not remove the cartridge from the printer until you are ready to replace it with the other one.
r_1.gif Make sure that the printer is on. The fontp.gif power light should be on, but not flashing.
r_2.gif Lower the output tray, then open the printer cover.
r_3.gif Press the fonth.gif ink button. The print head will move to the ink cartridge replacement position, and the fontp.gif power light will begin to flash.
r_space.gif r_note.gif Note: r_space.gif r_space.gif Do not press the fonth.gif ink button over three seconds. Otherwise the printer starts cleaning the print head.
Jun 13, 2010 | Epson Stylus CX6600 All-In-One InkJet...
Have changed black ink.
Perhaps is damaged one of three lightdiodes to monitor position of cartridges. To test and repair that it is necessary disassembly fast whole printer.
Feb 16, 2009 | HP Officejet 7210 All-In-One InkJet...
Canon iP1800 printer,flashing orange light under the green 'on'
First off, How many times does it flash organge before it goes to green?
two: out of paper
three: paper jam
four: Ink has run out
Five: FINE cartridge cannot be found
Seven: FINE Cart. not installed in correct position
Eight: Ink absorber almost full
Count how many times it flashes. Then get back to me
Feb 05, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Power light and red light keep flashing alternatively
If both lights are flashing alternately, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utilit to reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help.
Nov 03, 2008 | Epson Stylus 680 InkJet Color Printer
Red light flashing-not reading ink cartridge
I have the same proble, except that the red light keeps flashing and nothing happens...
Oct 15, 2007 | HP PhotoSmart 7660 InkJet Printer
HP DeskJet 810c InkJet Printer Logo
113 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
