Question about Audiovox PLV31199S1 19 in. LCD TV
I have a trutech m# plv3119s1, i lost the mounting screws, what size can i replace them with?
How do i find screws for mounting brackets?
Contact the manufacturer for the proper screw size. Just give them the Model number and they'll provide you the correct screw size. They may even just send them to you for free or for a nominal charge.
Sep 28, 2016 | Heritage (4FNW42PT1M) 42'' Ceiling Fan
Lost screws for Mounting. Need to know size screws for mounting
To know more about this, you have to download the repair manual of this set. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Disassemble procedure to many popular brand TVs are given.
Apr 18, 2014 | Sylvania LC370SS9 LCD TV
Need to know TV Stand Screw sizes
To know more about this, you have to download the repair manual to this set. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 03, 2014 | Toshiba 47TL515U 47 3D LCD TV
Panasonic tc 32lx85 mounting screws sizes
Call Panasonic customer service and they will provide either the parts or the size and thread type----most of these bolts are common and can be purchased at Home depot etc.
Oct 30, 2012 | Panasonic TC-32LX85 LCD TV
Need screw size for 26" niko tv stand. to mount the tv to the stand
man i looked and couldnt find a size but here is a number to a company who might can tell u, its called peerless mounts 1-800-473-3753 good luck
May 26, 2009 | Niko OTP-2613W 26 in. LCD Television
Trutech 16190 Wall mounting
They are usually designated in Metric sized screws.
Find the closest standard screw to your size, and go into home depot and ask for some help finding the metric. Get the closest to and one above and below, since they should be 15c each and through process of elimination, you will find it. The length should be no longer than 1 inch.
Unfortunately that is all the info I can give you as there is no cut sheets or manuals to refer to. This brand is a Target brand that they have had multiple manufacturers make.
Please see this link for some interesting info about this.
http://www.iconnectdots.com/ctd/2007/05/targets_trutech.html
Jan 08, 2009 | TruTech PLV16190 Television
Need manual for trutech product
go to the trutech website and you should be able to download a manual there.
Nov 29, 2008 | TruTech TT320
PROTRON STAND
Is that a problem? Check the hole size and choose a screw with a head that is bigger than the hole size. Typically select a minimum of 4mm diameter screw.
May 03, 2008 | Protron PLTV-37 37 in. LCD Television
Audiovox PLV31199S1 19 in. LCD TV Logo
42 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
