Question about Samsung DV337 Electric Dryer
I have samsung dv337 electric dryer, just a little over one year old. it does not generate heat now. everything else is fine. I checked circuit break. It is fine too.
  • Samsung Master
  • 7,482 Answers
Hi jianyuzeng...
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please take time to rate me
Posted on May 21, 2011
Testimonial: "Actually the heating coil was broken."
Dv337 not drying
check for full power from the outlet a full 240 not 120, check the heating element, the hi-lo and cycling thermostat
Jul 23, 2014 | Samsung DV337 Electric Dryer
Samsung front load electric dryer not getting hot
There is a thermal sensor type breaker leading to the heating element. They are usually round, about quarter size, with a spade connector on each end. They can be checked by a OHM meter to see if they make a connection from one terminal to the other. There may be more than one. If that checks good then you need to check the heating elements for resistance for one end to the other. If there is no resistance then the element is bad.
Jan 23, 2014 | Samsung Dryers
Motor running -no heat.Did troubleshooting from the manual-still no heat,called samsung support,went through troubleshooting with them-still no heat,run dryer on manual for 5mins.-blew cold air.Can you...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 04, 2011 | Samsung DV337 Electric Dryer
Not heating
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 21, 2011 | Samsung DV337 Electric Dryer
My drier has no heat
Element has failed. The heating element looks like a big spring which is wrapped around the inside of the drum. Over time, the heat breaks down the tungsten which they are made from and it will separate breaking the circuit. You can buy a replacement and put it in yourself or have a repair man do it. Hope this helps : )
Jan 07, 2011 | Samsung DV337 Electric Dryer
My samsung dryer will not turn any suggestions? It is less than a year old was working fine and when I switched loads the unit lights up just will not turn
Door switch...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 24, 2010 | Samsung DV337 Electric Dryer
Hello my samsung dv377 dryer is not heating in any mode.
This is the best and easiest, Hope it helped Tim:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Oct 16, 2010 | Samsung DV337 Electric Dryer
The dryer will not heat. I have no error codes and everything else works fine. I did order a heating element assuming that was the issue but now wonder if I would've had an error code and it could be...
heatman101
Oct 05, 2010 | Samsung DV337 Electric Dryer
I have a Kenmore Dryer model #110.66732500 that just quit heating. Everything else is working fine, tumbles but no heat. It is 4.5 years old. When it quit it tripped the circuit breaker, we reset the...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
bn
Sep 28, 2010 | Kenmore Dryers
Will not dry,
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 12, 2010 | Samsung DV337 Electric Dryer
Samsung DV337 Electric Dryer Logo
805 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
