Sony Bravia LCD KLV-32U300A Symptoms: ~ powering up problem, whenever try to turn on click twice and power goes completely off no standby indicator as well. i have to discharge the stored current in the caps to try the tv on but still the sounds click twice and goes.it rarely turns on after 4/5 hrs. In the SMPS board EADP-170AF A ~ board-G, CN202: "4VSB" pins 3, 7 & 8 have 4Vdc ~ other power outputs: CN201 6Vdc, 15Vdc, 30Vdc, "PWR_PANEL pin 7&8 ~ CN203- 24Vdc IN CN202 pin 3,7&8 4VSB is immediately falling 0-1v after sound click twice while tv started to turn on.i disconect the CN202 from the main board still found no volt in pin 3,7&8 After i discharge the current in capacitor and pluged back again and found required voltages 4v and again i connect the board click twice and goes off the voltage.I found the 4VSB while in standby mode. Any advice would be greatly appreciated. Thank you
  • Televison & ... Master
  • 17,164 Answers
Replace the caps
Posted on Mar 10, 2017
4 Suggested Answers
techman
  • 3130 Answers
SOURCE: High-pitched noise when I turn on the tv
No I think your problem is the horizontal output transistor blew out an that was a result of the flyback transformer going out or blowing up.. Good Luck TO you.
Posted on Mar 25, 2007
SOURCE: Hi, where to buy parts for Maxent LCT TV
I have one screen for the model l271170w1 please let me know if you want it. to set up pricing. jribot@gmail.com jribotatgmaildotcom
Posted on Apr 29, 2009
  • 230 Answers
SOURCE: Burnt Zener diode... Voltage spec??
On the cathode of the zener diode look for a filter cap and check its value the voltage of the zener should be less than the working voltage of the zener. Basicly its likely being used as a shunt regulator as protection and regulation of the voltage. When the zener hits a certain threshold it will breakdown and start conducting to ground until the supply regulates and then it will recover. If the filter cap for that voltage rail was 25V I would guess that the zener would probably be regulating between 12 and 20 volts. I'd pick a 15V Zener its probably +- %10 on the original and any system should be able to take a %10 tolerance as a general design rule.
Posted on May 07, 2009
Schamthmsch
Hi.
If you have no picture, no sound and the TV stays in standby it is not the remote sensor. That is the TV in protect mode (forced standby). The TV goes in forced standby when an internal problem is detected. Most Sony have buttons on the TV set. If problem is the IR sensor the TV Twill wake up if you press the channel buttons on the set. Try disconnecting power cord for ten minutes. If that does not work call the Sony support number listed in your user guide.
Regards.
Ginko
Dec 15, 2011 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
Buy KLV-32U300A power supply
Hi.
This model was distributed only in few countries. Replacement parts are not available from third party distributors.
Please contact Sony at the number listed on the owners manual or check your local Sony website for the support contact.
Sony Global
Sony eSupport - Electronics
KLV-32U300A - Sony South Africa
Nov 29, 2011 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
Sony Bravia LCD KLV-32U300A Symptoms: ~ powering up problem, whenever try to turn on click twice and power goes completely off no standby indicator as well. i have to discharge the stored current in the...
I know its a 32 inch TVand its probably about 2 years old, give or take. If you got a warranty on it, I suggest calling whoever you got it from (BestBuy,Amazon, etc) and seeing what they can do for you to get it fixed for free. Otherwise call Sony abotu getting a real tech out to either fix or swap parts on the TV at your house, or where to send it for repair. Depending on what it costs, you are probably better off buying a new 32inch LCD TV for about $400.
It seems you have isolated it down to the power supply though. If you are confident enough, you can get a replacement on ebay for abotu $100.
Just depends on what you value more: time or money.
May 21, 2011 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
Whenever i plug my sony bravia KLV-32U300A, it click twice and doesn't turn on,power sign goes completely off. I have to unplug from the power source, wait 5 mins and try again, it rarely turns on, but...
This is an indication of out-of-regulation in the power supply section. The very common caused of this fault is the leaky electrolytic capacitor in that section. It will drop the supply from normal voltage and will disable the unit.It needs a little warm-up to make itself stable but the symptom will get worst, times will come that it will not power up at all. Sometimes it has a bulged/dome at the top but not all, it is better that you have a capacitor checker/tester to determine its condition. Your unit will back to normal again if the leaky capacitor is isolated.
If you don't have necessary tools and test instruments, and can't do the job yourself, I would advice you to look for a professional to troubleshoot the problem. Don't attempt to work in the power supply if you don't know the safety precaution of handling it, there some stored electricity enough to hurt you with a little mistake only.
Also check if your unit is under warranty /extended warranty, avail it because the manufacturer of your unit will fix it for free. Don't open the back panel, this will void the warranty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
May 17, 2011 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
Klv-32u300a sony geting power on suddenly goving of
SONY-KLV32U300A
NO STEND BY LED NOT LIGHT
4V FROM POWER NOT FOUND
May 01, 2011 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
Power Tripping?
power problem for the sony KLV-32U300A . Open the back cover of the tv onplug the power supply board, In primary section where u connect AC voltage just after the fuse there is NTC (negative temperature coefficient) parallel to the Relay, replace it. this could be the cure for your tv. isn't it simple? LET ME KNOW.
May 22, 2010 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
