Question about Cameras
Each time I turn the camera on I set it to (P) and set the sound, resolution, etc. but when I turn it off and the on again it resets to the initial settings including language, sounds, etc. is that a firmaware issue or what?
  • Eduardo Wayar May 21, 2011
    still same problem
    still the same problem
  • 92 Answers
Try to save your setting as your default setting..
Posted on May 21, 2011
  • 1 more comment
    how???
  • Bajoka Ocampo
    Bajoka Ocampo May 21, 2011
    try to restore it to factory setting then change again your setting.. turn of your cam then turn it on,.
  • Bajoka Ocampo
    Bajoka Ocampo May 22, 2011
    Some cameras contain CMOS battery.. CMOS batteries is the supply for the internal memory to save some setting even if you turn off the cam..
    Try to check if there is a CMOS battery in your Digicam.. How? Open the casing of your cam, if you can.. When you saw a small battery on it, try to replace it..
    You should know where to buy that type of CMOS battery..
My Sony DSC-S60 camera lens in stuck open and my camera is stuck on access. It tells me turn off camera then back on. I have done that several times with no luck
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
Sep 10, 2011 | Sony Cyber-Shot DSC-S60 Digital Camera
When I turn my DSC W230 Sony Camera on the lens opens and closes several times then finally closes and I get a message to turn it off and on again, but it just keeps doing the same thing. I have tired...
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1
May 12, 2011 | Sony W230 Digital Camera
When I turn it on the lens goes in and out three times and then says turn the power off and on again and it does the same thing
Turn on the camera.
Thanks for contacting FixYa.
Feb 24, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
The lens will not retract or close, when hooked up to usb connect camera just turns off, when turning camera on error message to camera on and off again is shown. I have gone in and reset/initialized it,...
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
Dec 20, 2010 | Sony Cybershot DSCW370 Digital Camera
Turn power off and on again appears on the screen
Turn the Power Off and On again error message is displayed when the Lens in the Camera is stuck is affected by a malfunction. Try turning off the power and on again. If the issue persists, try performing a power reset.
To power reset the Camera; turn off the Camera and remove the battery pack.
Allow the Camera to remain without power for 60 seconds.
Then, reinsert the battery and check if it helps.
You may also try INITIALIZING the Camera.
To Initialize the Camera, press the On-Screen key.
Touch MENU-->SETUP-->SETUP 2-->INITIALIZE-->OK. Initializing the Camera will change all the settings back to factory reset.
Thanks for using FixYa
KenSolutions
Dec 06, 2010 | Sony Cyber-shot DSC-N2 Digital Camera
Sony Cyber Shots camera, turn the power off and on again problem
Turn on the camera.
Thanks,
KenSolutions
FixYa
Sep 13, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Sony cyber-shot 7.2-Megapixel Digital Camera pink DSC-W120 lens keeps going in and out it want stay out so its says turn your camera off and on again I keep doing that but its doing the same thing every...
Option 1:
Try Initializing the Camera as follow; (Initializing the Camera will reset the settings of the Camera to the factory settings including date and time. It will not delete any data saved in the Camera).
1. Touch the HOME and select the SETTINGS menu in the Camera.
2. Now, please select the MAIN settings menu.
3. Then select the INITIALIZE option under the MAIN Settings 1 menu.
Option 2:
If issue persists try Power reset the Camera by removing the battery from the Camera and inserting it after 1 minute.
Option 3:
If the issue still persists then Service may requires to resolve it.
Aug 26, 2009 | Sony Cyber-shot Digital Camera
Itsays turn power off and on again and shutter comes out and back in about 3 or 4 times then stays shut
Turn on the camera.
Thanks,
KenSolutions
FixYa
Aug 01, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
Selected resolution will not save
You need to change the setting in the Menu of ALL RESET from ON to OFF so that it will retain any setting changes that you make. To do this Press Ok button - right arrow to Mode Menu - down arrow to Setup tab - right arrow to All Reset - right arrow and choose Off and then press Ok. This will retain the mode setting until you manually change it again or change all reset back to On.
Aug 21, 2008 | Olympus Camedia C-350 Digital Camera
Camera keeps resetting the settings when turned off
Possible solution?
PROCEDURE
1. Initialize the system.
a) Enter the TEST mode.
b) Select "3:ROM UPDATE" and press SET button.
c) Next, select "5:SYSTEM INITIAL" and press SET button.
d) The following message appears.
SYSTEM INITIALIZE
START ...
PUSH OK KEY?
e) Press SET button and System is initialized.
"SUCCESS !" appears on the monitor.
2. Write firmware.
Update the firmware version"
Write the firmware.
If the TEST mode boots automatically, change "USB TCC ON" to "USB TCC OFF".
Nov 06, 2007 | Casio EXILIM Card EX-S770 Digital Camera
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
