Heater will not ignite. pilot lite is on. - Heating & Cooling
  • 43,501 Answers
Here is a tip that will help you try to figure out why your furnace is notworking.
BasicFurnace or Heating System Troubleshooting
heatman101
Posted on May 21, 2011
Why won't my Hayward H Series H200 pool heater not lite, what is the most likely problem
there are a few things you can check. make sure you have a good fuel supply. make sure the pilot light is lit. (just because the pilot is on doesnt mean you have good fuel supply). the pilot may be out of adjustment from the burner rail. the igniting burner rail may be dirty or blocked
Aug 13, 2014 | Hayward H Series Pool & Spa Heater 200k...
Igniter works gas kicks on after igniter stops if it would spark a little longer it would lite I can lite it with a match
Check igniter! You don't have the right spark? Lots of times it will short out & you can see the sparking elsewhere other than just at the gap at top of the igniter. The other thing to check is ensure that the orifice is completely clean at the pilot burner. A clean pilot orifice and the proper spark will ignite the heater.
May 19, 2014 | Pentair MiniMax 100 Natural Gas Swimming...
Jandy lite 2 heater model lj325n - code fl4 - hot surface igniter problem- I tapped the gas valve and checked the fuse , still getting the same code.
Igniter circuit is open. Check fuses on igniter wires. Identify and correct loose or broken wires.
Element has a fine crack in it. Replace
Igniter fault. Replace igniter.
Aug 31, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
Pilot lite won't light
I believe your heater uses a" Glow plug" style igniter not a traditional pilot.This type takes a few minutes to lite. Be sure the correct pump is running,the gas valve is turned on, and the Bypass valve is at least 1/2 way closed.Also make sure you have at least 10 psi on the filter gauge.
Oct 08, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
Pilot Flame will not ignite
Clean the pilot tube of rust or other debris.
Jul 10, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Can't re-light the pilot light
THIS HEATER DO NOT HAVE A PILOT YOU MUST HAVE A DIFFERENT MODEL. DO YOU GAS? TURN KNOB TO PILOT PRESS. LIGTH PILOT WAIT FOR 60 SEC AND RELEASE IF STAY ON TURN KNOB TO ON. IF TURN OFF PILOT MUST BE REPLACE
Jun 20, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Will not ignite
First check thermostat is calling for heat or if gas valve fault get unit serviced
Dec 10, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Heating & Cooling Logo
16 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
