Question about Sunpentown 2,800 Watt 6.5HP Power Generator
How much gas to oil ratio to run generator or straight gas
  • Sunpentown Master
  • 43,501 Answers
Check for a crankcase with oil in it on the motor...if you have oil in the motor already then you do not need to mix it in the gas...
I am very sure that you will find this motor does not need the gas mixed...
Run straight gas... usually it is good to run Prem in small motors..
heatman101
Posted on May 21, 2011
What is oil to fuel radio
Hi Maryanne:
Most lawnmowers have 4 cycle engines and run on straight gas.
If there is an oil sump or a dipstick to check oil level, you'll just use straight gas.
If it's a 2 cycle machine, like a weed eater, the "modern" units typically use 50:1 ratio.
Jun 13, 2015 | Garden
How do I Calculate a 20:1 oil- gas ratio for a 2 stroke engine
20 parts gas to one part oil. There should be charts on the oil container for this.
Sep 20, 2014 | Poulan 2-Stroke Engine Oil - 24 Pack
I have a sears electric power 1250 watt alternator. Model number is 580.323010 It takes straight oil. Weight and viscosity unknown. Probably straight 30w I would assume? My primary question is the gas is 2...
The manual is listed at Sears parts for $33.00
I don't blame you for not buying it.
Engine appears to be a vertical shaft lawnmower engine.
Can you find any identification on the engine as to what brand it is.
If I had to guess I would error in favor of more oil. It will smoke more but there is less risk of damaging the engine.
Some per mixes are 50/1 and are claimed to be safe.
two cycle fuel mixture YouTube
Aug 20, 2014 | Electrical Supplies
What is ther gas oil ratio
Most generators are 4 stroke and you do not mix the gas and oil. Try to contact the manufacturer for more information.
Jul 30, 2014 | Coleman Electrical Supplies
What is the problem when my 27cc craftsman weed wacker starts but doesnt stay running
check age of gas. Cannot be more than 30 days old.
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.May need to clean or replace carburetor.
May 29, 2012 | Craftsman 27cc 2 Cycle Crank Straight...
Do you run straight gas through it
No, gas chain saws use a 2 cycle oil gas mix, it should say on the chain saw fill or on a bottle of 2 cycle oil the mix or ratio of oil to gas mix.
Dec 03, 2010 | Garden
Troy built 27cc string trimmer Model TB21 EC. What is the gas oil mix ratio?
4 cycle engines do not run on mixed fuel. Run on straight fuel. They have a spot to put oil in just like a lawn mover, and should be changed regularly. @ stroke engines run on mixed fuel.
Sep 27, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
How much gas to mix the oil in?
First check that your Mantis needs an oil/gas mixture, most of the newer Mantis tillers have four-stroke motors meaning they have oil in the crankcase and use straight gas. If your Mantis needs oil mixed in the gas use a 50:1 ratio. That's usually 2.6 ounces of two-cycle oil (it's sold in bottles that size) to one gallon of gas but read the oil bottle to get the proper mix ratio.
Sep 08, 2010 | Mantis 2-Cycle Tiller
Oil to gas ratio for Coleman Powermate 5000?
my powermate is straight gas.......be careful. go to colman web site and download service manual. mike
Nov 18, 2008 | Coleman Powermate Premium Plus 6250W...
Sunpentown 2,800 Watt 6.5HP Power Generator Logo
69 people viewed this question
Top Sunpentown Electrical Supplies Experts
John Trevino
lloyd cole
rlev_7
Level 1 Expert
Are you a Sunpentown Electrical Supply Expert? Answer questions, earn points and help others
