Question about Mad Dog Multimedia SurePower (MD-350WPS) (MD350WPS) 350-Watt Power Supply
Power Supply Cables
I need to find out what each of the cables connects to. I am not sure what connect to what except for the 24 pin. Is there a certain order for the cd drive and floppy. Also, which ones connect to the hard drive
    Sergeant:
    Champion:
  • 258 Answers
The hard drive and CDROM connect to the large flat four pin cables [there are several.] The floppy[s] connect to the tiny four pin cable that is on the same line as one or more larger four pin cables...
There is no order, just pick them in a way that they all reach without strain.
Posted on Aug 15, 2008
SuperMicro H8QG6-F Continous Beep
http://www.supermicro.com/Aplus/motherboard/Opteron6000/SR56x0/H8QG6-F.cfm
Under the Link and Resources heading, in the blue banner to the right, click on - Motherboard Manual
Page 32 of the PDF file. Page 2-10 for the manuals actual page,
2-7 Connector definitions:
Power Connectors
"A 24-pin main power supply connector (JWP1), and three 8-pin CPU PWR connectors (JWP2 / JWP3 /JWP4) on the motherboard.
These power connectors meet the SSI EPS 12V (Volt) specification.
In addition to the 24-pin ATX power connector, the 12V 8-pin CPU connectors at JWP2 / JWP3 / JWP4, MUST be connected to your power supply.
Warning: To prevent damage to the power supply or motherboard, please use a power supply that contains a 24-pin and three 8-pin
power connectors.
Be sure to connect these connectors to the 24-pin (JPW1) and the three 8-pin (JPW2,JPW3 and JPW4) power connectors on the motherboard.
Failure in doing so will void the manufacturer warranty on your power supply and motherboard."
So there you have it.
YES.
These,
http://www.playtool.com/pages/psuconnectors/connectors.html#eps8
NOT these,
http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress8
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 02, 2012 | Super Micro Computer SUPERMICRO H8QG6-F
There is no power switch on the enhance atx 1123b that I have . What actually powers it up?
Just about every power supply I've owned doesn't have a power switch. The power supply is turned on by one of the wires in the 24 pin connector. According to this it looks to be pin 16 and how to turn it on:
"Short this pin to GND to switch power supply ON, disconnect from GND to switch OFF."
Hope this helps
Ray
Mar 01, 2011 | Enhance Technology ATX-1123B, Enhance...
I Just bought a Corsair Cx-500W P4 ATX power supply, but I can not connect it to my Asus P7P55D-E/LX P55 LGA1156 motherboard because of to many cables(confusing)
You need to connect the 20 or 24 pin connector to the ATX power slot on your motherboard, its the long rectangle one. You will also need to connect the CPU power to the CPU power slot, that is the 8 pin one. I hope this helps.
Feb 26, 2011 | Computers & Internet
I am replacing a motherboard with a G31-M7 TE and find that my existing power supply has a 20 pin plug consistant with the old motherboard but the new one has a 24 pin socket. Why is this and do I need to...
New motherboards have a 24-pin power connector. Here is a diagram of both plugs:
You can see that the two are almost identical. The extra 4 pins on the 24-pin connector provide extra connection points for a few voltages. Newer boards and processors need more current, and the extra pins were added to prevent overloading.
Adapter cables are available to go from your 20-pin power supply plug to the 24-pin motherboard connector. Here's one from TigerDirect, and other vendors have them as well. If you're not making other changes than replacing the motherboard, you shouldn't need more than this adapter.
If you are upgrading your processor along with the motherboard, you should probably replace the power supply too. Older power supplies are often in the 300-watt range, and this is too low for reliable operation with new processors, motherboards and video cards. A new 500 or 600-watt supply is not expensive, and would give you the 24-pin power connection the motherboard needs.
Hope this has helped. Thanks for using Fixya!
Nov 20, 2010 | Biostar G31-M7 TE Motherboard
I am trying to troubleshoot whether or not my ultra x2 connect 550 watt power supply is bad. When you press the power button on the computer, the light flashes and then noth9ing else happens. The light...
Well here is a way to check your power supply, on your hard drive connector using your volt meter and measuring from ground. this would be using one of two middle connectors it should measure +5 VDC on the red wire and + 12 VDC on the yellow wire. If these voltages are good then we got to see if the power supply is producing the -12VDC voltage. This voltage is ussed by the syustemboard on pin 14 of a 24 pin power supply. I would recommend not having your system board plugged in while measuring these votlages, but the power supply may need a load, I would plug in the cdrom.. Below are a couple of picture to explain this and a link to a website that has this documented.
dfish26_1.jpg The 24 pin main power connector was added in ATX12V 2.0 to provide extra power needed by PCI Express slots. The older 20 pin main power cable only has one 12 volt line. The new 24 pin connector added one line apiece for ground, 3.3, 5, and 12 volts. The extra pins made the auxiliary power cable unnecessary so most ATX12V 2.x power supplies don't have them. The 24 pin connector is polarized so it can only be plugged in pointing in the correct direction.
