Question about Sylvania Televison & Video
Small Sylvania TV model W6413TB with FM. No controls on the TV to operate the FM function. No replacement remote available. Also none of the universal remote codes I have found for Sylvania work for this model. How to use the FM?
SOURCE: remote control not working and need programming code for cable television/universal remote control
remotes.com says oerseas item-not available?
Posted on Feb 24, 2008
SOURCE: Universal Remote Code Needed
The code is 11963.
Posted on Apr 06, 2008
SOURCE: moxi remote control
The "universal code" 9910 is just the first step in doing a program search. Hold down the MOXI and OK buttons simultaneously until you get the double blink. Then enter 9910 and it will blink twice again. Then begin alternately pushing MUTE and the up arrow (above the OK button). Pushing the up button effectively cycles through the codes and pushing MUTE tests the current code that it is on. Do not go too fast because when you finally push MUTE and it actually mutes (or unmutes) your TV, you must push the OK button to store that code. I just performed this procedure and my first positive code that I stored only affected the mute and volume settings on my TV and would not turn the power on or off. If this happens to you as well, repeat the above process and just skip over the first positive you get until it mutes (or unmutes) your TV again.
Posted on Nov 15, 2008
SOURCE: code needed
Here's the link to the Radio Shack product document support. It has all the codes and how to info.
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/1502200_PM_EN.pdf
Posted on Jan 02, 2009
SOURCE: Sylvania 6313CB 13" TV/VCR replacemnt remote
We have a Sylvania 6313CB TV/VCR combo.  I bought a universal remote and the code would not work when I tried to program it to the "TV" button using all those possible codes listed in the books.  So, on the universal remote, there was a button named "VCR" and when I programmed in the code "0000" all worked.  This was a $6.00 universal remote named "One For All"  we bought at the Big Lots store.
Specifically, here is what I did:
Turned TV on Pushed the "VCR" button and light blinked once Pushed and held the "set" button until it blinked twice Released the "set" button and entered the numbers "0000" Pushed the on/off button and it worked including volume, channel up/down and channel change by entering the channel number.
Hope this works for you too.
Posted on Jan 16, 2009
How to get this remote control to turn the 2004 Sylvania TV on/off
There is a fault with the remote control and it is not worth trying to fix it and not worth replacing the stock remote control unit even if the manufacturer could still supply one for that TV.
The best option is to just buy a very basic generic remote control (quite inexpensive) from an electronics store which will work with many TVs and use that remote to turn the TV on and off. Use your stock remote for all other functions if it is still working well on those functions.
I had a friend with the exact same problem with her stock remote a while back. I purchased a simple generic remote control on special for around $20 which she now uses to turn the TV on and off. .
Nov 21, 2015 | Sylvania Televison & Video
Sylvania TV Remote Control System Is In Operative
If your new Sylvania remote is functionally identical to the old one and does not work, make sure nothing is blocking the path between the remote and your TV and try again. If no results, the IR detector in the TV may have failed
Jun 28, 2013 | Sylvania SRT2319 TV
Control remote lg for my Sylvania CD202SL8 TV
If I understand correctly you are using a LG remote for the Sylvania Combo set?
None of these companies make those units--someone else does and puts the name on the unit----Sylvania uses different remote codes on every model (they are actually Phillips).
Most programable remotes will get you basic functions BUT WILL BE MISSING KEY FEATURES YOU WILL NEED.
You need the original remote---GOOGLE FOR A EXACT REPLACEMENT if the original is damaged or lost.
"Universal remotes" are hardly universal as you have discovered.
Mar 24, 2012 | Sylvania CD202SL8 TV
Remote for avtex
Hello.....try this link,,,http://www.that-leisure-company.co.uk/avtex-replacement-remote-control-for-avtex-w152d-p517300.html...They should have the exact replacement for your set...I hope this was helpful....PEACE....
Jan 25, 2012 | Sylvania Televison & Video
Sylvania 15 inch digital/analog LCD TV HDTV. Once
try doing the auto search method on the cable remote. sometimes this works when the codes do not. if it doesn't then it is what it is.
Jun 26, 2010 | Televison & Video
Comcast remote control won't turn on or off Sylvania LC321SS9 TV
Usually you need to make the remote search for the right code that will work with your TV. Google you Comcast remote model for instructions and it willl how you the right steps.
Jul 04, 2009 | Sylvania LC320SS8 32 in. LCD Television
Factory Remote Control for Sylvania model SRT2319 doesn't work
You can buy an original replacement remote for your TV clicking the link below:
New Original Sylvania SRT2319 Remote Control $39.99
Apr 18, 2009 | Sylvania SRT2319 TV
Sylvania LC321SS9 remote code
I have the sylvania LC321SS9 tv and a atlas dvr1056 remote code 1864 works great with all functions!
Jan 14, 2009 | Zenith ZEN450 Remote Control
Remote Control Codes don't work with my LCD TV
There is no code!!! -- Solution...You have to buy a universal remote with learning capabilities. I’ve ordered one that will not only learn off other remotes but can handle 10 components also. I got it from 10x it’s called the iconRemote control…if you call the company they will give you a discount (but you have to call them and ask) AWESOME!
Jan 02, 2008 | Sylvania LC320SL8 Television
Televison & Video Logo
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
