Question about Miele Dryers
Miele Honeycombe Dryer T4224C. We have moved house. Our dryer is set up for moisture to drain away. we now need the moisture to go into the inbuilt container. How do I make this happen?
  • 3 Answers
SOURCE: Install 220 outlet for electric dryer or trade it for gas dryer?
Thanks for all the input!  We reached a compromise in hiring an electrician who was willing to come out today and install the connection for half what everyone else quoted...on a Sunday!  The laundry piling up in the corner was very persuasive in convincing us that your advice (in the end, we'd need a professional no matter which way we went) was prudent.  Thanks. jersey p
Posted on Sep 14, 2008
reverendrave
  • 24 Answers
SOURCE: Diagram of wiring on Miele dryer
Hello cpopp101,
Please follow the link and goto page 30 for the electrical requirements. The manual is for the T8012 but all the dryers are the same for electrical. Goto page 30. There is usually a seperate fuse box for these (Depending on how old the dryer is) in which you may want to contact Miele to see if you have
http://www.mieleusa.com/manuals_pdf/Residential/Dryers/T8012C_8013C_us.pdf
Good luck
Posted on Sep 17, 2009
  • 17 Answers
SOURCE: electric lg front loading dryer not drying well.
make sure the exhaust tube to the outside is not blocked with anything.
Posted on Nov 07, 2009
dmftrucker
  • 1922 Answers
SOURCE: Our miele condenser dryer with the miele washing
have the neutral power connection on that circuit and back to the main house panel and then have the neutral connection checked at the power companies side also, it sounds like you have a high resistance neutral connection somewhere in the circuit and its looking for another return path due to the high resistance on the line to another feed circuit line to make connection
Posted on Dec 07, 2009
  • 70 Answers
SOURCE: No heat out Miele T234C dryer.
Most likely fault is filters have been clogged and tripped the safety stat on rear of appliance. Wash filters and replace stat Part No. 5432530
Posted on Mar 28, 2010
My miele drying machine shut off after a few use then wait for a few days to work again suspect that it got moisture inside.what to do
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
Mar 01, 2015 | Miele Dryers
Reset the thermostat
If the dryer has dryness sensor strips they may have a coating on them repelling moisture from wet clothes. The brains might think them clothes is dry. Clean the sensors with windex and party on.
MIELE NOTES FROM FOGGY
Jan 03, 2014 | Miele T8000 Series : T8005 24 Electric...
The dryer does not pass 6 min mark and does not shut off. How would I test a humidity sensor? Thank you for help.
A dryer moisture sensor can stop working without notice, until you notice your clothes being over dried or still wet at the end of the cycle. It is a good practice to test the dryer moisture sensor periodically. There are two types of moisture-detecting sensors for dryers. Once you understand how they work you will see how to test each one.
1. Sensor BarThese sensors contain digits that protrude outwardly. They work on an electrical current and the moisture from the clothing.
The first step to test is to place completely dry clothes in the dryer and turn on the dryer; it should run for a few moments and then shut down right away.
Secondly, place damp clothes into the dryer, turn on the dryer and watch the timer. As the clothes begin to dry the timer will move and shut off.
2. ThermostatThe timer is regulated by the thermostat. The thermostat rests in a closed position. To test this type of moisture sensor, place damp clothes in the dryer. Watch the timer; as the clothes begin to dry, the thermostat should open and the timer will move forward ,eventually shutting off.
Sep 08, 2013 | Dryers
SAMSUNG MODEL DV218AEB/XAC LEAKING WATER
Dryers don't use water, washing machines do, so it's probably the washer.
If the dryer is drying, then it's not moisture.
Check the house drain for the washer, watch it drain and make sure it's not backing up, check the drain hose.
Apr 03, 2013 | Samsung DV218AE Electric Dryers
Condense around the door and the control module
While it COULD be stored condensation, once you run a couple of loads, that would go away. It sounds more like you have bad seals allowing moiture to escape out the door and by the control module, so you need to inspect them very closely.
Jan 23, 2012 | Miele T4422C Dryer
We have a gas dryer whipool duet . It dry the towel but it still litle damp and the flame it good , no vent hook up , and it run for 70 minute cycle ,. Any idea why that happen . Please hepl
If you are not venting the moisture from the towels away from the rear of the dryer that could be causing your problem. If the dryer is up against the wall try either moving it away from the wall or hooking a vent hose to the discharge and at least pulling the other end of the host around to the side of the dryer. The dryer pulls air into it self from the rear and bottom of the dryer so it could be pulling the moisture from the towels right back into the dryer making it take longer to dry. Hope that helps
Aug 29, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My Miele T294C NOVOTRONIC TUMBLE DRYER KEEPS STOPPING AFTER A FEW MINUTES OF DRYING. I CAN SWITCH IT BACK ON IMMEDIATLY ONLY FOR IT TO STOP AGAIN. CAN YOU HELP?
Hi - it seems likely the moisture sensor unit is faulty, reason?
Well Miele dryers after you start up will actually try to work out the amount of moisture in the dryer, it will calcualte the time & temp required to correctly dry the load in the machine. I suspect the sensor is not functioning proper.
I will assume there are no messages or other indications or flashing lights on the right side of the knob - it would be nice to plug my laptop to it and find out for sure..
You have cleaned the heat exchanger unit in the bottom corner of the dryer, the filter in the door and the two on the bottom of the door opening..
Despite all of these I would lean on the faulty sensor as the most likely culprit.
You may have to locate the nearest Miele service agent to help you out...
cheers
Jun 22, 2011 | Miele Dryers
I dont have manual for miele T5213 so cant tell - should heat button be pressed in for low temp. Doesn't seen to have time difference when drying towels
hi i have a miele t5213 dryer it was ok yesterday but today it is
not getting hot can you help also i dint have a manual for this
machine i lost it during moving house
regards jeff
Sep 19, 2010 | Miele Novotronic T1570C Electric Dryer
I have a Miele dryer, model T494C. The system starts rotate right then stops and when rotates left and immediatly the main relay of the house falls. After three days the dryer works fine. Is there...
It's most likely one of the heat/humidity sensor tubes that needs to be replaced. This has happened twice to my T494C in 12 years. Miele (or your dealer) will come out and replace it for a cost. Do NOT leave wet clothes (or semi-dry clothes) in the dryer for any length of time when the dryer is not operating. Apparently this is one of the problems.
Nov 23, 2009 | Miele Dryers
Miele Dryer heater bank
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Mar 21, 2008 | Miele Novotronic T220 Electric Dryer
Dryers Logo
116 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
