Question about Lantronix SecureLinx SLC48 Console Server 48 x RJ-45 Serial, 2 x RJ-45 10/100Base-TX Network - 2 x P... (SLC04822NG3)
We bought new lantronix SCL048 for console managment replacing the SCS048 which went hard down. So we replaced with SCL048. All network devices including routers, firewalls, VPNs and loadbalancers console are using straight-through cable to connect to lantronix ports on SCS048 it we are able to login to the device through it. But since we replaced with new lantronix we are unable to login. We tried giving baud rate of the deviceport. that didn't work. Hang up the system after giving direct [Lantronix01]> direct 25 Connecting to Device Port 25. Connected to port 25. Escape sequence is ESC A Can somebody help me to configure or to login to the devices through lantronix.
    President:
  • 739 Answers
Hi..
as routers, as well as the device you mean, they only need to enter IP addresses and configuration, if you have problems to enter, try to reset to factory settings, if it still fails, chances are there is a problem in the device. before assuming the damage to the device, you need to do a reset to factory settings and make the connection directly (from the computer to the device) is still the same if this means there is a problem with the device. please refer to the supplier or the place you bought it for inspection device and the warranty claim.
Please accept if it is successfully done
Regards
Posted on May 21, 2011
How do i detect the ip of my iomega
you have two options:
1) Install the Iomega management software and it will detect the connected storage at your network automatically, then you will be able to view the IP address
2) connect to your router management console and check the connected devices; if your network is not huge you will be able to locate the device easily
Apr 22, 2012 | Iomega 2 TB Home Media Network Hard Drive...
Lantronix UDS1100 what are the pin connection to emulate com1 on a PC
Please see the link here below for the complete manual.
http://www.lantronix.com/pdf/UDS1100_UG.pdf
If you go to page 70 you will see the complete pin layout for RS232, if you need to connect it to a PC with a 9 pin RS232 port you can see the equivalent on page 72.
Please let me know if you need more details.
Mar 15, 2011 | Lantronix UDS1100 (UD110000201)
I have Lantronix-SCS400,i forget it's ip and i wanted to reset it,the reset button seems broken,is there any other way to reset it to default??
To reset the SCS to factory so you can assign a new IP, use a paper clip to depress the button inside the reset hole. Hold that button and recycle the power, continue to hold the button after power cycle for 15 seconds.
Nov 29, 2010 | Lantronix Secure Console Server SCS400...
Hi. I have to configure the lantronix mss-100, bat I dont have the cable.
Are you asking about a serial cable to connect the serial port on the MSS100 to (for instance) a Com port on a PC?
If that's the case you can use a DB9-to-DB25 null modem cable. Here's an example: http://www.cablestogo.com/product.asp?cat_id=936&sku=03019
You will also need a DB25F/F gender changer in order to use this cable.
If the MSS100 already has an IP address that is valid on your network you can telnet to it or open it's web configuration manager in a browser to configure it.
There are video tutorials of various ways to assign an IP address to an MSS here: http://ltxfaq.custhelp.com/cgi-bin/ltxfaq.cfg/php/enduser/std_adp.php?p_faqid=1114
There is also a FAQ: http://ltxfaq.custhelp.com/cgi-bin/ltxfaq.cfg/php/enduser/std_adp.php?p_faqid=167
Installation and configuration information is in the Installation and Getting Started chapters of the MSS User Guide, http://www.lantronix.com/pdf/MSS_UG.pdf
If you have further questions, please give Lantronix Technical Support a call at 800-422-7044, or post a question here: http://ltxfaq.custhelp.com/cgi-bin/ltxfaq.cfg/php/enduser/ask.php
Regards,
Gary Fisher
LANTRONIX
Senior Technical Support Engineer
167 Technology Drive, Irvine, CA 92618
Phone: (800) 422-7044 or (949) 453-3990
Post Technical Support questions at http://ltxfaq.custhelp.com/cgi-bin/ltxfaq.cfg/php/enduser/ask.php
Get real-time help online! Use Live Assist at http://www.lantronix.com/support/live-assist.html
Mar 10, 2010 | Lantronix (MSS100-21) (MSS10021) Remote...
My network adapter disappeared on mt desktop- do I
You might need to check the Device manager to see if the network card is there and installed properly.If the device manager says it is there and working then it will be a hardware issue.
Just in case your not sure how to get to Device manager, here is a shortcut. Right click on My Computer, click Manage. This will bring up the management console, have a look down the left and find Device Manager.
Oct 29, 2009 | 2wire (1000-100009-001) Network Adapter
I have connected Lantronix UDS1100 Device with Siemens AZL Meters. But not able to get complete data on front end.
The UDS has the following LEDs, which help you diagnose problems.
Power LED (green)
Ethernet 10/100 Link (yellow = 10 Mb/green = 100 Mb)
Ethernet Half/Full Duplex Activity (yellow = Half Duplex/green = Full Duplex)
Diagnostic (red)
Status (green)
Simultaneously lit Diagnostic (red) and Status (green) LEDs mean something is
wrong. If the Diagnostic LED is lit or blinking, count the number of times the Status
LED blinks between its pauses. The following table explains the LED functions:
Aug 27, 2009 | Lantronix UDS1100 (UD110000201)
UDS10 reconnection problem
Try the LS100 from www.sena.com, it has a better warranty (5yrs vs 1yr) and its about half the price of a uds-10. We've had the same experience with the four UDS-10's we have and now 3 of the four have stopped working and report the following error: "FATAL ERROR 01/Setup memory: Contact tech support". I called there tech support and the guy (Marty) actully told me that the units have exceeded their life expectency. They all failed within the first ~22 months of operation. Working in a school district we cannot afford to keep doing the same thing over and over and over again, so our next project which involves 15 building will all use the SENA LS100 product and save the district money and have way better support and warranty. Thanks goes to "tech support" person Marty at Lantronix.
Oct 26, 2007 | Lantronix (UDS-10-01) Terminal Server
Lantronix UDS 1100 freezing my software and hardware
I would check your flow control on both the device and on the UDS1100. Also make sure your baud rate, stop bits and parity match
Oct 24, 2007 | Lantronix UDS1100 (UD110000201)
Lantronix SecureLinx SLC48 Console Server 48 x RJ-45 Serial, 2 x RJ-45 10/100Base-TX Network - 2 x P... (SLC04822NG3) Logo
123 people viewed this question
Top Lantronix Computers & Internet Experts
Unlockingcom
saqi iqra
saqi iqra
Level 1 Expert
Are you a Lantronix Computer and Internet Expert? Answer questions, earn points and help others
