Question about Samsung SC-D363 Mini DV Digital Camcorder
Eject ...D error
Just starting to get subject error. Per manual reset the battery. Did not slove the problem. Got camcorder for Christmas 2007. Previous messages online said that this was a common problem and that Samsung is extending warranty and paying for shipping.\
My e-mail address is [email protected].
I have only used the unit a couple of times.
What is my recourse ???
  • 2 more comments
  • nothavingfun Aug 28, 2008
    Battery sounds like its being drained when in camera mode. Also have the "d" "eject" problem. Bought this in Nov. of 06' and its probably only worked well 2-3 times. I've tried trouble shooting, by removing the batteries and so on and still nothing. Not sure where to even start.
  • Anonymous Sep 30, 2008
    Mine has a whining noise then comes up with the same error
  • rachelcreasy Oct 16, 2008
    I have the exact same problem. Out of warranty and nearest service center is states away. Anyone get any assistance from Samsung?
  • razah Mar 11, 2009
    I am getting the same eject sidn with a "D" popping up in the middle of the screen.
Good News!! I have found a way to fix this loud high pitch "grinding" noise, sudden battery "draining" accompanied by the eject "D" symbol being displayed only after a few seconds of tape play. And absolutely No thanks to Samsung's customer service. Although seemingly polite, I had to talk to 6 customer service representatives before they properly transferred me to Executive Customer Relation(ECR). They said they were experiencing technical difficulties. Once I got through, the ECR rep. insisted that the repairs will cost $160 mainly due to the cost of the parts and also admitted that he didn't know much about the technical aspect of the camcorder. And I was repeatedly told that this was not a known or "universal" issue so the warranty cannot be extended.
It is indeed a mechanical problem. The camcorder had only been used three times and kept in storage in its original box with no temperature extremes since I had puchased it at the end of 2006.
Here is the SOLUTION:
1) Gently unscrew and remove the front casing portion of the camcorder.
2) Directly underneath the lens there is crosslike metal support that extends from the tape compartment chassis. The green circuit board should rest on top of it as shown below instead of being under it .
Eject ...D error - 13e6f7e.jpg Now the camcorder functions properly consistently. The cost = $ 0.
Posted on Jul 01, 2009
  • 1 more comment
  • Step Hen
    Step Hen Jun 28, 2014
    I'm not going to lie. I had all expectations that this would not work, but it actually did! It doesn't seem like this is the way it's designed to sit, and I don't think I would be able to close the camera back up without forcing the circuit board back below the metal piece but I just need it to work long enough to copy everything to DVDs. Thanks so much!
  • Margarita Sourdis
    Margarita Sourdis Aug 18, 2014
    I've had this camera put away for almost ten years because of this D eject problem, i took it to service and it costed too much, so I decided to put it away. Organizing some stuff I found it again and tried it, same problem, made a search on internet and the first answer I found was this, and I tried without having any hope, it is incredible!! It worked! I have an old new camera to play with, thank you very much.
  • Ricky Tricky
    Ricky Tricky Nov 25, 2018
    maldito ********!!!! thank you very much!
    Problem Solver:
Put it in the freezer for 3 min. take the battery out first. That should do it. And I'm not kidding. Email me back want to know if it worked for you. [email protected]
Posted on Feb 16, 2009
    New Friend:
Ben Sundar, I have no idea where you go, to think just changing the board from the bottom to top of that clamp could make the camera work again, Bingo, it works, I was ready to launch it in the garbage can, and this idea save the camera, it works perfectly so far, Thank you so much.
Posted on Apr 21, 2010
  • alfredoaguia Apr 21, 2010
    New Friend:
Ben Sundar great fix. I was at a event for my son at school when this problem happened to me which sucked. Anyway, I just got off the phone with Samsung and they was going to have me send it in and pay them $160.00 I told them no way I could put a little bit more money with it and buy a new one first? I decided to look around on the web and ran across this site here and in less then 5 minutes my camcorder is working again. Thank you very much......
Posted on Dec 03, 2009
Hi my name is candice. i called and got the same result but i have undying determination so i am trying to get this camcordered recalled so that everyone who has one of these cameras can get it fixed for FREE!!! all you have to do is call or write to the Samsung Office of Presidents USA here is phone number and address. Please do this the more who do the better chance we get of a recall whether you still have the camera or not THANK YOU!!!!!
Samsung Electronic USA
Office of the President
400 Valley Road
Suite 201
Mount Arlington, New Jersey
70856
(973) 601-6000
Posted on Aug 31, 2009
    New Friend:
How do i move the circuit board???
