Question about Motorola Mobility SLVR L7 Cellular Phone
Ok I have dropped my slvr several times in water and they continued working. A few of my buttons came off and one day i got a little drop of water on my phone, and now the buttons tend to frequently freeze up. Help me please!
  • 48 Answers
You must open your slvr then try to clean it with some PCB cleaner. try to put it back then test this will fix your problem. if still cannot you must change your Keypad board.
Posted on Aug 15, 2008
Motorola V3 pins 1,2,3 shorted out...
If the phone was on when it was dropped in the water it probably will never work because the circuits inside will have been compromised. If the phone was off, remove the battery and it can be put in an oven set to 'warm' and left for several hours. This dries out the circuits an sometimes lets the phone work. Usually the phone gets damaged when it is dropped in water.
Jan 03, 2015 | Motorola Mobility RAZR V3
My impala is showing it is overheating on the gauge. i was driving this morning and got about 3 miles from my house and the needle went from barely warm to redline. after pulling over for a minute and...
Blockage in the Cooling system
Fan's Not working Properly
Blown Head Gasket or Warped Heads
Faulty Sending Unit
Water Pump Vanes are Corroded OFF (Got to love DEXCOOL)
and my Favorite that everyone seems to forget about
AIR in the COOLING SYSTEM....
Apr 08, 2013 | 2003 Chevrolet Impala
Pressure dropping slowly over a few days.
If you have a pressure tank, make sure that 1/3 of the tank is full of air...this may solve your problem
Or maybe you have to install a "foot valve" on the suction of the pump to solve the problem
Mar 26, 2013 | Plumbing
My phone will be fine, but then suddenly it freezes with a black screen and the buttons flashing continuously.
Same thing happened to one of my phones after i dropped it several times. I ended up having to just get a new phone because pulling the battery out stopped working it would just stay frozen and would turn itself off and on over and over again until the battery died
Apr 26, 2012 | LG P500 Optimus One With Android Os Wi-fi...
I dropped my iPhone in water. What should I do?
useually unrepairable but take the back off then remove battery and sim then use a hair dryer to try and dry out the moisture sometimes it works depends on how much water damage is in the main board
Sep 01, 2010 | Apple iPhone (16 GB) Smartphone
Dropped in fresh water for approx 2 seconds. Unit powers up but I can not get past the Drive safely screen.When tap the Continue button, it will not continue.
Just been trawling through tomtom's website and the only reference to waterproofing I can find ( The IPXX rating) is for the motorbike version. So in short, it's not even remotely waterproof. So the best thing for now is to turn it off, remove the battery if possible, but don't worry if you can't, and leave the gps in a warm, dry place to dry off. This can take a few days but it tends to work for phones etc that are accidently dropped in water.
If it still doesn't work after that it will need to be sent back to tomtom to see what the damage is...
Oct 06, 2009 | Tomtom ONE GPS Receiver
Ventilate will not drop from menu ventilate...what to do..how to get rid og msg
Open hot water valve, for a few seconds, water will stream out and pump will engage to vent out water circuit.
May 30, 2009 | Gaggia Titanium Espresso Machine
I dropped my slvr and now the screen is white - can I retsore the screen?
to do a master reset blind press the red button a few times to make sure you are at the home screen. now press the center button once, press 8 then 5 press up twice then the center button once now enter your 6 digit security code and then press the center button twice. that should do a master reset on your phone. If that doesn't work then your screen is destroyed. If you don't want to spent money on a new phone you can always use the voice dialing button on the right side of the phone located right under the charging terminal. press it once then give a command (EX. "Call Joe smith") the phone should confirm the command, then say yes or no
Aug 06, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Phone won't turn on/charge
Kikimenor: Advise. If this is your 3rd RAZR V3, you must encourage Cingular (Now is the new AT&T) to replace your whole unit with another model. A friend of mine exchange his phone 4 times, until Cingular replace it. Motorola had too many problems with RAZR phones and that's why they launch quickly the SLVR L7. They still producing the RAZR, because users love the style and shape of the phone, but reality is that Motorola had several heavy issues with RAZR (Bluetooth, batt, microphone, etc.) If you're paying for an insurance on your unit, encourage them to replace it. SithPitt
Jul 04, 2007 | Motorola Mobility RAZR V3
Hotpoint aquarius 1200 washer dryer wd64
operation will be affected by having only one hose connected - when water from the disconnected hose is demanded then machine will not continue. i assume hot hose not connected. easiest way to deal with this is to connect both hoses to a ~"y" piece. easily available and costs about £3
Jul 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Motorola Mobility SLVR L7 Cellular Phone Logo
23 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
