Spin cannot funtion - Washing Machines
  • 1,170 Answers
Hello, A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem. 2)If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place. 3)Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task. 4)Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
  • If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall.
  • Thanks.
    Posted on May 21, 2011
    HI WHEN USING THE FUZZY CYCLE THE MACHINE STOPS AFTER THE SPIN AND RINSE FUNTION. WATER CONSTANTLY RUNNING OUT
    pressure valve stuck...remove lid............look for small plastic unit with a thin pipe connected to it......remove small pipe and blow through it a few times
    cheers
    Nov 21, 2016 | Washing Machines
    Washer broke
    that is just a dampening ring. Does nothing with the funtioning of the machine. if the machine stays full of water and doesnt drain
    May 27, 2013 | Washing Machines
    How do you unsnap the lid clothing stuck under agitator
    i bought2 month ago new electrolux washing machine model EWF 8556....now this washing machine will give me a problem......problem is start /stop button always blinking.....and other button also not funtion( spin/option/rinse) also for delay button....... so please help me as soon as possible..... tq
    Aug 12, 2010 | Washing Machines
    CAN'T SPIN OUT
    do you mean the little prong that sticks into the lid switch to make the lid switch funtion so that it can spin you need to order the piece that he broke off on the lid or If he is mechanically inclined have him open the top find the lid switch connection and use a jumper wire from positon 1 to positon 3 on the lid switch wire connection this makes the unit run normally whether or not the lid is open or closed if he is mechanically inclined two phillips scews in back of unit to open the head
    Apr 28, 2010 | Roper RAS8445KQ Top Load Washer
    I have a Hoover Vision 1600 plus that has stopped spinning. Water pump works, water inlet works- drum will not spin. Help!
    Could be motor or motor brushes you could remove one carbon brush check if its worn should be at least 1/2 inch left in order to funtion well
    Apr 01, 2010 | Washing Machines
    My whirlpool duet washing machine will not spin quickly to drain out the excess water in the clothes. I noticed a set of lights are out on water temp (superhot and warm) and the low spin speed light. Any...
    It sounds like that you may have some non-funtioning circuits in your control panel. May need to hire someone who is well versed in electronics to test some of the circuits.
    Mar 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    I WANT TO ASK ABOUT THE FUNCTIONS OF INDESIT WIXXL 146 WASHING MA
    instruction book http://imagebank.indesitcompany.co.uk/brochures_online/pdf/indesit/Laundry/WIXXL146-GB-Hires.pdf
    Jun 10, 2009 | Washing Machines
    Metal to metal noise while spinning? whirlpool heavy duty super capacity plus email pjbmaxx@q.com
    Yuo may want to cheak the inside of drum where the holes are and make sure there are no nails or screws stuck there .If not does the unit still funtion normaly as in spin and agitate?The other thing that may have happend is the coupler is busted and is rubbing on motor shaft.To cheak this you will need to look under waher and inbetween the motor and trany there is a coupler.They break due to over load or a miss funtion in the trany.Hope this helped:)
    May 16, 2009 | Whirlpool Washing Machines
    Wash cycle,spin dry, water level
    I WOULD CHECK FOR A PLUGGED AIR PRESSURE HOSE OR THE PRESSURE SWITCH ITSELF.
    Jan 26, 2009 | Hoover Washing Machines
    Washing Machines Logo
    61 people viewed this question
    Top Washing Machines Experts
