Question about Aiptek IS-DV2 Camcorder
Webcam hi yes how do i get my camcorder to be used as a webcam i plugged it up to my computer and its worked before but now it wont please help
  • HMaier Sep 02, 2008
    It seems early on I accidently got the function of web cam but now I cannot duplicate it. I have tried the usb mode in camera and menu without getting the web cam mode. I want to use the camera to feed the video to my laptop and use the laptop to provide input to a projector for instructional purposes. is there any way to connect the usb input to the windows media player, that would accomplish what I am after.
    Herb Maier
  • elena_lynna Oct 22, 2008
    no intala la camara no puedo ver fotos
Camcorder not working without charger plugged in.
hi if you have the charger plugged in the camera the you have power to work it, if you unplug the charger and it dose not work, the I think the battery is not charged fully or it is no good after being left to long, check to see if the battery is charged. I hope this helps you, please let me know.
Mar 30, 2014 | Sony DCR-DVD602E DVD Camcorder
Lost the Web Camera driver disk for my Coby Snapp 3000, can't seem to find the drivers online.. Any solution?
Hello Werewolf, According to the manual here http://www.cobyusa.com/files/manuals/CAM3000_MN.pdf
You should not need any driver just plug it in a USB port and Windows will detect it
Transferring Recordings to a Computer Connect the CAM3000 to a computer with the provided USB cable to: ? Transfer files from your camcorder ? Perform basic file management functions. The USB 2.0 Hi-Speed connection makes it easy to transfer recordings quickly from the camcorder to your computer. Simply use the camcorder as you would a removable storage drive using basic operating system commands. If you need further assistance with transferring files, please refer to your operating system's instruction manual or on-screen help
Hope this answers all your questions Please remember to Rate/vote for any solution that helps you out. Leave a comment if you need more help. Thanks for using Fixya
Aug 16, 2011 | Computers & Internet
I have the cam plugged into my computer and the green light wont turn on so my cam doesnt work
Hi! i would like to help you with this.
First clue helped me understand that the green light wont turn on, which clearly says that there is no power supply for the webcam.
second thing i would like you to try is.
*please check for loose connectivity issue.
*please check of the port in the computer( where you plug in the cable) or the connector pin is damaged, broken or loose.
*then please check of the driver is installed in the DEVICE MANAGER.
How to get into DEVICE MANGER:
*please click START> RUN.. type in "devmgmt.msc" and click OK.
*then the device manger will open. there you can see drivers for keyboards and all hardware components. please look out for "imaging devices". if you expand it.... you will find the webcam driver.
** if there is any exclamation, question or X mark on it. please let me know. there might be some problem in the driver installation.
** also please let me know the operating system and please check if you installed the webcam software.
please let me know if you need more help. Thank you:)
Oct 23, 2010 | Logitech Quickcam Chat Webcam
Use sony dcr-sr40 as webcam
unfortunately for this model, it would not be possible to be use as a webcam. it uses HDD as its recording media. it may actually work if you have:
1.an a/v capture card installed in your computer that connects to the a/v jack of the camcorder.
2.a webcam application software that supports a/v connection
basically,you would need a camcorder that that has a usb streaming feature and a computer that has an OS that supports it (i.e win xp),or you can use ilink (dv or ieee1394) connection So you should be using a digital-8 or dv camcorder.it works perfectly as a webcam.of course, your webcam software should be designed to work with whatever connection your using.hope this info helps.tnx:)
Apr 15, 2010 | Sony Handycam DCR-SR40 Camcorder
Webcam not found - but plugged in to USB
mmmmm
u need to try to connect it to another PC and try to see if the other computer see it or not, if yes then try on ur computer to remove all usb cables and put ur webcam alone and try
Jun 07, 2009 | Logitech QuickCam Fusion Webcam
PUEDO UTILIZAR MI CAMARA DE VIDEO SONY DCR-SR 30 COMO WEB CAM PARA MI ORDENADOR PORTATIL, ASUS?
Si puedo utilizar su camara por eso. pero, la directiones estan en engles.
Primero es para S- Video
La orta mas pavajo estan directiones para USB Streaming
How to use a Sony® camcorder as a Web cam with a composite video or S-video connection.
Solution
sp.gif sp.gif IMPORTANT: The computer must have a composite Video or S-Video input jack [FIG. 1]and compatible webcam software installed. Some computers may require a video capture card and/or sound board.
NOTE: This procedure cannot be performed when using the battery of the camcorder as a power source. If the camcorder is turned on, but not recording or playing a tape, it will automatically turn off after 5 minutes to conserve battery power. In addition, please be advised that this procedure may not work for all Sony camcorder models even when using the AC power adapter. Some models have an automatic demonstration mode that will activate after 5 minutes if the camera is turned on but not recording or playing a tape.
  1. Plug the AC power adapter for the camcorder into a working electrical outlet and then connect it to the camcorder.
  2. Connect a composite video cable or S-Video cable to the VIDEO or S-VIDEO jack on the camcorder. NOTES:
    • Sony camcorders usually come packaged with composite Audio/Video cables; S-Video cables are sold separately.
