Question about Philips DVP3150V/37 DVD Player/VCR
My DVP3150V powers off aftre about 10-15 seconds. I've tried everything I can think of and pored over the manual too. Anybody have any ideas on this?
Connecting my ps3 to a jmb tv?
Do you mean the TV is on AV or the PS3 is on AV? Either way, try this, it will not hurt your PS3 at all!
Turn off the ps3, then hold down the power button until you hear the second beep, then can take up to a minute. Once you hear the second beep allow it to boot normally.
My friend swears you need to do this with the ps3 powered on. But I don't think so, but just in case the original solution doesn't work, try this.
If this doesn't work, it's probably a problem with the cords, or the tv.
Apr 28, 2013 | Televison & Video
OBD2 CODE READER P0562
fully charge battery and make sure everything switched off i.e rear window demist etc and take it for a run to get it up to tempature then park up rev engine at fast idle approx 2750 rpm for 180 seconds then take foot off throttle and allow to idle for 30 seconds this will clear your catalyst and get it up to the 600 degrees needed for it to operate properly this should remove the engine warning light
Apr 21, 2013 | Mazda RX8 Cars & Trucks
Will shift on reverse and on first gear will not shift into second and third ?
have a pressure test done on the transmission if auto. Look for metal on the drain plug if manual as it may be a cluster shaft bearing failing and allowing misalignment in the gears .
Apr 20, 2013 | Cars & Trucks
Okay I have been using my HP G61, for a while now. I bought it 3 months ago. And I used it for college everyday. I used it last night before I went to sleep. I've closed it and left it charging all...
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue You might use the system restore to restore your system to an earlier time click start all programs If it is a hardware issue the system restore might not work Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Feb 28, 2013 | Computers & Internet
Constant black screen on my galaxy S GTI9000
Solution-no but pretend that you are trying to get the phone right for the first time. Take the manual in your hand and do what you have to do to change the screen colour.
I do not know the prosydure by heart soI leave it to you.
Kolbrun
Feb 26, 2012 | Samsung Galaxy S GTI9000 Smartphone
I have the Philips DVP3150V/37 DVD Player / VCR Combo. The DVD player works fine, but when putting in a VCR tape, it plays for a few seconds then shuts itself off. Any suggestions on what to to?
The 3150 has two belts or bands that can slip when old, just like the old days. One is for loading the cassette and the other is for providing take-up torque for the tape. Have also seen the tape loading arms get out of sync and don't put the tape around the heads..... working on one now but dont have a fix yet..it has the loading problem.
Nov 01, 2011 | Philips DVP3150V/37 DVD Player/VCR
CPI Aragon gp 125cc , bogs down when trying to set off , if I leave it to warm up for 10 mins it will go but other then that it doesn't want to go anywhere , I've tried to find the carb settings on...
I dout its the carb setting if you mess with the screws it will be very hard to get it back to factory setting it sounds like a choke problem check your choke cable make sure its working and try to adjust it
Jul 23, 2011 | 2008 Cpi Aragon GP
My Danby DPAC9008 (which I just got today!), doesn't seem to work, after only an hour of use! I've tried everything I can think of, and the manual is about as useless as they come, and I...
I assume, that since you tried everything you could think of, you also checked the electrical outlet it's plugged into, to see if it's still working. And the circuit breaker for that outlet hasn't been tripped.
I took a look at the Owner's Manual for your model and it's pretty extensive on how to operate the unit. But, admittedly, it doesn't have much of a troubleshooting guide.
After you checkout the power to the unit and you're still having problems. Contact Danny's Consumer help line 800-263-2629 for more assistance.
Jun 02, 2011 | Danby Heating & Cooling
Philips DVP3150V/37 DVD Player/VCR Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
