Question about ASUS Computers & Internet
I can't see the label that under the computer it worn off is their another place that i can find it?
    Scholar:
  • 38 Answers
Welcome to FixYa!
  • If the label is already worn off, you could get the information by going to your computer's start menu, right click on computer, select properties and you'll your computer specifications there.
  • If this one will not work, go to the start menu again look for the word run or go to the start menu, click all programs, click accessories then look for the word run and then click it. And then type on the field dxdiag, press enter and it will show the specification as well.
Hope this helps! Thank you for using FixYa!
Posted on May 21, 2011
P0320 on 98 Mustang
Check the wiring harness about 8"-10" from the computer and all places where the harness splits up for insillation worn off.These harnesses are known for wearing the plastic off of them causing this code.
Feb 15, 2013 | 1998 Ford Mustang
Intermec PX4i label printer. Paper/Ribbon loaded correctly, but ribbon is 'rippled' meaning barcode label being printed has white lines across it. Any ideas?
Ribbon Wrinkle as it called can be caused due to the main feed rollers (that touch the ribbon or the label) being slightly worn. Even if you have a sligh gradient on the roller(s) it will pull ever so slightly to one side. If you need the parts then please do not hesitate to contavct me. Jack Woodworth - Codeo UK, 01179064587
Oct 19, 2011 | Intermec PX4I Label Printer
The serial # info. label, under the seat, is worn out. Illegible. How else can I find out the info I need to order parts? Is there another place to look for this info.?
You may well have to find someone with a similar or identical machine and get the model number off of it. The model number is what is important, the serial number can not get you anything as far as parts.
Aug 27, 2011 | Troy Garden
Labels aren't feeding through at right length
This sounds like a calibration issue.
Follow the instructions below to re-calibrate
Three readings are required:
· Empty: No media in the sensor.
· Gap (or Mark): Only the backing, notch, or reflective mark in the sensor.
· Paper: The label (with the liner attached) in the sensor.
To perform a Standard Calibration:
Step Operator Action Displayed Message Comment
1 (Media should be loaded and the appropriate Sensor Typeselected.)
2 Press the menu key.
Raise the printhead assembly.
MENU MODE
MEDIA SETTINGS
You are entering Menu Mode.
3 Press the enter key to enter
the Media Settings menu.
MEDIA SETTINGS
MEDIA TYPE
4 Press the FWD key and
scroll to 'Sensor Calibration'.
MEDIA SETTINGS
SENSOR CALIBRATION
5 Press the ENT key. SENSOR CALIBRATION
PERFORM CALIBRATION
You are beginning the standard
calibration procedure.
6 Press the ENT key.
Remove the media from the Media Sensor then press any key.
REMOVE LABEL STOCK
PRESS ANY KEY <yyy>
This sets the parameter for the
'empty' value.
Where 'yyy' is a numerical
value representing the current
sensor reading.
8 Position the label (and backing,
if any) under the Sensor Eye
Mark.
ã Note: If using preprinted
media, ensure the label area
under the sensor is free of
preprinted text, graphics or
borders.
Press any key to continue.
SCAN PAPER
PRESS ANY KEY <yyy>
'paper' value.
sensor reading.
The calibration was successful.
See note below if another
message was displayed.
10 Exit upon successful
calibration: Back out of the
menu tree by repeatedly
pressing the key.
If using gap or reflective media,
press and hold the FEED key.
The printer will begin
advancing media; allow at least
one label gap (or mark) to
advance under the sensor.
READY
Aug 19, 2011 | Datamax I-4208 Thermal Label Printer
I have a Dell's PowerEdge 1800 server and the server's fans are making a loudy noise. Is there any way of quieting them down? Thanks, Ricardo
The fan bearings are worn, it is best to replace them.
As a temporary measure you can insert a small drop of oil on the bearing, the bearing can be accessed by carefully lifting the label in the center of the fan.
Jul 07, 2011 | Dell PowerEdge 1800 Server
Where are the power window relays located? I checked the fuse box under the hood but none of them are labeled 'window'.
This circuit does not require a relay. It does have a fuse. the fuse box in the passenger area will have this fuse. this fuse box is in one of two places. If you have a small coin holder on the left hand side of the steering wheel check behind it, if not there look under the dash on the drivers side near the kick panel.
Jun 24, 2011 | 1998 Toyota Sienna
We have 13 s4m Zebra printers. We try to change from thermal to direct. Which was no problem during our initial test. But when we try to change actual printer that was being place inside a cooler we kept...
Changing the setting on the printer The default setting is thermal transfer for this printer. You can change the setting on the printer so it doesn't show you the error any more by doing the following: Press SETUP/EXIT Press Plus (+) to scroll through the different parameters About the 6th parameter is "PRINT METHOD" Press "SELECT" to select the parameter Press Plus (+) or Minus (-) to change to Direct Thermal (no ribbon) Press "NEXT/SAVE" to save your changes If you make the changes to you printer and as soon as it prints it reverts back to thermal transfer, then your label software or your driver are overriding it and you need to make the change there.
Changing the setting in your label software - this will also change the settings for this label only Open your label Make the change under "label setup" or "page setup" inside your label software.
Changing the setting on the driver - this will also change the default settings for all future labels that you create Go to control panel and devices and printers. Locate the driver for your label printer and make the change under "Printing Preferences".
Sep 16, 2010 | Zebra S4M Thermal Label Printer
Is possible to configure my ymail.com account with my mac. if it is what are the setting
Yes you can and please follow the settings that is listed below.
1. In Entourage, Click the Tools Menu
2. Select Accounts
3. Click New
4. Select IMAP from the Account Type Drop Down
5. Click OK
6. Select the Account Settings Tab
7. In the Account Name field, enter a meaningful label that will help you
recognize the account (i.e. USA.NET)
8. Place a check in the box labeled Include this account in my 'Send & Receive
All' schedule
9. Enter your Name and your full Email address in the respective fields
10. Under Receiving Mail, enter the following information:
a. Account ID: your full email address (i.e. rickberglund@usa.net)
b. IMAP server: imap.postoffice.net
c. Password: your password for your USA.NET account
11. Under Sending Mail, in the SMTP server field, enter smtp.postoffice.net
12. Click the button marked Click here for advanced sending options
13. Place a check in the box labeled SMTP server requires authentication
14. Select Use same settings as receiving mail server
15. Close this window
16. *Optional* If you wish to leave a copy of your email on the USA.NET server and
have them deleted only when you
delete them from Entourage:
a. Select the Options Tab
b. Place a check in the box labeled Leave a copy of each message on the server
c. Place a check in the box labeled Delete messages from the server after they are
deleted from this
computer
17. Click OK
Feb 15, 2010 | Yahoo Mail
Computers & Internet Logo
16 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
