Fan blows out air but not cold air at any setting at&t put wiring in for tv next to airconditioner since then problem ?
  • 43,501 Answers
They may have drilled through a wire or stuck a nail in the wire...
Check the wiring with an OHM meter for a shorted or broken wire..
heatman101
Posted on May 21, 2011
SPT WA-1220H Portable Air Conditioner stopped blowing COOL air?
sounds like the compressor has died and is tripping its overload protection. Give it a good funeral, and next time, buy a brand name model.
Oct 06, 2014 | Kenmore Ac Airconditioner Remote Control...
Why is my airconditioner blowing hot air instead of cold... we tookit out for this year and now it dooesnt work right do we add freon to it
Check the capacitor, It should be flat on top where the wires connect. A lightening strike or other power surge will cause this area to be puffed up. two wires connect either way. Three wire, Black to common Red,white or yellow to herm, Blue purple or brown to fan.
Jul 27, 2014 | General Electric Heating & Cooling
Just bought a 2 yr. old Danby DAC5209M window a/c unit that doesn't cool the air before it blows it into a room. The wiring looks brand new, it was barely dirty on the inside, anyway, I've...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 24, 2011 | Danby DAC5020 Air Conditioner
Danby DB98-26786A window air conditioner will start up and blow cold air..frost forms on the tubes..after a few minutes the frost disappears and the compressor shuts off .. the fan still blows; but no...
heatman101
Jul 23, 2011 | Danby Heating & Cooling
Hi i have a reverse cycle airconditioner. i have just cleaned it with an aircompressor. the fans workin but its not clickin in and out to controll temprature its cold for about 1 and a half ours n then...
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV.
Please check for loose wiring and rectify, as your cleaning with air compressor would make chances for that.
Jan 01, 2011 | Heating & Cooling
Air conditioner is blowing hot air; fun blade not working
dear sir
if fan motor is not working that why your airconditioner is not getting cold. please try to test fan motor by electric tester check continuity on fan motor wire one bye one. if there is all wire have continuity with each other then it,s mean fan motor is ok and problem in other device . if you can do by yourself then try if not then take help to a technician.
hope answer the question
thank you
please vote!
Oct 03, 2010 | Carrier 38CKC036 Air Conditioner
The AC blows on #4 fan setting but doesn't blow at all on 1-3
That is the blower resistor. 4 is wide open, so, no resistance. I had 4 of them put into my truck. The wires were burnt and shorted the others until the problem was found. Check the plug if you do this yourself.
Jun 13, 2009 | 2005 Chevrolet Colorado
The Fan in My F350 airconditioner is not blowing very hard.
check to see if the fan is wired correctly. if the wires are backwards the fan will work but because it is spinning the wrong direction it wont blow the right airflow
Apr 15, 2009 | 2000 Ford F350 Super Duty Super Cab
Fan speed trouble on cool setting
1.check selector switch of airconditioner.
2.capacitor of blower fan motor.
3 wiring of airconditioner.
4.replace selector switch.
Feb 25, 2008 | Comfort-Aire EKTC12-150J Air Conditioner
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
