Question about Nintendo DS Lite Console
Today i went to the pool and i was splashing and my Ds was near the me and my mum shoted sauing that my Ds got wet when i got home my mum said not to tern it on intill 3 days
  • 3,018 Answers
  • Take the battery out and leave it unplugged for at least 3 days depending on the water that was splashed onto your DS I might wait a week. If you put the battery in or plug it in before that unit is dry of water the water will short out the circuit board and ruin your DSI for good and all. I suggest putting a fan directly on it to further aid in the drying process. The wait will be worth saving your DSI.
Regards, Tony
Posted on May 21, 2011
How do I fix an Jandy ePump?
open up the power box see if still wet dry out make sure communication plug is dry then power everything down reboot and try again if it doesnt work the main board in the pump is no good
May 25, 2014 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
Is it waterproof
This device is Water RESISTANT. IPX-5. It can get wet, be splashed and fall into water. As long as it is quickly removed and too much water does not seep through the top holes the speaker will be fine. It works great in the shower where it will constantly get splashed or pool side.
Apr 20, 2014 | Digix BT-100 Portable Bluetooth Wireless...
Saunacore 44QRS, is a 120 vac unit. As soon as you turn the elements on it trips the circuit breaker. I've tried plugging into different outlets, even a dedicated 20 amp circuit. The unit is only...
must be running with gfi. run for one hour without neutral wire connected. it will dry moisture content within heater elements. then reconnect neutral wire, and walla, no tripping.
Jul 13, 2011 | Saunacore Standard Residential Sauna...
My son dropped his ds in the pool and it got wet
If he tried to turn it on while it was wet the water on the circuitry would act as a conductor and the circuit board could or is fried. If nothing is working which it's probably not you'ld need a new ds. If it's under warranty you could try that but many electronics now have strips to indicate if they've been submerged in water and that will automatically void the warranty from personal negligence. If it got wet and you've not turned it on or done anything yet, remove the battery, let it sit for about 72 hours in an area with a high enough heat to help dissipate the water but not directly in front of a heater or something similar and try it after that point
Apr 28, 2011 | Nintendo DSi Blue Console
My ford windstar wets pluges after which the car will not start. you need to clean the pluges before it will ever start. when it is driven it makes some shoting noise. I ve changed the pluges, clean the...
If it is all plugs I would check the fuel pressure regulator, see if gas leaks out of it when you remove the vacuum hose. It is located on top of the engine, near the fuel rail.
Jan 07, 2011 | 2001 Ford Windstar
The phone got wet when splashed by pool, now front buttons do not work except power/end button. inside works fine. is there a solution to this. and wont hold a charge long anymore. lg env2
Look, enV2s **** ****. almost everyone at my school thats had one, the front buttons quit working... even mine and i only dropped it once. its just a bad phone when it comes to front buttons.
Jun 15, 2010 | LG enV2 EnV-2 VX-9100 VX9100 Premium Pink...
Ds wont turn on
never get your d wet but if u want 2 keep your DS, just bring it to the company or look in the box an they give you a phone#
Nov 28, 2008 | Nintendo DS Console
Nintendo DS not reading games
Some pins were bent in my son's DS. I used a mini LED light and an open paper clip as a pick to bend them back into line.
I then got an Emory board (nail file) and wet the tip in alcohol, the board is the right thickness to just reach the copper pins. I went in and out gently as I worked my way across the lot and kept wetting the file with alcohol. All the games worked like it was new. be sure to do this upside down so the alcohol drips out the slot along with the filings. good compressed air blow after you are done to get all the strays out of there.
The pinds are copper and they do oxidize and the games left in gets moisture trapped between the game and the pin causing some corrosion. Maybe diddimilar metals by alloy but wither way this fix works ! : )
Sep 21, 2008 | Nintendo DS Lite Console
Error shoting
It is a technical problem in the hardware of the camera which has to be fixed by a technician.
I just fixed this problem two days ago.
vicky
Oct 30, 2007 | Nikon D40x Digital Camera
Nintendo DS Lite Console Logo
57 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
