Question about Sony DVP-FX730 Portable DVD Player
Hi there, I let my daughter use my DVP-FX730 and next thing I know it's not reading discs. Actually says "Cannot read this disc." It's out of warranty and I hate to throw it out - however it's likely going to cost me more than it's worth. Thoughts?
  • Sony Master
  • 6,771 Answers
Unfortunately the problem is in the laser pickup assembly, the only option is take rubbing alcohol and a q-tip and carefully wipe the lens and allow several minutes to dry, if you are lucky the unit will function, if not! much cheaper to replace the dvd player.
Posted on May 21, 2011
Dvp-fx970
here is an answer anyway--if will not play a disc "cannot play disc etc" usually it is either a dirty or bad optical pickup in the unit.
May 20, 2012 | Sony DVP-FX730 Portable DVD Player
My sony dvd can't read any disc imported or local disc, what should ido ?
its restricted by local codes, not possible playing untill unlocked
Nov 10, 2011 | Sony DVP-NS51P DVD Player
My dvd will not play any disc it's the sony dvp-ns725p model
If you have necessary tools and test instruments, know safety precaution in basic troubleshooting try the steps below to solve your problem.
Assuming that the disc is good.
1.Clean the lens. - Sometimes because of dust and any fine foreign objects the lens can't read any disc. If you have a CD Lens cleaner, play it to the affected area. If this is not available you may manually clean the optical lens. Open the cover and gently clean the eye of the lens by smooth,clean,soft cotton buds. Be careful while doing this, just a gentle stroke only.
2.Check the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc. Also try to erase the contact by pencil eraser. If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
3.Check the motor - Check the motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.Good motor - reading should be fairly high and it will spin. Bad motor- reading will drop to low resistance and will not spin.
Click this link for more info.
LINK1
LINK2
Hint : Most of my repaired unit the above parts are commonly caused of the problem.
If you confirmed that you have a defective motor then replace it with a new one. Before replacing the new motor you have to check the clearance of the disc holder with the old one. The clearance should be the same as the old because if not the lens will not read the disc if it is too far or too close.
If the above steps didn't cure the problem, high chance that your optical lens was faulty.
If you can't do the job yourself, I would advice you to look for a professional to troubleshoot the symptom.
Also, check if your unit is under warranty period, avail it because the manufacturer will fix it for free. Don't attempt to open the cover(it will void the warranty).
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jun 28, 2011 | Sony DVP-NS725P DVD Player
My Sony DVP-CX777ES player just opens and closes several times upon powering up. Then it stops and I get an error message that reads "C 32 00." Then it turns off.
Please check door mechanism as explained in chat session and possibly loading belt and/or door switches could be culprit and causing problem.
Hope this will help.
Thanks.
Mar 13, 2011 | Sony DVP-CX777ES Multi-disc DVD Player
Hi, I have a sony portable dvd player (DVP-FX730). Is there any way I can make this region free? (currently region 2)
I'm afraid, there is no way to change region code in Sony dvd players including DVP-FX730
I'm sorry for that.
Thanks.
Mar 09, 2011 | Sony DVP-FX730 Portable DVD Player
Says cannot play the disc or no disc
Hi Kenny, Here are some steps that may help. You should prepare tools and multimeter. Assuming that the disc is good.
1.Clean the lens. - Sometimes because of dust the lens can't read any disc. Try clean the lens by soft cotton buds. Be careful while doing this.
3.Check the motor - Check the motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.Good motor - reading should be fairly high and it will spin. Bad motor- reading will drop to low resistance and will not spin. You may visit this link for more info http://www.fixya.com/support/r7833671-change_defective_motor_portable_dvd.
Hint : 50% of my repaired unit the above parts are commonly caused of the problem.
Ifyou already cleaned the lens, and confirmed that the ribbon is good as well as the motor then I've advice you to send it to repair shop because the next step should be done with an expert because it is quite technical diagnosing the fault between the pick-up lens and the main board.
Hope it may help you.
Have a nice day!
Feb 11, 2011 | Sony DVP-FX730 Portable DVD Player
My Sony dvp-cx777es won't play DVD's anymore. It will play any CD just fine but when I put in any DVD video movie the unti will not read it. It just sits there and after a couple of mins it says...
I Fixed Mine!!! I found that the part that spins and reads the dvds was bad. Luckly i had a spare changer at home to test this. I took it apart and got this info from the part that i replaced.
KHM-2
90AAA
07666HA
514659
Hope this helps
Nov 05, 2010 | Sony DVP-CX777ES Multi-disc DVD Player
Sony portable DVD player wont load DVDs
maybe the spindle motor is defective so it cannot read the disc. just bring that your dvd to sony service center to fix your dvd.
Jun 19, 2010 | Sony DVP-FX730 Portable DVD Player
Sony DVP-FX730 Portable DVD Player Logo
204 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
