Question about Microwave Ovens
The capacitor in my Bamix M122 has exploded and destrayed the rating markings. Can you supply the capacitor value
    Sergeant:
  • 248 Answers
GPF 40/085/56
PME 271Y522
Posted on Mar 03, 2013
2 Suggested Answers
  • 517 Answers
SOURCE: bamix M122 circuit diagram required
Good day!
Please try this link:
http://www.pdfqueen.com/bamix-m122-diagram
Thank you
Posted on May 25, 2011
How to open up an over the range microwave to replace the hv capacitor
I'm not finding that model number. Please check your tag in the cooking cavity or on the microwave somewhere.
I'll guess that you might mean FGMV185KFA. You can find helpful exploded views and order parts here.
There is a YouTube video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
On some models that will be enough to give you access to the capacitor.
If not, you'll need to remove the oven from the wall, then remove the cover to access the HV capacitor.
If so, it's best to have 2 people, since it can be heavy and awkward. The installation instructions are here.
Please see this safety file first.
Jan 09, 2013 | ERP Microwave Capacitor - 13QBP21095
Where is the capacitor on the kitchenaid microwave KHH2090SSS
You can find helpful exploded view diagrams and order parts by entering your full model number here.
This model is inverter-based, so it does not use the larger, exposed capacitor that transformer-based models do. It uses one or more small capacitors hidden on the inverter board.
As long as the high voltage section was not energized within about a half-hour of disassembly, and one does not contact the high voltage connections, there's really no need to discharge high voltage capacitors.
They have built-in bleeder resistors that bleed off the charge in seconds. But there is that one in a zillion chance the resistor inside is defective, etc.
The shock from stored DC high voltage isn't what hurts you. What hurts is getting sliced up by the sharp metal chassis when you reflexively pull back your hand after the shock.
I'm also curious as to what problem you're troubleshooting.
We're
Dec 13, 2011 | Microwave Ovens
Bamix M122 circuit diagram required
Sorry, but Bamix M122 circuit diagram is not available right now. In that case if you have your manual, you can check that.
May 25, 2011 | Microwave Ovens
How can I get a bamix manual, I have a bamix but have lost the manual that came with it
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
May 02, 2011 | Microwave Ovens
I have microwave model fmv156dcg. After a period of time the digital display has become hard to read. If i squat down a bit and look up at an angle I can read the display but it's almost impossible to...
If you have a smoker in the house, the display may be coated with tar from the smoke. Spray some window cleaner on a soft cloth or paper towel, and gently wipe off the display face (do not scrub; it scratches easily).
The power supply capacitor on the controller board may be going bad. Unplug the oven, remove the top/side cover, and inspect the electrolytic capacitors. The tops should be flat; if any are domed or obviously leaking, they should be replaced (note: sometimes the top of the capacitor has a thin plastic disc covering it; doming of the disc is normal). See the photo below to identify good and bad electrolytic capacitors. This photo is from a TV or computer power supply and your controller will not look this. You're looking for components like bad ones marked in the photo or the good ones next to it. If you see a bad capacitor, post a comment with the capacitance (e. g., 2200 uF) and voltage rating, and I'll recommend a part number that I know will be a good replacement. The cost is usually under $2 plus shipping from whatever supplier you choose.
It is possible that the display itself is going bad, but this is not very common.
Jul 08, 2017 | Frigidaire FMV156DC Microwave Oven
How do i replace the magnatron on a kitchen aid khms147kss
You would need to remove it from the wall, using the installation instructions here, review the safety information here, then remove the outer cover and discharge the high voltage capacitor.
Then you can swap the magnetron.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
May 05, 2010 | KitchenAid KHMS147 Microwave Oven
Main fuse blows when I press start on panasonic nn-255 microwave opened up microwave and see 25 ohms on cn702 of invertor circuit board, what's normal? This would appear to be a short to the 120v supply,...
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
Apr 17, 2010 | Panasonic NN-S255 Microwave Oven
SIZE OF INTERNAL FUSE A Belling BEL-CJ/SS25 Combination microwave oven The fuse has blown and the size printed on end cap unreadable any one any idea as to its value as it reads like T8H250V
Check to see if its marked on the panel itself could be an 8 amp 1.1/4 inch size ...you must fit the correct amp fuse for safety also be careful as the Capacitor may hold a charge and can be lethal voltages within...good luck.
Apr 12, 2010 | Microwave Ovens
Microwave exploded.
Did it make a popping noise, like a .22 cal pistol? Probably one of the larger capacitors on the power supply blew up.
Mar 06, 2009 | Emerson MW8168B Microwave Oven
Capacitor and diode
Unless you know they\'re bad, I would test them first depending on the symptoms, since they may not be the culprit(s).
Here are some helpful links:
arial; background: rgb(255, 255, 255);font-size: 13px;">http://www.microtechfactoryservice.com/cap_test.html
You can find helpful exploded view diagrams and order needed parts by entering your full model number here: http://tinyurl.com/gv383
We\'re happy to help and we appreciate your thoughtful rating of our answer.
Feb 23, 2008 | Jenn-Air JMC7000 Microwave Oven
Microwave Ovens Logo
262 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
