Question about Dehumidifiers
I have an AMFAH 2009LCD unit. it sounds like it i running but does not seem to be working as no water in the tank after 1 hour. Could it be a simple blockage or something more complicated? Thanks
  • 43,501 Answers
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on May 27, 2011
My Kenmore dehumidifier is set for 65 the display constantly reads 90 and is always running and collecting water the unit never turns off and the display number always stays at 90. What is wrong?
wow it seems you really have a lot of moisture , 1st i suggest you find and seal location of water entry second you might have to consider getting a second unit or a larger unit to work as your primary and save smaller unit for use as a back up
they are rated in Pints per hour the bigger the number the more water they pull out of air sounds as if your gonna need a 60 PPH unit or larger
Btw : 70%rh is considered the "normal" of the avg home
yours at 90 % rh is unhealthy for humans and will promote respatory mold growth and all its complications unit setting of 65% is telling me that unit is too small to handle amount of water you have
Oct 04, 2014 | Dehumidifiers
I have a delongji DEM 10 dehumidifier and it keeps switching to pause, I have cleaned filter switched off for a while but it still won't come on
follow this steps and fix it. God bless you
Unless you are licensed and qualified professional, do not try to repair a dehumidifier by yourself. If your unit is running constantly yet there is no water in the tank, try lowering the temperature control. If the problem persists, there may be a problem within the refrigeration system. You may need to pull the filter and clean it. Also try wiping off the unit itself. When the water tank is full, the unit will shut off and will not run until the tank is emptied. The dehumidifier shuts off by a safety switch in the back of the unit. If the switch is not working properly, you may try manually pressing the button or slightly bending the switch.
    Motor If the fan motor is damaged or will not work, no cool air will be coming out of the dehumidifier. The unit, however, may still run. You may need to replace the motor. If the coils in the back of the dehumidifier constantly freeze, try turning off the unit for an hour or re-locating the unit to a higher position to allow the room to heat up. If your water tank is constantly full and you are emptying it on a daily basis, you may have a water leak somewhere in the room with the dehumidifier.
    Oct 30, 2013 | DeLonghi DE500P Dehumidifier
    All the unit's digital controls seem to be in
    Joe, There are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2.
    1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have a manually
    controlled unit.set the knob on maximum.
    2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
    Unit, before removing to inspect & clean it, if necessary. If washed,
    allow filter to completely dry before reinstalling. DO NOT operate
    the unit without the filter.
    3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
    space around the entire unit.
    4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
    clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
    5. Ambient air temperature at floor level is between 40 - 60 degrees.
    dehumidifiers do not work well between those temperatures
    (Unless, you have a Low Temp Unit). This applies mainly to
    where the air temperature at floor level is colder than at shoulder
    level
    in basement applications. Raising the unit up off the floor,
    onto a sturdy table, counter top, etc, that can handle the weight
    of the unit, plus a full tank of water, will usually resolve this
    problem.
    If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
    I really hope this helped you to troubleshoot and solve the problem.
    Please let me know.
    Jul 20, 2011 | DeLonghi Dehumidifiers
    I have a sunbeam 1387 warm mist humidifier. I need to know how to clean scale from the filter. It looks like it can be taken apart. Can it?
    Actually, Carol, it shouldn't be necessary to take the unit apart. Mix a 50/50 solution of White Distilled Vinegar and Bottled Distilled Water (enough to fill the tank). Pour the solution in and allow it to sit overnight. Then empty the solution and fill the tank with Bottled Distilled Water. Turn the unit ON and allow it to run for 1 hour. Then empty any remaining Distilled Water. Doing all the aforementioned, should have not only cleaned the filter, but also the unit itself. If you use Bottled Distilled Water in the future, rater than tap water, the filter and the plumbing of the unit will stay clean longer and will require less maintenance.
    Hope this helped you. Please let me know. Thanks.
    Jun 26, 2011 | Sunbeam Warm Mist Humidifier Dehumidifier
    LG LHD45EL Dehumidifier - The dehumidifier runs continuously, but very little moisture is taken out of the air. There is only about one quarter of a tank of water after running continuously for 24 hours in...
    There are many reasons why a dehumidifier will not work or collect water.
    Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
    heatman101
    Jul 12, 2010 | LG LHD45EL Dehumidifier
    Dehumidifier not dehumidifying
    heatman101 ....
    May 25, 2010 | Whirlpool AD50USS Dehumidifier
    I have an ebac dehumidifier i think 6000 model and it appears to work fine. the fan runs ok the compressor seems to kick in ok but the tank will not fill. i had it on in my room for approx 30 mins and...
    If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
    I out mine over the floor drain.
    Turn off and it will defrost over night.
    Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
    Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
    Dec 19, 2009 | Ebac HD880 Dehumidifier
    Hi, bought one two weeks ago. Try it on auto and set at 'normal', and 'dry' and the unit will stay running with out stopping over a period of day and a half. Collected about 1/3 tank of water. Phoned...
    If you are in a very humid room or area it will not shut of until it reaches desired humidity% level that is set. If it is reaching the set level and not turning off I would return it.
    Oct 06, 2009 | Whirlpool AD50USS Dehumidifier
    Dehumidifier Brand haier HD456E does not pull water and the tank is empty, after 24 hours of running with water on wood floor. Can't find manual or online info for this model.
    I have 3 HD656E Haier Dehumidifier with the same problem runs but no water in bucket. How many did the Haier company make with this problem?
    Apr 12, 2009 | Haier HD656E Dehumidifier
    No water collection
    Check if the fan is running by putting your against the grill in front or back of the unit.
    Jun 23, 2008 | LG LD65EL Dehumidifier
    Dehumidifiers Logo
    Top Dehumidifiers Experts
    Bill Long
    Gil Shultz
    Michael Youngman
    Michael Youngman
    Are you a Dehumidifier Expert? Answer questions, earn points and help others
