Question about Dishwashers
Just replaced the control panel on a Frigidaire DW #PLD4375RFCO. Had the dreaded "ER" flashing problem. All was working well ....about 15min into the wash and now "HO" flashes, and then the "ER" again. Opened and all was very hot. Any suggestions? Thanks.
    Sergeant:
    Champion:
  • 257 Answers
Probably the thermostat. Remove the kick panel and look toward the back you will see a circular piece with 2 wires attached on the top. Turn off the power to the dishwasher, unscrew the thermostat and order a new one.
Posted on May 21, 2011
How do I reset my Frigidaire dishwasher? eR light is flashing
Good Afternoon Sammy, thank you for your inquiry!
Based off the information you have provided you would like to reset your Frigidaire dishwasher because it is flashing "ER". The best way to reset your dishwasher is to flip the household circuit breaker off for roughly ten minutes. If you continue to receive the "ER" code it could be a possible problem with your main control board or keypad. I hope this is helpful information. -Matt
Mar 21, 2015 | Frigidaire Dishwashers
Have a Frigidaire Gallery dishwasher that is flashing ER
Good Morning Jimpat Holmes, thank you for your inquiry!
I understand that you are having an error code "ER" displayed on the panel of your Frigidaire dishwasher. Normally, "ER" stands for error code and that can be a miscommunication within the board. I would perform a reset on your dishwasher and you can do that by disconnecting power from your dishwasher for ten minutes. If you continue to receive an error code you could be experiencing an issue within the control panel or faulty wiring harness. I hope this information is helpful. -Matt
Oct 30, 2014 | Dishwashers
Rinse only error, interrupted cycle
Double check that the float on the basin isn't stuck. It is mushroom shaped and inside the DW. Open the door, slide out the bottom rack, and look for it. Found it, great. Gently move it up and down a couple times. Does it move freely? Was it stuck? No? Ok Then lets try something else.
Call the manufacturer and ask them questions. If it is less that a year old, it is covered under basic warrantee. Do not delay.
Also check other common issues with DWs: Is their debris in air gap or in the bottom of the DW, where the drain is screened?
1. The air gap is usually located on top of the sink. Lift off the pretty cover, and unscrew the top cap nut. Is there rice and debris there? Remove it then. Reassemble and check it out.
2. The DW drains to the bottom of the unit where the pump is. This area is screened off so that the pump doesn't get clogging debris in it. is their leaf lettuce and stuff covering this? Remove that debris. Some times this area can only be accessed by removing the bottom spinning spray head. It comes off with a nut, possibly this nut is reverse thread. Reassemble when done looking for debris.
3. Is the drain line between the DW pump (located under the DW) and the waste pipe kinked? This line is a plastic corrugated line about 7/8" around the outside. It is a pumped waste and won't work if it is kinked, so unkink it.
4. Is the float stuck. This is a device on the bottom of your DW that tells the DW how much water is in the bottom of the DW basin. It looks like a mushroom. Gently move it up and down. Does it move freely or is it stuck? Unstick it.
Good luck.
Jan 11, 2014 | Frigidaire FGHD2455LF
ER code, flashing touch pad selections.
It is most likely a fault with the keypad mebrane on the dishwasher control panel. Need model number of dishwasher to make a more detailed conclusion.
Jan 04, 2013 | Frigidaire Dishwashers
"ERR" is flashing and it makes sounds like it washing dishes.
Hello derekwaynemo - Could the dishwasher be flashing "ER"? If so, it typically indicates that the unit has shorted out the control panel. This can happen by excess moisture getting into the control area. Let the unit dry for 24 hours with no use, and see if the display error code erases itself. If it does not, this unit will require the repair of a professional to move forward accurately.
Dec 14, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Error message "clean S"; flashing
Hi
"Er Clean S" is a common error with Frigidaire which means shorted keypad. The issue is with the touchpad/keypad that should be replaced. However, before replacing the keypad you can unplug it and take it apart completely and use a hair dryer to blow some warm air on the keypad assembly to blow the moisture off. Hope this helps...please post back for further assistance.
Daniel
Jun 18, 2011 | Frigidaire PLD4375RFC Dishwasher
Error codes flashing
Hi, This is mainly due to control panel failure. This unit does not ventfrom the front like most do, so there needs to be some clearance above the top of the tub to avoid blocking the vent fan, otherwise moisture gets trapped in the machine and works it's way into the control panel eventually..
Apr 13, 2010 | Frigidaire PLD4375RFC Dishwasher
Just bought 4 months ago.was flashing ER and now no power to ANY buttons
frist you should call the after sales servic agent in your country.
but you can try unplug the Dw AND CHEEK THE ERGTH CONECTION.AND TRY AGAIN
May 24, 2009 | Dishwashers
6 mo. old frigidaire d/w displays the "ER clean S" flashing error
Probably a control panel failure. This unit does not ventfrom the front like most do, so there needs to be some clearance above the top of the tub to avoid blocking the vent fan, otherwise moisture gets trapped in the machine and works it's way into the control panel eventually.
Jan 01, 2009 | Frigidaire PLD4375RFC Dishwasher
Er message on panel of Frigidaire GLD3450RD
I had the same problem last spring. Unfortnuatly, the problem is within the electronic control. Steam leaks in, due to an improper seal ring. Humidity stay in the compartment and eventually, the contact on the wire ribbon corrodes. For me, it meant a new electronic module.
If the eletronic module is ok, then the only working solution require that you order and install a "fit kit" from Frigidaire.
Some models even have a recall made form Frigidaire. Better check with them.
Nov 15, 2007 | Frigidaire 24 in. GLD3450RD Built-in...
Dishwashers Logo
211 people viewed this question
Top Dishwashers Experts
Owen Barnes
