Question about Whirlpool Refrigerators
Water leaking from the freezer into the frig through the vent in top of frig Model#ETIPHKXPQ00
  • Whirlpool Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on May 21, 2011
Maytag mtb2156de freezer leaking through the top of the frig. The freezer is keeping things frozen, but water is running onto the floor.
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Aug 28, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
Hotpoint model #ctxy14epjrwh slow water drip from inside of the refrigerator. inside the top of the frig, center, there are several components that appear to come down from the freezer. the lowest one...
The exact location of drain is under the coil behind back freezer plate in the centeroldtech2332_52.jpg
Aug 24, 2011 | Refrigerators
I have a GE PTC22MFMBLCC Top Freezer Refrigerator. I recently noted that the water line that dispenses the water to the ice tray has a drip leak. The drip starts at the back end of the tube. Now my...
the water valve is bad it is in the back under the frig. go to appliacepartszone.com put in the model # it is easy to repace just unplus the frig first
May 26, 2011 | GE PTC22MFM Top Freezer Refrigerator
Water leaking inside of frig, seems to be coming from vent below freezer
Usually if a refrigerator is holding water this means that the condensate from the freezer is not going down into the pan in the bottom, the water has to go somewhere so it ends up in your refrigerator. Find the drain line in the bottom and try some how to blow it out, if you can do this and clean the pan you should be ok.
Mar 21, 2011 | Kenmore Top Freezer Refrigerator
Refrigerator leaking water from freezer compartment, freezing along walls of freezer, but running water out under door
Sounds like the defrost water drain is plugged up. It could be a piece of food wrapper fell into it, or something. What make and model is it? Top freezer? Side by Side?
Dec 30, 2009 | Refrigerators
Everything in my frig is frozen
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .. I don't know what he was doing with the putty unless he was stopping up the vent which won't work because you have to have the air circulation for the fridge section to work. The fridge temp control may be the problem.
Aug 14, 2009 | Maytag MSD2456G Side by Side Refrigerator
At the top of the frig where the cold air blows into a small "vent" is it suppose to still have styrofoam the inside of the small "vent"? PC Water is leaking into frig and into veg bends.
most likely the drain is clogged..if it is, the water flows to the path of least resistance, hence, into the air vents and down under the crisper..remove rear freezer panel. the drain pan is located under evaporator. Defrost the drain pan if there is ice in it. there will be a small drain hole. this is where you need to see it gets open via hot water and all will be ok..make sure you hear or see it flowing into drain pan...Bruce Denton, master tech
Jun 19, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Refrigerators Logo
69 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
