Question about ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA 775-SIS 672 968 VGA FETH (610839154845) Motherboard
Shut down automatically while playing and when it re start, "CPU is over temperature error" and CPU over voltage error.
  • ASUS Master
  • 27,725 Answers
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no?MOISTURE in the air line dust causes static to build up in a computer causing it to overheat any many other problems
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error if this fails to fix the shutting down
another possible reason could be a memory dump you might be running to many programs at the one time placing to much strain on the CPU also you might not have enough RAM random access memory to check what is running when your computer is running scroll to the bottom toolbar right click select task manager applications and processes if you see something you dont need running select end now to check how much ram you have click start right click on my computer select properties you will see all of your computers details another way to check how much RAM you have click start all programs accessories system tools system imformation all of your computers imformation will be there try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive this will schedule on a restart don
Posted on May 21, 2011
Computer idles high then shuts down
When you say "idles high" do you mean you hear fans spinning faster or louder? If so, a fan spinning at higher than normal speeds is indicative of components/chips being run aggressively causing them to run at much higher temperatures. You may want to look into getting temperature monitoring software like CPU-Z to monitor the temperatures of your CPU and GPU. These components are the most common ones to be running at high temperatures. If any fan has failed on them the secondary fans (if there is one) will run at much higher speeds to compensate. Your PC may have a safety precaution to automatically shut down if certain temperatures are reached to prevent permanent damage to the components. Are you getting any blue screens before it shuts down?
Oct 16, 2013 | E-Machines eMachines Desktop PC
Toshiba satellite p300 shutdown
You also should change the thermal paste. If you want to play games, please choose normal PC. I think you are asking too much from your laptop.
Apr 15, 2013 | Toshiba Satellite Computers & Internet
TOO HIGH TEMPERATURES AT MY LAPTOP ACER ASPIRE 5735Z
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Aug 01, 2012 | Acer Aspire Computers & Internet
My Laptop is Acer Aspire 3050- PC Notebook when i play games laptop ,it became too heat and suddenly shutdown.(between 15 -20). it will happen only when play games, For other purpose it will work...
The laptop was not designed to gaming ..and when you use it for gaming the video card and the cpu are forced too much for it ..The system is shutting down cause it gets to the top heat point ..
The cpu has a top heating point set in BIOS ..and when it gets to it ..the system is shutting down automatically as a protection ..i suggest to avoid forcing it and if you still want to run large games on it ..you need to upgrade the heat dispenser and also get an external cooler for it ..
here are some ex..
http://www.pcworld.co.uk/gbuk/laptop-cooling/737_7124_70133_xx_xx/xx-criteria.html
Also check in bios settings if the cpu is set for the max temperature allowed..to be sure it has the correct settings ..just enable the optimal factory settings ..or ..if you have it from teh start and you know you never messed with the bios settings ..just let it be ..cause you can do something wrong ..(specially on the hdd bus and will not see your system after )
Another thing that may be wrong is a heat dispenser that does not doing its job ..either dirty or something like that //If you want you can open it up and check ..but the best idea is still to get an external cooling device and improve the temperature control ..
Sep 05, 2011 | Acer Aspire 3050-1733 Notebook
Dryer runs for a short period of time and then shuts down without any error code but with a "clean filter" indication. This happens when running any automatic cycle except "air dry". ...
it is proberly lint stuck around the motor and fan resticting air flow to the motor and the motor is shutting down because it is to hot vac out around the motor and inside the cabinet
Jul 04, 2011 | GE Profile DPSB620ECWW Electric Dryer
My laptop turns itself of after 3 - 5 minute
Check the charger of your laptop if there is any place that has problem or cut? check the voltage of your laptop whether is the same thing with the charger. If everything are fine, then reload your operating system, because I have noticed this problem with my clients. Good luck
Feb 03, 2011 | Dell Latitude D600 Notebook
Ok i read some forums on the web about the amd am2 5800+ processors and it says nothin about them overheatin.. so down on the forum it said that when the cpu shut off from gettin to hot to feel the...
try this, open case then plug off processor cooling fan, then plug off processor, clean it, then plug on again the processor and cooling fan, if need take more fan on your pc then turn it on, if still like that it mean you must change your processor
Jan 23, 2011 | Abit Fatal1ty AN9 32X Motherboard
My comuter won't start up properly. It stays blank right before the log in screen at start up. It shuts down automatically when I play certain video games.
Ok this could be a CPU Issue, after a while the thermo paste on the heatsink which is on the CPU under the fan the paste will dry out and when it does the cpu once starts working under load due to the games being played will shut down to protect itself and the board.
What you need to do or get someone to do it for you take out the Heatsink reapply thermo paste on top of the CPU (by the way thats what I call it) may be known in your region as Thermal grease (also called thermal compound, heat paste, heat transfer compound, thermal paste, or heat sink compound. If you need more help let me know
Regards,
Spud
Jun 18, 2008 | Gateway Computers & Internet
Dell gx270 {switch}
My motherboard shows error thermal error and after 3 minut its power is close automatically
Apr 10, 2008 | Dell (4T274-DE) Motherboard
Shut down problem
if it gives you 60 secs warning , abort the shutdown by ---- shutdown /a---- command....and check for any servivice termination from administrative tools > services... check if all the automatic strted services are running
Jan 26, 2008 | Microsoft Windows Server Standard 2003 for...
ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA 775-SIS 672 968 VGA FETH (610839154845) Motherboard Logo
81 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
