Question about Miller Welding Tools
Why is the maintenance light on in my miller 250 bobcat
  • 1,940 Answers
The maintenance light is probably on because of low oil pressure. Check the level of oil and top it off.
You may also want to check your Air Filter, Fuel Filter, Spark Arrestor, and Fuses.
Here is the manual for your Miller 250 Bobcat:
http://www.millerwelds.com/om/o4419m_mil.pdf
Posted on May 21, 2011
What Battery does my Miller Bobcat welder take I cant find any markings
The original battery is rated 430 cold cranking amps and 75 amps reserve Group 58. What I have found locally in that group size are: one with 850 cca, one at 700 cca, and one at 550 cca.Bobcat 250 Battery.
this is all I could find out.
http://www.millerwelds.com/resources/communities/mboard/forum/welding-discussions/33890-bobcat-250-battery
Nov 06, 2016 | Miller Welding Tools
I have a 2007 miller bobcat it has spark cleaned carb new plugs new filter and it won't start
did you try a touch of starter fluid in the carb just to verify that the engine is getting spark? ethanol gas... if it hasn't run in a few months and you left the gas in it... you better revisit the carb cleaning
Dec 13, 2015 | Bobcat Miller 250 Welder Generator 907212...
225Bobcat gen.runs but will not excite when trying to strike arc
#Tags bobcat 250 welder service manual
coop.bounceme.net/term/bobcat-250-welder-service-manual
Why does my miller bobcat welder generator not stay at an idle when swithed to low idle, insted it goes back and ... Won't strike an arc,fuses ok brushes and slip.
Aug 11, 2015 | Electrical Supplies
Miller bobcat 250
remove the side doors, and top cover, make sure your brushes are making correct contact against the slip rings, there is a flat mounting panel behind the range control switch, you will see 2 white fuses in their holders, check these fuses, one controls AC output the other controls weld current output.
May 19, 2014 | Welding Tools
Miller bobcat on propane surges when turned to idle
It might be missing a stabilizing spring on the the throttle shaft to eliminate accumulated play in the components.
Otherwise if no smell of leaking LP is noted, there may be a small vacuum leak in the induction system- can be found with carb cleaner on an idling engine- the area of such a leak when sprayed will smooth out the idle and speed it up momentarily.
If you do smell LP, the regulator likely needs repair or a hose needs replacement..
Sep 14, 2012 | Bobcat Miller 250 Welder Generator 907212...
I have a 250 bobcat that stick welds just fine but when you go to wire feed and plug in suitcase box wire feed unit wire feeds but it doesn't get hot enough to melt the wire. LF299725
What model of suitcase? Could be the contactor in the suitcase, could be the mig gun. Are you using the CV setting on the Bobcat, instead of CC? Is the Bobcat on the high CV setting and the dial most of the way?
Apr 30, 2012 | Miller Bobcat 3 Phase Welder Generator...
How to separate the kohler engine from the generator of a miller bobcat 250
The shaft is tapered and will have a bolt in the center, loosen the bolt enough so you can tap on the end of the bolt. This should release the shaft, if not there should be 2 hole that you can thread a bolt into to push the connection apart.
Jun 25, 2011 | Bobcat Miller 250 Welder Generator 907212...
Can i power this unit with my old Miller Bobcat 225. Also what gun do you recommend?
If your Hobart Mig is less than 250 amps then yes you can, bobcat 225 will give you10000 watts and you require at least 8000 watts for the hobart.
Dec 21, 2010 | Hobart Welding Tools
Miller bobcat 250 welder with kohler lp gas engine won't idle properly any adjustments for air/fuel mix?
Make sure that the idle is set at 40Hz. You do this by placing a frequncy meter on one of the 120Vac outlets. If frequency is low, the engine will run rough at idle. There is a 3/8 nut next to carberator that needs to be turned to the right to increase the idle speed.
May 13, 2009 | Miller Welding Tools
Welding Tools Logo
511 people viewed this question
Top Miller Welding Tools Experts
Kory Ronning
hubiam
hubiam
Level 1 Expert
John Trevino
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
