Question about Edimax BR-6226n nLite Wireless Broadband Router
My laptop can detect the wi-fi but I cannot connect to the internet. What is wrong with my router? Please help me out. This is a new router by the way.
  • 92 Answers
Routers have a limited bandwidth.. but some routers need to register your laptop serial to be able to connect to the internet.. there is a permission to allow your laptop to use the wireless connection.. check your wireless connection setting, then choose your router name, then try to connect..
Posted on May 21, 2011
My laptop and HP Deskjet 3510 All-in-one printer are on wi-fi networked to my wi-fi router. My problem is that when my laptop is connected to the internet my laptop is not able to communicate with my HP...
Okay... Sound to me like the DHCP Server in your router is off..
Well, do this or have your technician login to your Router admin page ( by typing 192.168.0.1 or 192.168.1.1, (or something similar depending on the brand and make of the router) into your browser and hitting enter) and either make sure Lan side DHCP server is on, or leave it off and just assign different static local IP's to each of your network devices ( e.g. 192.168.1.10 for you laptop and 192.168.1.11 for your printer). I think that will solve your problem if its related to an IP conflict.
Hope this Solves your problem. :)
Jan 07, 2014 | HP Deskjet 3510 e-All-in-One Printer
Describe your 7" G-Netbook
There may be many reasons for this. Please check the following things one by one.
1. If you have another known good laptop then try it with your wi-fi router. See if the wi-fi router is able to connect to the internet
2. If you don't have another laptop then use an ethernet cable (RJ45) cable to connect to the wi-fi router. See if this helps.
3. While connected with the wi-fi router see if you can access the router. open any internet browser and type 192.168.0.0. you should get the router page. If you don't get then you have to configure the router first.
4. Check the internet settings of your browser. There will be "internet options" or similar in the menu of your browser. Click that. In the GUI you will get "connections" tab. Click that and select the proper wi-fi setup.
Jul 28, 2011 | Sylvania G-Netbook
I attempted to add a password to my wifi and now my laptop does not recognize the router or network.
Go into your laptops wi fi connections and try deleting the wi fi connection from your laptop. Then search for the wi fi from your laptop and connect as a new connection. This should resolve the issue.
Please rate if this helps
Mar 15, 2011 | Dynex Computers & Internet
The router is blinking a yellow light
Here are some of the more common reasons that the status light may blink amber:
  • The Wi-Fi base station has not yet been configured because it is new.
  • The Wi-Fi base station has been reset.
  • A new firmware update is available for the Wi-Fi base station.
  • No IP address is available for the Wi-Fi base station.
  • A Wi-Fi base station in Extended Mode is out-of-network Wi-Fi range of a primary Wi-Fi base station.
  • The WAN Ethernet cable is unplugged from the Wi-Fi base station.
  • The Wi-Fi base station lacks a path to the Internet (or local router).
  • Internet access may be temporarily unavailable from your Internet Service Provider (ISP).
  • Your AirPort Time Capsule has detected that the internal hard drive has reported a SMART error, and is failing (This requires firmware 7.5.2, and AirPort Utility 5.5.2).
Feb 10, 2011 | Apple AirPort Extreme Router
Cant connect to wifi
Please tell what is your Wi-Fi LED status. what channel count you configured inside the configuration of router. Please be sure that your wi-fi signal is transmitting or the device is able to receive the wi-fi signal.And please tell what router you using as host and what device you using as receiver. Thanks for subscribing Fixya... All the best
Nov 15, 2009 | Computers & Internet
Hi. I just configured a DLink DIR-300 wireless router on my laptop. During the installation, it required me to keep the ethernet cable connected between the router & the laptop. I finished the...
First you have to check on your laptop that your wi fi network drivers are installed correctly.
Also check it is enabled.
Also check wi fi switch on laptop is turn on.
Check its ip addreses and subnet amsk and gateway is proeprly.
Aug 19, 2009 | D-Link DIR-300 Wireless Router
Hi, I have an old acer laptop and my wife communicates with me on it using broadband and a router with a usb pick up. I have returned home and have a new acer laptop with wireless LAN already installed. It...
Youe broadband router is working ok with the broadband cable.So it is configured with the broadband cable.Now,to work with the wireless internet,you have to configured the wi-fi router to work internet.You can see the wi-fi connection but unless & untill you will configure wi-fi router it must not work or if before it was working with the wi-fi then you can check the wi-fi router setting because it might change by mistake.Surely it will work after configurating wi-fi router.
Jan 03, 2009 | Computers & Internet
Connecting to internet
you connect the internet if your broadband router is wi-fi enable. so if you turn on wi-fi on your laptop and you get the signal. than you can access the internet on the laptop too. But for this your router should be wi-fi enable and DHCP must be set properly with in the router. so if you can access the router from your desktop by opening it in browser e.g. http://192.168.1.1 and default login id and password e.g admin you can check the status inside it. I hope this will help you in solving your problem.
May 10, 2008 | HP Compaq Business Notebook NX9010
Wi-Fi Connectivity
login to http://xda-developers.com ;and this will solve the problem of your PDA
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Oct 10, 2007 | i-mate K-jam Smartphone
Edimax BR-6226n nLite Wireless Broadband Router Logo
126 people viewed this question
Top Edimax Computers & Internet Experts
Prashant M
Prashant M
Michael Vincent Cruz
Are you an Edimax Computer and Internet Expert? Answer questions, earn points and help others
