Question about CAS CL5000 Label Printing Computing Scale
I've installed a new label roll in my CAS CL-5000 but it's still giving me the 'paper end' message. How do I get the scale to recognize that there is a new roll of labels in the machine?
Zero range error? the keypad is locked. what to do?
The zero range error means when the scale is switched on and the weight on the pan is above the zero range for the scale.Thanks
Sep 12, 2014 | CAS CL5000 Label Printing Computing Scale
Why is the red light flashing all the time
Indicates one of the following problems:
  1. Label Sensor Error (end of roll or paper jam)
  2. Incorrect roll installed (wrong paper type)
  3. Transmission Error
Aug 05, 2014 | Brother QL-570 Thermal Label Printer
Label writer 450 is only printing half a label and then the blue light flashes like it is out of paper. New roll, worked fine before it ran out
Make sure you use genuine DYMO labels, not compatible ones. Also, make sure you select the right size in DYMO Label.
Disconnect the USB cable and the power cable to reset the printer. Check if the roll is loaded properly - the holes between the labels have to be on the left. Connect the power cable. If the blue light is solid, connect the USB cable and try to print.
Check the DYMO Label version (Help > About). If it is below 8.5.0, you have to update it.
^CM
Feb 08, 2013 | Dymo ® LabelWriter® 450 Series PC...
How to calibrate?
just look up calibrate .there ar many ways to calibrate .
Feb 15, 2012 | CAS CL5000 Label Printing Computing Scale
My casio PCR -T2000 won't print receipt paper. The paper is not moving. There is no error on the screen. There is no jam. It is the correct thermal paper. I've tried turning power off and on and...
You haven't mentioned the journal roll, so I will assume it prints the journal but not the receipt. What happens if you press the post receipt button at the end of a sale. Does it print daily reports on both rolls? --------------------------------------------------------------------
If anyone needs a Casio PCR-T2000 manual, C-tech collective have it here: http://the-checkout-tech.com/manuals/cashregisters/Casio3.php
Jul 25, 2011 | Casio Parts Cash Register PC Desktop
Display H and do nothing and till left open . can not close the till
hmmmm are you try to install new paper roll?
the paper feed arm didnt lock
open printer cover and again install paper roll
and close the printer arm
then press cl key
Sep 26, 2010 | Sharp XE-A402 Electronic Cash Register
Sharp A203 cash register froze up
then press cl key
Jul 22, 2010 | Sharp XE-A402 Electronic Cash Register
Changed rolls of labels on Zebra GX 420T and now nothing prints
Were the new labels thermal paper? Thermal printers need specially made paper to work right.
May 28, 2010 | Zebra LP 2844 Thermal Printer
DYMO THINKS ITS OUT OF PAPER ....
New versions of the Labelwriter 400 (original and Turbo) do not take Generic Labels. It is an issue with the firmware Dymo have installed - it will only relabelwriter400.jpgad the genuine labels made by Dymo. currently there appears to be no work around to solve this isses.
The Dymo OEM labels have lines print on the back, if you use labels without these lines, the printer gives an "out of paper" error
The only printers in the Dymo Range that will take our generic labels are the Dymo Twin Turbo and the Dymo Duo (both the more expensive from the range).
Dymo have only made this change in the last 6-8 months, old 400's will work with cheaper generic labels
Aug 09, 2008 | Dymo LabelWriter 400 Thermal Printer
CAS CL5000 Label Printing Computing Scale Logo
44 people viewed this question
Top CAS Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a CAS Office Equipment and Supply Expert? Answer questions, earn points and help others