Posted on Apr 16, 2010
  • satanicxmess Apr 16, 2010
    I cant do it
  • Margarita Sourdis
    Pull the crosslike metal thing away from the board, use something to move the green board up and release the metal thing.
SOURCE:
My Sony DCR-TRV240 camcorder won't eject the tape. The power and all camera features work, but it won't eject a tape.
I'm sorry that the Camcorder is not ejecting tape. Please follow the troubleshooting steps provided below and check the operation:
1. Please make sure that the battery is fully charged. 2. Perform Reset by following steps:
1. Locate the RESET button behind the LCD panel of the camcorder. 2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds. 3. After 2-3 seconds has elapsed, release the RESET button.
3. Perform a manual power reset by following the steps:
1. Turn off the camcorder. 2. Disconnect AC power adapter. 3. Remove the battery pack. 4. Move the POWER switch to the CAMERA position for 15 seconds. 5. Move the POWER switch to the OFF position. 6. Reconnect the AC power adapter or reinsert the battery pack. 7. Turn on the camcorder.
If the issue persists after following all the steps service will be required. You can find repair information and initiate service at:
http://fixya.com/repair
Thank you for using Fixya. Please let me know if you require any clarifications.
Sep 01, 2011 | Cameras
Panasonic dvd video camcorder VDR-M55PP
system malfunction, put a soft reset on the camcorder.
Feb 24, 2008 | Panasonic NV-DS65 Mini DV Digital...
Jammed by putting tape in upside down
Take off the battery on the camcorder. Insert the battery and at the SAME time, push the power and the eject to see if this resets the camcorder so it will eject. If this does not work, I'm afraid the unit will need to be taken apart and removed manual. Good Luck
Jun 25, 2007 | Sony Handycam CCD-TRV37 Camcorder
C:31:23 code with flashing icon for eject,with a beeping sound
The error message indicates that the Camcorder has detected an issue that may require a power reset.
Step 1:
Try to reset the Camcorder and check if it helps to resolve the issue. Locate the RESET button behind the LCD screen of the Camcorder.
Step 2:
Turn off the Camcorder. Remove the battery or disconnect the AC power adapter for 60 seconds. Insert the battery or reconnect the AC adapter.
Step 3: If still unresolved Service may requires.
Jul 17, 2009 | Sony Handycam CCD-TRV318 Camcorder
What does C:31:22 mean?
Per the manual
C means you can fix E means professional service needed.
21 is moisture condensation. icon of rain drop in a box will flash on screen unless moisture in lens Eject tape let sit 1 hour or more to acclimate
31...manual says to eject cassete and reinsert, operate OR daisconnectpower cord andremove battery, reconnect, operate.
Mar 08, 2009 | Sony Handycam CCDTRV118 Camcorder
Error ....D
This error is a mechanical malfunction, try this:
  1. Eject the tape.
  2. Set to OFF.
  3. Detach the battery.
  4. Reattach the battery.
Here is a link to your manual:
Manual
Mar 13, 2008 | Samsung VP-D361 Mini DV Digital Camcorder
CAMCORDER ISSUES
There Should be error code start with.E-
Jan 05, 2008 | JVC GR-D290 Mini DV Digital Camcorder
C:32:11 message flashes, cassette eject won't work, camera doesn't work
Just had this problem myself... called Sony. Here is what I did to fix this:
1. Turn off power
2. Open the LCD Display
3. Press "Reset" with paperclip/pen
4. Unplug ANY wires connected to the camcorder
5. Eject battery
6. Plug in DC charger
7. Power on
8. Attempt to eject tape
9. At this point, the metal tape holder comes out but refuses to open... slightly "close" the portion of the camcorder that has the button to eject the tape, and then open it fully again (you'll hear a click, this signals the device that the 'hatch' is open and to eject).
10. The metal door *should* pop out and allow you to withdraw the tape.
I've tried 4 different cassettes and about 2 seconds after hitting play, I get the error every time... my solution: Not going to try to play my tapes on the camcorder anymore... will find another player to play Hi8 MP cassettes. Unknown if able to record to tape as of yet.
Nov 24, 2007 | Sony Handycam DCR-TRV240 Digital Camcorder
Re eject and D error.
  1. Eject the tape.
  2. Set to OFF.
Manual
Nov 05, 2007 | Samsung VP-D361 Mini DV Digital Camcorder
Tape Jam
Can anyone give any information on this problem? I am having the same problem, on Christmas of all days. Any help would be much appreciated. Thanks
Nov 23, 2006 | Panasonic Palmcorder PV-GS14 Mini DV...
Samsung SC-D363 Mini DV Digital Camcorder Logo
1,974 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
