Question about Motorola Mobility Backflip Smartphone
How to master reset phone to origional setting
  • 43,501 Answers
Here you go...
Reset Backflip phone
heatman101
Posted on May 21, 2011
I bought an iphone 5s second hand but i cant unlock iphone icloud.what do I do to remove icloud account and password
you have to master reset and or factory reset or you can add new I cloud and use
Jun 06, 2017 | Cell Phones
Tried to reset password since cant remember origional. Got code but now get message tried too many times...wait and retry. Four hours later get same message. Now what?
What phone is this? There are different master reset sequences for different phones. And understand you will lose everything on the phone, it will go back to factory settings.
Sep 19, 2014 | Cell Phones
Master reset keys in Sony Ericsson W995
performing a master reset
Ensure all content on your handset is backed up before performing a master reset, then:
  • Press Menu.
  • Select Settings.
  • Select General.
  • Scroll to and select Master reset.
  • Select either Reset settings or Reset all.
  • Select Continue/Reset.
  • The phone will now reset and restart.
Jan 20, 2012 | Cell Phones
I forgot my keyguard security code n code ffor reset factory settings.. so nw i wanna jst get done with reset factory settings...
If you forgot the security password, then you need to master reset the phone. To master reset the phone, you need to contact the service provider oryou can get the free master reset code from the site Unlock-Free.com where they are providing master reset code for certain Nokia and Alcatel phones.
Jul 10, 2011 | Nokia 1100
To restore the factory setting
how to restor k300i factory settings
Mar 10, 2011 | Cell Phones
How to remove message saying "emergency calls
If "Airplane Mode" is activated, this could happen, otherwise there's no other settings to deactivate or activate the offline mode with this Model. The "Airplane Mode" is under Settings, make sure it's Off.
You can also check the Network Setup under "Settings" and make sure "Automatic" is selected.
I would also recommend you to try with another sim card. If the same problem persists with another sim card, try resetting the phone "Master Reset". There are two options to reset your phone, 1. Master Reset and 2. Master Clear. Master Reset will reset every the phone settings to factory default while Master Clear will reset the phone as well as clear all the data from the phone and will restore everything as it was when you bought (as a new handset).
To do Master Reset, open "Settings" then "Initial Setup" and "Master Reset", you'll be asked to enter the security code, type in 1234 and proceed, if 1234 doesn't work, then use 000000 (6 zeros).
Note: if you have changed the code, you should use that.
Even resetting doesn't help, then there must be Network Problem with your phone, perhaps, the Network IC. In rare cases, Antenna causes this issue. Or sometimes it's related Software. All these are to be checked/done at Motorola Service Center or at local Mobile Repair Shops.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Dec 08, 2010 | Motorola Mobility RAZR V3m Cellular Phone
Cnt unlock or reset mater code on the motorola rokr for metro pcs
Here is how to do a master clear or master reset on most Motorola cell phones.
If you have a Motorola cell phone and want to clear all numbers out of the address book and reset factory settings you need to use the master reset function.
First you need to go to the main menu, settings, setup, master clear option and enter six zeroes, 0000000
This works on most phones. If that does not work call your carrier's technical support
by dialing 611.
Master Reset Codes and Master Clear For Motorola Cellular Phones.
var dc_AdLinkColor = 'blue' ; var dc_PublisherID = 90892 ;
Sep 09, 2009 | Motorola Mobility ROKR E1 Cellular Phone
I have a motorolla ming... i dont know the code for the master reset / master clear / its asking for a 6 digit code / i do see only in the manual a 4 digit code
You have the option of using Master Reset or Master Clear to reset settings, and remove information.
Master Reset resets all settings on device to factory default.
Master Clear resets all settings to factory default, plus clears all data from the device including: PIM data, Call History, Settings, etc.
To perform a Master Reset or Master Clear:
  1. Press Start.
  2. Scroll to and select System Tools.
  3. Scroll to and select either Master Reset or Master Clear.
  4. Press Yes when Alert appears.
  5. Enter Master Code (normally 000000).
Feb 19, 2009 | Motorola Mobility RAZR V3
Hard Reset
Hello DoctorJ16,
If you mean hard reset as in reflashing the unit with software, it shouldn't make too much of a difference. Are you experiencing a problem with the unit or you just want to set everything back to default?
You can get similar results by performing the master clear and master reset option.
Go to the Menu and click on Settings
From there you'll want to scroll down to "Initial Setup"
Scroll down to the bottom and you will see both Master Clear and Master Reset.
I suggest you do the Master Clear first, the code should be six "0", entered "000000".
After which you can perform the Master Reset, same code.
Hope this helps,
cHiPz.
Apr 01, 2008 | Motorola Mobility MOTORAZR2 V9 Cellular...
Motorola Mobility Backflip Smartphone Logo
88 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
