Question about Hampton Bay 24750 Huntington III Ceiling Fan
Our remote to the fan is not working - Hampton Bay 24750 Huntington III Ceiling Fan
  • 776 Answers
Try changing the batteries int he remote.
If anyone opened the battery box for the remote recently, the "DIP" switches may have been moved. These switches make the communication between fan and remote match - (in case you have several fans in the house, you only want one remote controlling one fan). You will have to pull the besel off of the fan (where the pole comes to the ceiling). You should be able to see a set of 4, 6 or 8 little slider switches on a small electric board. Make sure the switches are set the same on both the fan and remote. If they are set differently, they will not communicate.
If that doesn't work, there are many options of what can be wrong (bad remote, bad radio receiver on the fan, interference from other radios, ...).
Good luck,
-Mark
Posted on May 21, 2011
Remote wont work for fan.
http://www.ehow.com/how_6104129_instructions-hampton-bay-fan-remote.html You may need to reprogram the remote
May 15, 2013 | Televison & Video
Hunter Ceiling Fan Remote Works Sporadically
The part that receives the signal from the remote control is the receiver which is located in the motor housing.
Apr 29, 2017 | Hunter 27148 Remote Control
We just bought a house that has 3 of the same fans. THey are hunter with remote and no pull cords. The master bedroom fan doesnt work. We tried to rewire it and the only way we could get anything to...
Hi Leanne,
Most fans have green, white, black and blue wires. Green is earth or safety ground, white is neutral, black is for the fan and blue is for the light fixture. Some fans may deviate from these commonly used colors in which case you should consult the instructions. Below are links to instructions for different Hunter remote fans, additional instructions for Hunter remote fans or you can look up your fan by model number or use. It appears that the built-in remote Hunter fans have no provision for controlling a light when the fan is wired from a traditional switch instead of using the included remote, as they have only a green, white and a single black that remains powered constantly to supply the remote receiver. The hand held remote transmitter tells the receiver to switch power to the fan motor and light bulbs as needed.
It is possible that the transmitter or receiver you're using in this room is not working. Try using one of the other remotes with the non-working fan by matching the code of the remote to the fan. If it doesn't work, try selecting a different code on the fan and match it on the remote (in case there's a problem with that particular code in this location). Try all (or as many as you care) codes to see if any codes work with this remote.
By this time, you should have either found a working code with this remote and are all done, or still have a non-working fan. Since you have tried more than one remote - and know that one of them worked in the other room, suspicion falls on a faulty fan or integrated remote receiver. You can replace the fan if you like with a traditional fan and light and purchase an after market or third party RF remote control if you no longer wish to get an integrated remote receiver.
I hope this helps and good luck. Please rate my reply - thanks!
Apr 19, 2011 | Dryers
Fan remote nor lights work.
FIRST CHECK THE WIRE CONNECTIONS IN THE FAN ARE NOT LOOSE ,IF ALL CONNECTIONS ARE GOOD THEN I WOULD SUGGEST YOU REPLACE REMOTE.
Nov 08, 2009 | Dryers
Fan with remote won't work with wall switch. I
I just recently purchased a hunter ceiling fan w/light and remote. Had it installed and wall switch would not work, only remote. I contacted Hunter company directly about this problem and I was told that they redesigned their fans with remotes so that only the remote works for turning off power to fan. The person who made that made that BRILLIANT change should be fired. So to those of you who own a newer hunter an product with a remote ne your wall switch will not work tat s te reason why.
Jul 14, 2009 | Hunter Ceiling Fan Light Remote Control
I have 2 fans 1 stopped working 1 remote
Look at the remote code on the remote which is broken, then copy the code on the fixed remote, then you can control anoher fan.
Jul 12, 2009 | Universal Remote Control Hampton Bay...
I have a floor fan and the remote isn't working.
check IR receiver on the fan circuit board, resolder the lead.
Jun 19, 2009 | Holmes Products Holmes HT35R-U Tower Fan...
Two ceiling fans, both remotes control the same fan
Most likely the dip switches on the remote receivers don't match (on the second fan, the one that doesn't work). While the remote dip swithes on both remotes match the working fan. You can simply reset the dip switches on the second fan receiver to match the one working remote, i.e. you don't need to have a second remote, one can work both fans as long as the codes (dip switches match). If you want you can make all the remotes the same, that way you have two remotes, or if you want them independent each remote and remote receiver must have unique codes (dip switch settings).
Nov 30, 2008 | Universal Remote Control Hampton Bay...
Hampton Bay Classic Collection 52" remote ceiling light/fan
rechecked wiring, but blue with blue, white with white, etc., now lights work with remote,but fan only works with wall switch - so why doesn't fan work with remote,if lights work the remote & receiver must be ok?
May 30, 2008 | Hampton Bay 52 In. White Redington...
Hampton Bay 24750 Huntington III Ceiling Fan Logo
165 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