Pinout Pins 1 through 12 Pins 13 through 24 Description Wire color Pin number Pin number Wire color Description +3.3 volts orange 1 13 orange +3.3 volts +3.3 volts orange 2 14 blue -12 volts ground black 3 15 black ground +5 volts red 4 16 green PS_ON# ground black 5 17 black ground +5 volts red 6 18 black ground ground black 7 19 black ground PWR_OK gray 8 20 white -5 volts (optional) VSB +5 volts purple 9 21 red +5 volts +12 volts yellow 10 22 red +5 volts +12 volts yellow 11 23 red +5 volts +3.3 volts orange 12 24 black ground
Good Luck I hope this helps.
Nov 19, 2010 | PSA Ultra X2 Connect (ULT31851) 550-Watt...
My evolution 3000 been occasionally powering down for no apparent reason for a couple of weeks. now completely died. no power at all. won't switch on or show any life.
Power Supply's have a Form Factor. (Actually only motherboards do, but most Power Supply's follow the motherboard Form Factor)
The ATX designation determines it's size, shape, and factors concerning the various power cables coming out of it, (Spaghetti), plus other concerns.
An ATX power supply shape is generally close to 6 inches long, (15.24 Centimeters), 6 inches wide, and 3-1/2 inches tall.
(8.89 Centimeters)
It is the common size and shape used for 90 percent of the personal computers made, out there.
From what I have been reading about Evesham, they used typical power supply cables used for most ATX power supply's.
Basic specifications on the Evesham Evolution 3000 desktop computer,
http://www1.epinions.com/specs/pr-Evesham_Evolution_3000_evop3ghblulightmar04_PC_Desktop
Power Cables:
1) Don't know if the Power Supply will have a 20-pin ATX main power cable, or a 24-pin ATX main power cable.
In reality the point is moot, because new power supply's have a main power cable which will be a 20-pin connector, or a become a 24-pin connector.
To expound,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20plus4
(If you scroll up the page, you can see a 24-pin ATX main power cable, and it's respective connector.
Scrolling further up produces a 20-pin ATX main power cable, and it's respective connector.
Color of the connector does not matter)
2) The Evesham Evolution 3000 specifications, state that an Intel Pentium 4 processor is used.
This means there will be a 4-pin ATX +12 Volt power cable, which plugs into the motherboard.
Example,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
(Again, color of the connector does not matter)
3) There will be a few 4-pin Peripheral power cables,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
One connects to the Harddrive, one connects to the Optical drive, (Or optical drives. Spec's state just one CD/DVD drive is used)
4) There is a Floppy Disk drive power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#floppy
(Again, I'm going off of the specifications stated. Your Evesham may not have a Floppy drive)
To be continued in a Comment.
Jun 15, 2010 | Evesham Evolution Blue Beast...
Psu
Hmmm.... mainly you have:
-20 or 24-pins connector, that is unique and goes directly to motherboard (powers motherboard and its components)
-4 or 8-pins connector that powers CPU
-the rest would be connectors for ROM (CD/DVD/BlueRay) and HDD devices (there are: molex and sata power conectors)
If you totaly unshure, there is manual:
Illustrated How to Replace an ATX Power Supply
Sep 05, 2009 | Computers & Internet
The system fails to boot up after a new power supply was added
There should also be a brand - the nVidia just relates to the chipset that the board uses, but its OK, lets check the wiring first.  If we still have trouble I'll get you to double check for the brand name.
Lets just check that you have the following plugs in place:
  1. The 24 pin plug from the PSU (blue) to your motherboard - this powers the board itself.
  2. A 4 pin 12v P4 connector plugs into the motherboard (near the CPU).  This is the CPU power.  It runs from the 8pin blue socket on the PSU.  Make sure that the end plugging into the motherboard is only 4 pin.
  3. No power cables required to run the 8600GT so the red sockets on the PSU are empty.
  4. Power cables going to all your peripherals (hard drives and CDroms).  These run from the black sockets on the PSU.
Does your current setup match that?
Nov 12, 2008 | EliteGroup NFORCE 570 SLIT-A Motherboard
Mad Dog Multimedia SurePower (MD-350WPS) (MD350WPS) 350-Watt Power Supply Logo
127 people viewed this question
Top Mad Dog Multimedia Computers & Internet Experts
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
Are you a Mad Dog Multimedia Computer and Internet Expert? Answer questions, earn points and help others
