Question about Mitsubishi WD-60638 DLP TV
I have a WD-60638. I have a PS3 connected to it by HDMI cable, and it onlt picks up the signal from the PS3, (which works fine when connected to other HDTVs), about half the time. Even when I do get a signal, when I go to load up a blu-ray or game, anything where the screen fades to black, or if I switch the input to antenna, leaving the PS3 on, to watch TV, then back to HDMI later to play PS3, it's again 50/50 whether the signal comes back, I always get the dreaded No Signal/Invalid Format. I've tried several different cables, and this is the 2nd TV of this model I've had, sent the 1st one back because I thought it was defective, but still having the exact same problem. I've tried all the PS3 fixes imaginable, restarting the PS3 in safe mode, resetting PS3 settings, unplugging PS3 and TV for a few minutes to reset them that way, nothing has helped. Any suggestions?
  • 20 Answers
SOURCE: HDMI connection problem
On your TV set remote are you selecting the proper input; for example when you have different devices connected to the back of your tv set, dvd player, vcr, cable box etc; you have to tell the tv which device you want to use by selecting the right one on your tv remove input selection. Hope this was any help.
Posted on Sep 08, 2007
SOURCE: Mitsubishi HDMI connection trouble
I have the same issue with my 73". Rather then going over all of my connections and equipment I'll just say htat I feel your frustration. I have been on the phone with Mitsubishi directly and it appears as though they have a free software upgrade that should address this problem. If you call 1-800-332-2119 and press 4 in the menu you will get someone to help you. Be patient. They will make you go through all of the fixes that you have already tried. They will mail you a flash drive that goes right into the front USB port of your TV. I hope this is of help. Good luck.
ret4good
Posted on Jan 05, 2009
localwonder
  • 6784 Answers
SOURCE: Mitsubishi TV WD-62527 will not turn on
Hi there, this is most commonly known as power board failure in the industry. the capacitors are blown. if you are experienced in inspecting circuit boards this will be helpful. you will have to disassemble and pull the power board and preform a break point test. the bown capacitors are easily picked out. they will be swollen and discolored. If you are not comfortable with disassembling this set, i suggest a service call. just tell the tech you are experiencing a power board failure.
Posted on Mar 07, 2009
SOURCE: Mitsu 57731 problems have wide bar across screen
This is an ongoing problem with Mitsubishi DLP HDTV's contact the Customer Service at 1-800-332-211. Tell them this has been going on for a while and you want the TV either Fixed or Replaced. Ask for Adrianne Hardt, she is a Customer Service Manager...... TELL HER RICK GRIFFITH told you to call.
I am in the 4th week negociations with Mitsubishi over these exact problems. I purchased my 57" DLP HDTV in Aug of 06. Replaced the Lamp 3 times and have had 5 Service calls. I DO NOT have and extended Warranty. Mitsubishi provided me with the extention in writing and stated if any problem occurred again they would replace the Unit or provided monetary compensation.
Good Luck and be persistant.
Any of you can email me for from info and covette54@live.com
Posted on Mar 15, 2009
SOURCE: Inputing HDMI signal to a WS-55313 55 via an HDMI-DVI cable
HDMI standard is a bear, especially "Older" versions. It should be possible to input HDMI to a DVI, either DVI-I or DVI-D, input, there are however DVI analogue too, in fact we have, 3 type of them, they are, DVI-I, DVI-A & DVI-D.... Also some HDMI do not send the Audio over it, as it should, so all in all it can be a pickle. So you MUST get a converter that works with your sort of DVI. You would have to select that DVI, input, which may be under Auxillary, or External or the like, try scrolling through your AV inputs, see if you "Find" it. if so, the set will "Read" the signal and display it automatically. The Audio, however will have to be done via the AV sockets, the Red & White stereo IN, from the DVD etc. If you have any other inputs such as Component Video, Green, Red, Blue, then this is the best way... The Audio, again must be routed to the AV, the Red & White Jacks. So ensure you have those outputs on your new DVD.
I have included a couple of links below about DVI & HDMI for your convenience. http://www.datapro.net/techinfo/dvi_info.html http://www.hdmi.org/learningcenter/faq.aspx
Posted on Feb 11, 2010
Samsung TV Is Not Picking Up A Playstation 3 HDMI Signal
If you are able to connect your PS3 to another TV using the same HDMI cable that would rule out your PS3, if it works.....or
does the PS3 itself have any settings that perhaps need to be set to an HDMI output as opposed to Composite or SCART etc?
Also have a look at the HDMI settings in theh TV menu too.
Jan 10, 2014 | Video Game Consoles & Games
Scart signal
check the tv mode av1 av2 and pal settings
Sep 05, 2008 | Televison & Video
HOW TO HOOK MY LAPTOP TO MY WD-60638
The easiest way would be through a HDMI cable.
Jun 15, 2012 | Mitsubishi WD-60638 3D-Ready DLP HDTV
I have a wd-62525 dlp i have pic and sound through ant. and hdmi but on component and video inputs i only get sound no pic
Hello
It seems to be some fault with its HDMI cable you connect to this device from the source. As you get sound by HDMI, and no picture at all, this indicates the fault with cable itself. There is a cution notice says that " To assure continued FCC compliance, the user must use a shielded video interface cable
with bonded ferrite cores at both ends, when using the PC or HDMI input."
Cheang the cable and check.
Oct 10, 2011 | Mitsubishi WD-62525 62" Rear Projection...
My Toshiba 57H84 has stopped picking up my PS3 through HDMI
try holding your finger on the power button(next to disc eject) for 5 secs
May 24, 2009 | Sony PlayStation® 3 (60 GB) Console
No sound through ps3 hdmi
I have sound on video 2, and when on a static channel but not on the usual channel 3 which is TV. Just stoppen working one day and cant figure it out... Please help!
Oct 19, 2008 | Televison & Video
Ps3?
Check the couplings at either end of the cable. Sometimes these will loosen and can cause a lack of signal strength.
but its probably not the cable, its probably the ps3. HDMI cables don't really break because they are just wires, they don't have moving parts. Try connecting your PS3 to your TV with the regular cable red, white, and yellow connectors that you got when you bough the PS3. If the PS3 doesn't work with the original red, white, and yellow connectors then you know its the PS3. If the PS3 does work fine, you know its either the HDMI cable (still unlikely) or the HDMI connection on your TV or PS3 (more likely
Oct 12, 2008 | Sony Playstation 3 (PS3) Console
Mitsubishi WD-52631no picture through the HDMI connections
had the same problem get a new cable its not the tv its the ps3 if the cable is tight in the ps3 it works fine or if you set the ps3 just right the cable will fit fine and work
May 24, 2008 | Mitsubishi WD-52631 52" Projection HDTV
Mitsubishi WD-60638 DLP TV Logo
156 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
