Question about Dryers
Check lint screen indicator light remains on,
  • 2 more comments
  • jmcmanus0068 May 21, 2011
    Ive cleaned the lint screen with warm soapy water. Problem still exists.maybe faulty sensor for lint screen or bad board?Does a dryer only have one board?
    you say ventilation?from connection of dryer to outside of house?
    hello there,
    kenmore elite dryer m#11062062101
    Thanks for your assistance
  • jmcmanus0068 May 22, 2011
    Hello Again,
    Where is the heater assembly located to test the thermostats?How many are there?
    If there isnt any sensors for the lint screen? What are the 2 wires connected to the 2 stripes
    of aluminum that you can slide off and shuts off the beeping sound of the lint screen?
    thanks again
  • Dryers Master
  • 19,396 Answers
Hi.
You need to access the lint filter and clean it. Details on the procedure depend on the dryer model and are illustrated on the owners manual. After cleaning the filter open the dryer door or press start to turn off the light. Try also disconnecting power for five minutes .If the "check lint screen" light does not go off after this there may be a problem with main board, or with ventilation.
Posted on May 21, 2011
  • 1 more comment
  • Ginko
    Ginko May 21, 2011
    Hi.
    If the problem persists, then the exhaust must be checked. About lint sensor and other parts, to be more specific I would need the model number of the appliance.
  • Ginko
    Ginko May 21, 2011
    Hi.
    THere is no sensor. The error is prompted when overheating is detected.
    Please see diagram below. Click on the picture to enlarge.
    Lint screen is part 64. Unscrew lint housing, remove the filter and and clean it. Hoover the filter housing.
    If that is not enough, check for lint in parts 22 (exhaust), 5 (air duct) and 45 lint duct. Hoover this parts.
    If still no luck, then the thermostats in the heater assembly must be tested.
    Regards.
    Here all parts and diagrams for your dryer.
  • Ginko
    Ginko May 22, 2011
    Hi.
    The two wires are a kind of switch. They close the circuit when the filter is in place. That does not detect the amount of lint. I am not sure if that can also trigger the error code. The case is not reported in service manual and this is not a common failure.
    There is one thermistor (42)
    Thermal cut off (47)
    Hi limit thermostat (48)
    There is also a thermal fuse .
    If the dryer is heating, then the thermostats are OK.
Check filter light blinking will not start only beeps what to do please help
Probably a lint buildup on the sensor. Need to clean the entire lint system. Should be able to remove the plastic frill if the lint filter is inside the drum. Remove the two screws and clean out all the lint then pull the dryer out remove the vent hose. Run a vacuum hose or reach up i to there and pull out the li t. Then clean out the vent hise...a broom handle works if it's a straight shot.
Oct 11, 2016 | Kenmore Dryers
Lint light flashing
The problem may be with air flow through the lint filter screen. The filter is a fine screen and even though it appears to be lint free, it may not be. Spray the screen with a degreaser, use a soft brush to gently scrub it, and rinse under running water. This may solve your problem.
Jun 30, 2014 | Bosch Nexxt 500 Dryer
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Lint screen light is on, dryer won't start!
If you use dryer sheets they create a wax coating on the lint screen,even tho it looks clean,use dish soap and hot water to remove this,dry it then put it back in and try it.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 30, 2009 | Bosch Nexxt WTMC 6500 Gas Dryer
Clean lent filter sign shows and won't let it run. power is on and have manually checked the vent hose, exterior exit. still won't work Clean Lint Filter Indicator Light Flashes but my lint filter is...
check for wires near lint filter casing. these are the lint filter sensors, they could be defective that is why it always indicate a clean lint filter alarm,
Feb 19, 2008 | Dryers
PF indication (Power Failure) and dryer digital light up but will not start
check your owners manual for clearing error codes in trouble shooting on theese electronic models lots of time you have to clear the codes to go back to normal ops by pushing certian buttons on kenmore i dont know which ones they are usaly its clear/cancel buttion some times you have to holld them so many seconds just unplugging it will make it think it has another power failure
Dec 26, 2007 | Kenmore Elite HE4 Electric Dryer
Water full indicator light
on most condensor dryers they also have a filter water bottle and also a radiator have u checked this becomes sometimes they get clogged up with lint this then doesnt let water go through as easy and it can put your water light on
Aug 22, 2007 | Zanussi TC7102W Electric Dryer
Dryers Logo
144 people viewed this question
Top Dryers Experts
