Me ge washer keeps tripping house breaker - Washing Machines
    President:
  • 1,654 Answers
Stop using it till you get someone to look at the issue. You can start a fire if your drawing too many amps on a circuit. Could be a weak breaker, or the pump may be leaking and shorting out the motor, or there could be a bad control board, cant tell you much with the info given
Posted on May 21, 2011
I have a ge washer that trips the breaker when it starts to agitate. I've replaced the belt but still trips breaker it spins and drains on that setting put soon as it fills,starts the breaker goes
Once a breaker "trips", it is more-likely to trip the next time at lower voltage/wattage levels. Hire an electrician to replace the breaker.
May 31, 2015 | GE Washing Machines
Main fuse in house went now machine will not start light under start button keeps flashing
The washer tripped the breaker once and OR after the breaker was reset it ran additional loads with no problem then it tripped the breaker again.
Intermittent problems are always difficult to diagnose because the problem usually doesn't occur when you're making the checks.
If the washer ran additional loads the problem will not be an electrical short with one of the washer parts. If the lid switch had a short it wouldn't run the additional loads.
You don't say if the additional loads used the same cycle as previously. A timer can have an internal short that might trip the breaker in heavy duty cycle but not the permanent press cycle.
If you have access to a clamp on amp meter, see the image below, then you can check the amp draw of the washer. The washer normally will draw about 10-15 amps at start up and about 5-8 amps while running. The house breaker for you washer should be rated at 20 amps.
If the washer is running and drawing less than 20 amps and the breaker trips then if can be a weak house breaker.
Mid cycle the washer is most likely draining or spinning and if the bearing or pump locks up then the washer may draw additional amps to try to start and trip the breaker.
The key to this problem is what the amp draw of the washer is when the house breaker trips.
To narrow this problem down, there are three places that could be causing the ( outlet) GFCI to trip, a malfunction in the washing machine, a problem with the downstream wiring (aka load side of the GFCI-other items connected on same circuit), or the GFCI outlet itself. If there isn't anything downstream, then plugging the washing machine into another GFCI outlet, or simply swapping out the outlet for a known good GFCI outlet, will identify if the outlet itself is faulty.
If the outlet trips when the washing machine isn't running and isn't even plugged in, then there's a fault in the wiring on the load side of the GFCI outlet.
If the issue is neither of the above, then running the washing machine and monitoring to see which step is occurring when the trip happens will isolate what part of the washing machine may be leaking current to a ground. It could be a certain water level, a motor being engaged, a transition step in the controller, etc
Beware some techs believe that most Washing machines or any other motor should not be on a GFCI! Should be a dedicated single receptacle. If there are other outlets on the washer GFCI, replace that GFCI with a single receptacle and put the GFCI on the next jump in order to protect other outlets.
Another item to check is ur lid switch which may have gotten moister inside and created a short_ or broken open and the rubber seal dried out over time, and the switch assembly will be exposed. water can splash onto the assembly, somehow causing the GFCI to trip. In any event, if you are having trouble with your washing machine stopping mid-cycle for any reason, test and replacing the lid switchis probably a worthwhile idea, as it is cheap and easy to replace.
By the way my advice is free cuz God is good!
May 17, 2015 | Washing Machines
How do you set a ge skhb36bc1200 breaker keeps tripping does have water in the panel would that be a factor
Yes, it definitely could be a problem! Water conducts electricity. So if the water is touching different parts of an electrical circuit (resulting in a "short circuit"), the breaker would trip. When you say "the panel" are you referring to the house breaker panel, or to a panel on the water heater itself?
Dec 18, 2014 | Water Heaters
Clarke power washers 150
Need more info:
What fuse? the one at the end of the cord on the pressure washer? Or the circuit breaker on your house?
If it is the one on the cord it may have gone bad. To test replace it with normal plug (non-GFI) and plug it into an outdoor or bathroom GFCI (GFI) outlet. If it still trips that outlet then there is a ground fault in the device which may be minor or major.
If it is a home circuit breaker remember that electric pressure washers use a lot of power - typically 1500 watts. If anything else is plugged in it can trip the house circuit breaker.
Jun 04, 2014 | Garden
Dishwasher trips breaker. Breaker only resets of door is opened
wires rubbing inside dish washer , surprising its not blowing fuse in dish washer plug .
Mar 25, 2013 | Dishwashers
GE electrical house breakers keep tripping. Any problems or recalls
You may have overload that power circuit with too many appliances.
Check the load of each of the appliances on that power circuit, add them together and check to see that it does not exceed the rating of the circuit breaker.
OR
You have an overload or short/fault on an appliance on the power circuit that is protected by that circuit breaker.
To identify the faulty appliance, disconnect all the appliances on that circuit and then connect each appliance one at a time to see when the circuit breaker trips out. When that happens you have identified the faulty appliance.
Jan 21, 2012 | GE Hammering
Spin cycle trips house circuit breaker on my GE top loading washer
The very likely reason the breaker trips only on spin is because the tub bearing is locked up on the washer since it is locked up its causing way excessive friction at the motor which causes the breaker to trip.Can you rotate the tub by hand or does it seem really hard to rotate by hand indicating that the tub is ceased up due to the tub bearing??
GENE
Oct 29, 2011 | Washing Machines
Washer keeps blowing fuses
Do you mean the houses circuit breaker? If so, WHEN in the cycle does it blow the circuit breaker? WHEN it trips will tell you what to look at. I.E. If the circuit breaker trips during the fill cycle then it would be the walter inlet valve or the timer in the control panel; if it trips as soon as it is in the agitator cycle - then the motor or transmission; if it trips in the spin cycle - then the drain pump or transmission or control panel.
Jul 15, 2011 | Maytag LSG7806A Front Load Stacked Washer...
Lightning strike power surge partially disabled dryer.(Whirlpool)
If it took a lightning strike something in the heating coil is shorting to ground tripping the breaker. DO NOT Keep trying it, you could cause more damage or even burn your house down.
Sep 29, 2009 | GE Profile Harmony DPGT750EC Electric...
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
