Question about Canon PowerShot A650 IS Digital Camera
Camera Shake Warning
I am taking shots in a continuous light room, of items.  I was using 800 or 1600 ISO, with a tripod.  I never got the shake warning but had alot of noise in the pictures.  Was told to not go over 200 ISO because of the noise.  The problem now is whatever setting I use the green square gives me the go ahead but the camera shake warning shows up.  Don't know what I am doing wrong.  Please help   Thank you
The camera shake icon is not 'smart' in that it doesn't actually measure camera shake, simply when shutter speeds drop below a certain level it will start to give you the warning. If the camera is on a tripod (and the subject is also stationary) you should use the absolute lowest ISO (ISO80 on the A650) to get the best results. Also, use the 2-second self-timer mode so that your pressing-the-shutter-button doesn't introduce shake to the photo (the camera will wait 2 seconds before taking the picture - long enough for all vibrations to stop). If the room is very dark (needing exposures longer than 1second), I recommend you use Tv mode to unlock the even-slower shutter speeds.
Posted on Jul 31, 2009
Blurry pictures of moving wildlife
check shutter speed, problem to slow, increase aperture if light level permits hand shake can also blur image.If in full auto mode change to manual settings mount camera onto tripod THIS WILL SOLVE HAND SHAKE PROBLEMS the most common cause of blurred images.
Nov 22, 2013 | Canon EF 75-300mm f/4-5.6 IS USM Lens
Image clarity (definition)
Are you sure SR is off?
Shake Reduction worsens your image quality if shooting over 200mm focal length.
Shake Reduction also affects negatively your images if the camera is placed firmly on a support (tripod, monopod, rock, table, whatever).
Jul 11, 2013 | Pentax K5 Digital Camera
Picture from camera not clear
There could be any number of issues, unfortunately, your problem description doesn't give enough information, but here are some ideas.
Likely, the culprit is either a problem with focus or a problem with camera shake. In either case, brighter light and/or using a flash should help as auto focus works better in bright light and the shutter speed is faster in bright light. (With a faster shutter speed, there is less time for the camera to move while the image is recorded).
If using auto focus, be sure that the focus point illuminates on your main subject.
Many point & shoot cameras have an indicator if the shutter speed is too slow for a hand-held shot (typically occurs with low light). If this is indicated, then use a tripod (or brace your arms/elbows to make a human tripod) or increase the ISO of the camera (may have to go to manual mode) to avoid camera shake. Holding the camera at arm's length to look at the display while taking the picture is a recipe for camera shake & blurry pictures. You can rest the camera on a shelf and use the timer so that your hand motion pressing the shutter button isn't an issue. If using an SLR, ensure that the shutter speed is faster than the reciprocal of the focal length. That is, for a 100 mm lens, the shutter speed should be faster than 1/100th of a second.
Feb 25, 2011 | Cameras
When taking pictures at night, i find that its not that sharp and clear. that goes for the video shots as well. how do i rectify this problem. changing the modes doesn't very much. shots during the day is...
Night shots without flash will cause your camera to use a slower shutter speed. This can cause camera shake. To avoid this, put your camera on a tripod. Also, you can raise the ISO to a higher setting...however, too high and you'll get more digital noise in the picture.
Nov 04, 2010 | Cameras
Photos are blurred.
Blurred images are caused by several reasons: motion due to camera shake, use of slow shutter speeds and failure of the camera to focus correctly.
Slow shutter speeds
When light is low, wide apertures and slow shutter speeds will be selected automatically by the camera. Most people can't take blur-free, hand-held shots when the shutter speed is under 1/60th of a second.
Cameras that have optical Image Stabilization help but even IS has its limits. Increase room lighting, increase the ISO setting or use a tripod, or use a combination of all three.
Blurred images or misfocus
If an image is blurred due to camera shake, the blur will appear throughout the entire image. If parts of an image are in focus, and others are not, you've misfocused.
Sep 16, 2010 | Cameras
Whenever the image or the camera shakes, the image gets blurred. I tried to use all options for auto image, P, S, etc. but they didnt worked. What settings need to be done to get shake proof images?
I'm not familiar with your camera but does it have "shake reduction" or "image stabilization"? Do you move when pressing the shutter button? It might be time to invest in a monopod or a tripod. In the meantime, you could set the ISO to a higher setting to cause the shutter to operate faster.
Jan 03, 2010 | Sony Cyber-shot DSC-H7 Digital Camera
Orange blinking light
This happens if you are taking shot in low light condition where a camera shake is more likely to happen. use a tripod, or change the ISO to higher value. Using Higher ISO would help less camera shake but the image may have coarse. This is not malfunction.
Oct 16, 2009 | Canon PowerShot SD780 IS / IXUS 100 IS...
Fuji Finepix z20 night shots
Set shake reduction, if your camera has it, or else use a tripod or other support. Increase ISO so you can use a faster shutter speed and smaller aperture, for greater depth of field. Use manual focus if you can - night scenes often confuse autofocus. Finally, be prepared for a high failure rate !
Aug 06, 2017 | Fuji Finepix Z20fd Digital Camera
Blurred pictures in auto mode
it is probably a camera shake problem. Consider using a tripod. Also, using higher ISO helps..Using flash helps too.
Jan 03, 2008 | Nikon Coolpix 5600 Digital Camera
GRAINY PICTURES
Noisy pictures = High ISO in almost all cases. Select ISO manually (select a manual mode where you can control the ISO) and set it to the lowest possible value. To avoid camera shake, place the camera on a tripod or another sturdy surface; or use the flash
Dec 20, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Canon PowerShot A650 IS Digital Camera Logo
297 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
