Question about Fisher and Paykel Washing Machines
Hi, my fisher and paykel 7.5kg top loader washing machine is not filling up with water when I start a load. It starts to fill then stops, then fills a little more, the stops completely. I am not too sure what is going on. Can you help at all?? Thanks
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.When the machine stops completely does the machine beep.If it does beep then a series of lights will light up.These lights will be in a row of 8 lights.Starting from the left to right which lights are on when the machine beeps,Is it the 2nd and 7th or the 1st and 6th etc?Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Posted on May 21, 2011
  • roger ewin Dec 02, 2012
    its the 1st and the 6th lights on the panel
  • Joan Wye Apr 29, 2013
    on my washing machine only the 3rd 4th and 8th lights are on
Fisher and Paykel top loader washing machine, won't stop filling up with cold water
The pressure switch usually has air in the feed pipe which sometimes gets water into it which then fails to notify the system when to switch off water supply which then prevents the relay to the motor to start.check the feed pipe so it is empty of any water.this will allow the pressure switch to work properly.if the switch has failed you can get replacement part from eBay.
Dec 05, 2014 | Fisher and Paykel Washing Machines
Hi I have a Fisher & Paykel MW612 top load washing machine. It will start to fill normally on warm wash then the hot stops coming in and the cold fills intermittantly then the whole ting stops and...
Gary - LEDS 00110010 as you have not mentioned the last LED which will be red if on is 00110011
Ok - your code is 50 indictes a faulty hot water valve - question - have connected the hoses correctly - as per your descriptions - it should always be cold 1st then hot water- cold - then hot etc until it fills.
Pays to check this as the fault code is totally opposite to what your saying..
May 01, 2011 | Fisher and Paykel GWL11 Top Load Washer
Starts and stops
A failed inlet valve is not uncommon in F&P machines. The hot valve is different to the cold one, so don't exchange them. Not a big job for a tech to do in-laundry. Good luck....Nomess
Jun 11, 2010 | Fisher and Paykel Fisher & Paykel Washer
Washing machine starts and stops
www.docstoc.com/docs/.../Fisher-and-Paykel-Circuit-Diagram-GWL11
http://washingmachinemanual.com/tag/user-repair-manuals-fisher-and-paykel-gwl11-top-load-washer/
Above is your service manual and a circuit diagram, Simply use the troubleshooting steps and you will soon isolate your issue and effect a repair.
May 29, 2010 | Fisher and Paykel GWL11 Top Load Washer
Water runs continuously tub never fills My Fisher & Paykel top loader keeps filling and draining at the same time. It never gets full of water. The hose is way higher than the machine, but still drains...
where is water draining into? have u got grey water hose attached to it?make sure u can see end of drain hose, put into bucket at lid level, if it still drains as it fills u have a faulty control module.please reply for more help
Apr 06, 2010 | Fisher and Paykel IWL12 Top Load Washer
Washer
If your washer does not stop filling, you have a problem with your inlet water valve at the rear top of the machine. You simply have to replace this.
Nov 30, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
169 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