    • To purchase either of these cables, check with your local electronics dealer or visit the Sony® Parts and Accessories Sales Web site or by call (800) 488-7669.
  3. Connect the other end of the composite video cable or S-Video cable to the VIDEO IN or S-VIDEO IN jack on the computer.
  4. Turn on the camera by moving the POWER switch to the CAMERA position.
  5. Remove the cassette tape from the camcorder.
  6. Turn on the computer.
  7. Start the webcam application to be used. NOTE: Contact the software manufacturer for assistance with setting up or using the webcam software.
[[Direct Accessories and Parts Center, DAPC]] How to use a Sony® camcorder as a webcam using USB Streaming. Solution
  • Not all Sony® camcorders are equipped with a USB Streaming port. For compatibility information, or if you require further assistance with any of the steps below, consult the instruction manual of your camcorder. A copy of the camcorder instruction manual is available in the Manuals/Specs/Warranty section of the Sony® eSupport Web site
  • The USB Streaming driver is not compatible with the Apple® Mac OS® operating system.
  • The computer should have a factory installed USB port and compatible webcam software, such as Microsoft® NetMeeting®.
  1. Install the USB Streaming driver on the computer from the CD provided with the camcorder.
  2. Restart the computer.
  3. Plug the AC power adapter for the camcorder into a working electrical outlet and then connect it to the camcorder.
  4. Connect the supplied USB cable to the camcorder and computer.
  5. Turn on the camcorder by moving the POWER switch to the CAMERA position.
  6. In the camcorder menu, set the USB STREAMING option to ON .
  7. On the computer, start the webcam software.
Apr 06, 2009 | Sony DCR-SR30E Camcorder
How to use a dvd cam as a webcam
hi!
i have a camcorder too im using it for some capturing videos on some places. i have webcam for chats and capturing pictures on a computer.so i suggest that use a webcam instead of camcorder. it will be pretty easy to use.
but if you want to use your camcorder as a webcam heres my help. all brand new camcorders have their own cables like usb, adapter, cd drivers, etc.. In interface on your camcorder just plug the usb to your computer. make sure that the computer will detect your camcorder. It will notify you for the installation of your device. If the computer searching for the drivers hardware just insert the cd driver included on the package of your camcorder. install it and when the computer will say that "your device is all ready to use" it means that the computer and your camcorder ready for some capturing moment or can use it as a webcam. i myself is using a yahoo messenger. the best way to apply for some devices like webcams and camcorders. it can easily detected.
i hope that my solutions help you!
thank you for using FixYa as your technical support questions
CHARCOIS
Jul 22, 2008 | Hitachi DZ-MV350A DVD Camcorder
My PC wont recognize my panasonic NV-GS70 camcorder as a webcam, it recognises new hardware but then cannot install the DVC serial device. Think I need a driver. Any ideas?
Yes you must install a USB camera driver that came with the camcorder. If you have lost the CD, then you can go to the manufacturer's site and find it. After installing the driver, you have to set the camcorder into Webcam mode. The technique will vary from camcorder to camcorder, as explained in the owner's manual. Also do a search on your comp using something like "using camcorder as a webcam" USB camera driver for XXXX", etc. etc.
Apr 14, 2008 | Computers & Internet
Can't use camera as a webcam.
Plug it in using your USB cable (it should have come with the camera) and then put the camera in the movie recording mode
(the red icon showing a film camera)
It should install automatically, if not then restart the computer with it plugged in and then check if its on (you can check by logging into MSN messenger and looking below you avatar, if there is a tiny webcam logo then its working
Dec 18, 2007 | Panasonic NV-GS15 Mini DV Digital...
Webcam
For the first user, The screen will cut off on the camera when you plug it into your computer. That is the way it's supposed to work. Make sure your camera is set to webcam. That will be under video resolution in your tools and settings screen. Looking at your camera, it will (or should) be the bottom left button. The camera won't work properly on your computer in Hi Def and that's probably why Yahoo won't recognize it. The resolution is just way too much for it to handle. Hope this helps some.
For the second one, did you install your driver software? Good, had to ask, don't cuss me! (HaHa) Okay, plug in your camera, open the little viewscreen on your camera (this MUST be open or you'll only charge your camera, go to my computer, then to whichever drive your camera is hooked to. It's removable media "L" on my computer, but yours may be different. Click (or double click) on that. You should see an icon that says DCIM, double click. Click on 100 media. Your files should come up. Hope this helps.
Nov 11, 2007 | Aiptek A-HD 720P Flash Media Camcorder
Aiptek IS-DV2 Camcorder Logo
Top Aiptek Video Cameras Experts
tomikles
Level 1 Expert
Larry Stiles
Larry Stiles
Michael Galve
Michael Galve
Are you an Aiptek Video Camera Expert? Answer questions, earn points and help others
