Question about Craftsman Air Tools & Compressors
I have a 30 gallon stand up craftsman. It runs good in cool weather but once the temp gets higher in the area it will run for one tank then kick the breaker from the power ever time. I have to wait a few seconds for it to cool then it will reset. However It will trip before building the air pressure again. A direction would be apreciated Thanks Apollo
    Master:
  • 403 Answers
To me sounds like the breaker, or power supply is not enough for unit. Cool temps will slow the juice down, on a solid copper wire. but once its heated to max, your done.I would check the power supply first.Also, check for a drain, could be kicking cause its full of water.
Posted on May 21, 2011
Craftsman lawnmower
so take a power washer to the carb area when it cools off. behind the plastics that protect the carb is the engine and fins for cooling. this choke thing sits up in there and gets dirty, best thing is to take off the carb and all the parts under it and clean out back in there , get the dirt out so the air will flow, use carb cleaner to get the dirt out of the autochoke . there is a idle arm/throttle that has a light spring on it , don't screw that thing up. power wash the whole thing if you can, usually wont affect the electrical. A little soon maybe but might need the valve lash adjusted , that's a once a year thing anyway.
Sep 12, 2016 | Craftsman Garden
I just installed new water pressure tank,it builds pressure to max then water runs low on pressure till pump kicks back on.whats wrong
Have to set the pressure switch
(instructions are under the cover)
65 # cut off
42 # cut in
Should install a new switch every ten years
& a new check valve before the tank & manifold
assy every 20 years
Oct 25, 2014 | Water Worker 44 Gallon Vertical Stand...
What is the max. temp. for 2004 4x4 trailblazer
Depends.
A normal cooling system runs between 195 degrees when the thermostat opens, to 230 degrees when the cooling fan kicks on.
If you are experiencing air temps over 90 degrees, the cooling system could run at 210 or higher.
Idling and moving make a difference too.
Jul 10, 2012 | 2004 Chevrolet TrailBlazer
I have an old craftsman impact gun model number 875-188992. what size compressor do I need for taking off lug nuts/automotive work?
The two most important specs are CFM at 90 psi (that's how fast the compressor can compress more air when the tank starts to run low) and how big the tank is. Virtually any compressor that has a top pressure rating 20 psi higher than you need for your tool (which is usually about 90 psi) and that has a tank of a couple of gallons will work. But the smaller the tank, the shorter time you can operate the tool before the compressor has to kick in. And the lower the CFM at 90, the longer you will have to wait for the tank to come up to pressure again so you can operate the tool at full pressure. If this is for occasional use and you aren't in a hurry, you don't need much of a compressor at all. If you want to operate continuously, then you should get something with a CFM at 90 psi that is higher than your tool's CFM consumption. Keep in mind that impact wrenches don't operate continuously like paint sprayers do. Good luck. Vote if you found this helpful. Al K
Jun 07, 2011 | Air Tools & Compressors
After first full tank on air, and you used it, when it kicks back onto recharge the the tank, the motor runs slow and blows 15amp fuse.
Sounds like you need a bigger fuse.What happens is there is no load (air) in the tank so their is no compression and the motor isn't working as hard as when it reach's the cut off point and restarts.Now there is air in the tank which makes the motor work harder and that pulls more than 15 amps and blows the breaker.I would start with a 30 amp and go higher if need be.Thank You for choosing FixYa.com
I always add this for your information. If this is not the solution that you are looking for please re post because when we pick a question to answer FixYa takes it out of the questions.
May 26, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
A/C will only pump 30-40 lbs, but keeps running.
Maybe your unloader valve is stuck or damaged. This is found in the switch assembly and if it is faulty you should be able to hear a constant hissing noise from the switch .
Jun 05, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
Must wait 30-40 mins to restart engine
Check your manual to see if it call for premium or regular. Premium has less energy per gallon and is designed for higher compression engines. What makes it "premium" is more anti-knock compounds - not better quality or performance. Sounds like a vapor lock problem that resolves as the engine cools. Regular gas may help with that.
May 03, 2010 | Briggs & Stratton 3000 PSI Pressure Washer
Rheem 40 gallon wh installed 12-13-06. Have
Was the tank full and all air out of lines before turning power onto it. If it's not full it will blow the new elements you just put in.
If the bottom one is good you get like luke warm then it will start cooling off.
If the top one is good it will be a burst of real hot then cold.
Dec 18, 2009 | Water Heaters
Engine running to cool
Replace the thermostat. If thermo is stuck open, coolant only heats up when there is no flow over radiator(idle) and then cools down when driving. Also, check coolant level, same response as stuck thermo.
Feb 06, 2009 | 1999 Volvo V70
Air Tools & Compressors Logo
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
