Question about HP DeskJet 6122 InkJet Printer
No maintenance (cleaning) option on my printing preferences
I bought some remanufactured ink cartridges for my HP Deskjet 6122. At first it only printed in black. There is no option to clean the printheads on the printing preferences or anywhere else. It appeared (out of the blue) for a short time and I tried the cleaning and I heard buzzing sounds like it was cleaning, then the middle yellow light on the printer started blinking and no paper ever came out, and none was stuck in the printer. I tried cleaning with Windex like I saw on some site but it hasn't done any good. It hardly prints in black and none in color. HELP!!! Irene at flabergasted...
  • Anonymous Apr 11, 2009
    I am having the same problem with brand new HP only cartridges, and this is my second Deskjet with the exact same issue. I notice a dollup of ink at the bottom of where the cartridges rest in both printers. I cleaned it in my old Deskjet only to have the problem continue. Thought this newer 6122 from Goodwill would work better, but it seems this is why the donors got rid of it in the first place.
    Genius:
  • 2,120 Answers
Buy new color and black HP only cartridges.
Posted on Sep 21, 2008
Do I have to have a color cartridge in order to print? Can I just use a black ink cartridge?
The HP DeskJet 6122 can print with both or only one ink cartridge installed. The printer driver includes an option to print in gray scale as a substitution for color. If you choose to print a document that has a color other than black and white with only a black cartridge installed, I recommend you select the gray scale print option. To select gray scale, select the printer properties and check the box for gray scale rather than color printing. This selection can be made either at the time a document is ready to print (ie., a one time selection, using the "Properties" box in the print options window), OR as a permenant setting using the Control Panel, Printers, HP DeskJet 6122, "Properties" window. Once changed in the general printer properties, these settings remain active anytime the HP DeskJet 6122 printer is selected to print a document.
Sep 03, 2013 | HP DeskJet 6122 InkJet Printer
I am having a hp deskjet printer model d 1668 and the ink in the cartridge was exhausted before one month and i removed the cartridge./ now i bought a new cartridge but the systems shows there is a error...
A cleaning will fix the problem. To clean your Canon HP D1668 > open a document (from the computer) and select print from the menu,
- In the print screen window select 'properties' Or 'Preferences'
- In the next window click 'maintenance'
- In the next window there will be many options to clean, align, nozzle check etc etc...
Hope this help, thanks!
Oct 08, 2011 | Office Equipment & Supplies
Will hp deskjet 6122 print on black ink only?
No. You must have ink in all cartridges for the printer to work.
Thanks for your visit today.
Jan 10, 2011 | HP DeskJet 6122 InkJet Printer
How to refill the cortrideg hp deskjet f4288.
Hi
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
Greetings - have a full black cartridge yet prints green?
This printer uses all 4 inks to make black by default. You have run out of magenta in the color cartridge. Go to printing preferencies, Color tab. Check Print in Grayscale and tick "Black only" to disable color use.
Aug 14, 2010 | HP DeskJet 6122 InkJet Printer
Misplaced my manual. Color running streaks. How do I clean?
Go to printing preferences.
There should be a tab called service...
There you will have two options...
Clean the cartridge and Align.
Do both.
Jul 24, 2010 | HP DeskJet 6122 InkJet Printer
Hp 5550 print cartridge light flashing.power light on,not flashin
All HP ink cartridges are dated. If you are using the remanufactured ones the date is not changed and will not work properly at all. By HP ink only and you will never run into this again.
Sep 03, 2009 | HP DeskJet 5550 InkJet Printer
Hp deskjet 6122
GO TO MAINTENCE IN THE PROGRAM AND CLEAN HEADS AND ANSWER THE QESTIONS
Oct 18, 2008 | HP DeskJet 6122 InkJet Printer
Printing problems
Unfortunately there is little you can do to troubleshoot hardware malfunctions like this you describe. Especially on inkjet printers. You would be better off getting a replacement printer.
Make sure you take the plastic guards off the cartridges, other than that there really isn't much more you can do.
Aug 12, 2008 | HP DeskJet 6122 InkJet Printer
Cartridge alignment using vista
Option 1:- This method of aligning or cleaning ink cartridges will work for most computers and printers. Follow the instructions below to align (calibrate) or clean the ink cartridges:
(NOTE: If the following steps are not the same as those you see on your computer, skip to the next option. Each option does not work on every computer.)
Click Start, then Printers and Faxes.
Click the desired printer icon to highlight it.
Click File, then Printing Preferences.
Click the Services tab.
Click Open Toolbox.
Click the desired task.
Option 2:- Follow the instructions below to align (calibrate) or clean the ink cartridges:
(NOTE: If the steps below do not match what you see on your computer, skip to the next option. Each option does not work on every computer)
Click File and Properties.
Option 3:- Follow the instructions below to align (calibrate) or clean the ink cartridges:
Double-click the XXXX Printer Assistant icon on the Desktop.
Click the Utilities button or the Tools and Updates button.
Click the Printer Maintenance button.
Option 4:-Follow the instructions below to align (calibrate) or clean the ink cartridges:
Right-click the Printer icon on the Taskbar.
Click Open Toolbox.
On the Device Services tab, click the desired task.
Option 5:-Follow the instructions below to align (calibrate) or clean the ink cartridges:
Click Start, Programs, HP DeskJet (your printer) series vX.X, then HP DeskJet (your printer) series vX.X Toolbox.
Click the Device Services tab.
Option 6:-Follow the instructions below to align (calibrate) or clean the ink cartridges:
(NOTE: If the steps below do not match what you see on your computer, go to one of the other options. Each option does not work on every computer)
Click Start, Programs, Hewlett-Packard, HP DeskJet XXXX series, then Printer Assistant.
Option 7:-Double-click the HP Director icon on the Desktop.
Click the Utilities option.
Jul 17, 2008 | HP DeskJet 5150 InkJet Printer
HP DeskJet 6122 InkJet Printer Logo
525 people viewed this question
Ben Johnson
